Forum Replies Created
13 October 2026 at 14:54 in reply to: Beovision 7 – 55 + Beolab 7.6 + wall mount + Beo 4 remote. Poss Beosound 6 #125873
Johnny T Dep
BRONZE MemberMake me an offer… this really should be getting used!
8 October 2026 at 19:07 in reply to: Beovision 7 – 55 + Beolab 7.6 + wall mount + Beo 4 remote. Poss Beosound 6 #125799Johnny T Dep
BRONZE MemberOne time offer… £200 for the TV and wall mount stand!
11 September 2026 at 16:15 in reply to: Beovision 7 – 55 + Beolab 7.6 + wall mount + Beo 4 remote. Poss Beosound 6 #125509Johnny T Dep
BRONZE MemberI should have said that I have the original manual and PIN code.
11 September 2026 at 16:14 in reply to: Beovision 7 – 55 + Beolab 7.6 + wall mount + Beo 4 remote. Poss Beosound 6 #125507Johnny T Dep
BRONZE Member2009 but if you are interested you’d need to visit Thomas Miller Auctioneers to view the TV. I’d be able to pull the item from the sale on the 6th October. However, I’d have to pay fees but I can live with that or you could take a gamble that you’ll get a bargain… but with their 33% fees on top of a purchase price (I’ve got a reserve on it) I’m not sure it’ll be as cheap as buying it off me!
You must be logged in to view attached files.Location: johnny.thedep@gmail.com
10 September 2026 at 18:33 in reply to: Beovision 7 – 55 + Beolab 7.6 + wall mount + Beo 4 remote. Poss Beosound 6 #125498Johnny T Dep
BRONZE MemberLast shout for a local NE UK sale as this will be going into a local auction house on Friday afternoon (they valued it at £350 but there are 33% charges on whatever you bid).
Johnny T Dep
BRONZE MemberGuy wrote:
For the navi remote (with joystick)> Press and hold the standby button down.
> Press LIST to get access to the Beo4 setup function.
> Let go of both buttons. ADD? appears in the display.
> Press LIST or ^ to display ZONE?, CONFIG? or MODE? on Beo4.
> Press the centre button to select the setup you want.
> Press up or down arrow to display the setting you want on Beo4.
> Press the centre button to store the configuration.
> STORED appears, indicating that the configuration has been stored.
Long press on BACK will leave the setup.
I did this but Zone and Mode doesn’t appear!Yes, same for me. I tried all 3 remotes (same as in my pic above) and none had the option for Zone / Mode
Johnny T Dep
BRONZE MemberIs this considered to be the Beo 4 ‘with’ a navi button/joystick?
Johnny T Dep
BRONZE MemberI have x3 Beo 4 remotes (I have bought various B&O items used, all with remotes), I recently acquired a used BV7 and none of the three remotes would allow me to scroll up/down in the TV set up options (they ALL allow up/down scroll with my other BV7 TV). I researched how to resolve this and the ‘mode’ option came up in many searches but none of my remotes allow this option.
This leads me to believe the issue is with the TV set up, not the remote!
Sorry if this doesn’t help but it may not be directly the fault of the remote being disabled.
Johnny T Dep
BRONZE MemberThat’s exactly what I hoped someone could help with, thanks Guy. My head was battered looking at flat plates, ALIEN spiders and a couple of other options and there was just no definitive, easily understood answer.
It seems a shame to waste the present stand, I may see if I can source a 9515… though if a BV10 stand came up, I could sell the stand for the BV7.
Thanks again.
