Forum Replies Created
Liviu Ojoga
BRONZE MemberSoftware is updated…..latest version 2017:(
but it cannot find a newer one
Liviu Ojoga
BRONZE MemberYes, I can control BV11 on BO app, but wife is not happy with phone controls:)
I assume new beoremote1 displays with 4 buttons can be matched with old aluminum frames….I am still thk if I should buy a new beoremote 1 or just the display/buttons panel
Liviu Ojoga
BRONZE MemberIt control it (start/stop/vol/etc), but if I open menu or program list I cannot scroll
Liviu Ojoga
BRONZE MemberAfter changing BV11 from beoremote1 to beo 4 you have another tab active, with 3 options : 1,2 and 4.
i thought that they ar eequivalent of Modes of beoremote so I tried all of them in order to match the beo4 mode (that I cannot find in setup to change)
When I selected 4, both remotes became unresponsive….I couldn’t change anything in bv11
i will paste what chatgpt instructed me to do, and it worked:
● + LIST → OPT? → GO → V.OPT → 1
Liviu Ojoga
BRONZE MemberI tried to setup BV11 to be controled by beo4….then tried 1 and 2 and 4 ….Beware that when you choose 4 both remotes (beo4 and beoremote1) became “dead”.
It was a full story to recover access to bv11:)
Liviu Ojoga
BRONZE MemberSo, the only remote to control bv11 is the joystick one?
In this case, did someone replace the beoremote one screen or do you advice to buy a new now?
I have seen here an offer for 177GBP just for the screen.
Liviu Ojoga
BRONZE MemberFor the navi remote (with joystick)
> Press and hold the standby button down.
> Press LIST to get access to the Beo4 setup function.
> Let go of both buttons. ADD? appears in the display.
> Press LIST or ^ to display ZONE?, CONFIG? or MODE? on Beo4.
> Press the centre button to select the setup you want.
> Press up or down arrow to display the setting you want on Beo4.
> Press the centre button to store the configuration.
> STORED appears, indicating that the configuration has been stored.
Long press on BACK will leave the setup.I did this but Zone and Mode doesn’t appear!
Liviu Ojoga
BRONZE MemberThanks!
I setup BV11 to be used with beo4, but the problem is that I cannot find MODE on my beoremote4.
did you put the remotes in mode1 and tv set to be used w b4?
