Home › Forums › General Discussion & Questions › General Discussion & Questions › Beo4 for BV11
- This topic has 22 replies, 4 voices, and was last updated 1 month, 1 week ago by
carolpa.
7 September 2026 at 14:48 #125447
Liviu Ojoga
BRONZE MemberSoftware is updated…..latest version 2017:(
but it cannot find a newer one
7 September 2026 at 15:49 #125448 Guy
ModeratorAccording to page 6 of this: https://update.bang-olufsen.com/products
… the latest version is 1.0.11.37484
7 September 2026 at 19:16 #125452 carolpaBRONZE Membercarolpa wrote:
No, all Beo4, Beolink 1000 and Beoremote One can actually control the BV11.It all depends on how the BV11 is setup. Look in the setup for the option to select the correct type of Beo4.
I too thought that, but found this in a BV11-40 manual:Note that your Beo4 remote control
must be set to mode 1. For more
information, see the Beo4 online guide.
You cannot use a Beo4 remote control
without navigation button.So perhaps some SW versions did not have the facility to chose remotes with/without navi button.
That seems peculiar………. how about the BR1: no navi button.
And the 46 and 55, for sure had the option to select the remote, when I had these Beovisions.I think he should try to set the BV11 to non-navi button and the Beo4 to mode 1 (if these older Beo4 do have these settings) and try the Beo4 OR set the BV11 to Beoremote One and try the Beo4.
But keep the BV11 option to 1 or 2 (and thus the Beo4 settings in the BV11, if asked, also).Note: does he have a Beovision 11 for sure?? Or does he have a Beovision 14??
