hcraig244
Forum Replies Created
Viewing 20 posts - 81 through 100 (of 337 total)
  • in reply to: Beogram 4000 – servo optical diaphragm adjustment #64749
    hcraig244
    SILVER Member
    in reply to: Beogram 4000 servo belt question #64592
    hcraig244
    SILVER Member
    I have been inside several BG4000 over the past few years and not seen a carriage motor with a pulley wheel with a different profile to that which yours has, that doesn’t mean there are none out there of course. Regarding the belt I have had one with a round profile belt that worked fine despite being somewhat floppy, I suspect it started life as a O ring and not a drive belt….I replaced it with a belt from Dillen and adjusted the tension accordingly. The Service Manuals B&O supplied are very detailed and for the most part accurate….but im sure im not alone when it comes to stumbling over the occasional inconsistency therin……..buy a replacement alloy pulley for the drive shaft and a new belt and you will be fine, yours does look perfectly fine by the way……I should replace mine also, just havent got around to it yet ;¬)
    Craig
    in reply to: Beomaster 6000 (2702) Remote Control #64338
    hcraig244
    SILVER Member
    last
    in reply to: Beomaster 6000 (2702) Remote Control #64332
    hcraig244
    SILVER Member
    some more
    in reply to: Beomaster 6000 (2702) Remote Control #64327
    hcraig244
    SILVER Member
    here we go…
    in reply to: Beomaster 6000 (2702) Remote Control #64326
    hcraig244
    SILVER Member
    That’s a very ambitious undertaking Jouni..
    All credit to you, the cost of producing such a piece must be high…not including your time of course which you give freely, my few dealings with custom laser printed items has always resulted in high costs.
    I will provide the images you have requested today……keep the pictures coming.
    Craig
    in reply to: Beomaster 6000 (2702) Remote Control #64216
    hcraig244
    SILVER Member
    Jouni
    I bought the 15v battery relatively recently, amazon I think VARTA No 4074.15v.V74PX
    Craig
    in reply to: Beomaster 6000 (2702) Remote Control #64199
    hcraig244
    SILVER Member
    Oh….and a 15v battery
    If I can help anymore let me know
    Craig
    in reply to: Beomaster 6000 (2702) Remote Control #64194
    hcraig244
    SILVER Member
    Couple more
    in reply to: Beomaster 6000 (2702) Remote Control #64189
    hcraig244
    SILVER Member
    No worries Jouni
    Not the best images but take a look….
    in reply to: S45-2 Woofer Problem #64184
    hcraig244
    SILVER Member
    Ahh…..nothing so adventurous Glitch, tried and tested hair dryer technique. So here is the finished article still giving 3.8 ohms and now moving freely….wont commit this to the postal service today  as it will languish in the system all weekend, not good….will send it back Monday morning.
    CraigP1017350
    in reply to: S45-2 Woofer Problem #64147
    hcraig244
    SILVER Member
    Just needs to be left as the epoxy hardens, the dust cap glued back in place and posting back home…..I don’t know if there is a better way to do this……
    in reply to: S45-2 Woofer Problem #64143
    hcraig244
    SILVER Member
    The epoxy holding the magnet to the frame now hardened, more epoxy can be applied to the magnet face. The whole assembly is then, with a firm and steady grip….the magnet wants to pull down and sidewards, lowered onto the core held in the vice jaws carefully…..the coil is exposed to damage at this point as the core is guided inside it. With a clunk the magnet will grab the vice jaws which can then be released to allow the backplate to snap into place. The coil now gripped by the off centre core can be viewed through the dust cap apperture as the alignment jig is fitted tightly to the magnet by the bottom row of screws and the top row of screws adjusted up against the backplate and used to centre the backplate and core using the dust cap apperture as a guide until the it looks central and the cone and coil move freely within the magnetic field……
    in reply to: S45-2 Woofer Problem #64140
    hcraig244
    SILVER Member
    The epoxy now dry on the backplate and core it goes back into the vice,  2 or 3mm below the vice jaws
    in reply to: S45-2 Woofer Problem #64136
    hcraig244
    SILVER Member
    Glitch…
    Yes the saucepan is simply a convenient diameter to rest the speaker on during removal of the dust cap and drying time of the epoxy, keeps any pressure off the cone and coil. The process of softening the dust capP1017339 comprises the use of my partners hair dryer providing hot air, this quickly softens the old adhesive which can then be very carefully lifted with a jewellers screwdriver….and in my case the use of a magnifying glass ;¬) takes a bit of patience but is quite straight forward.
    in reply to: S45-2 Woofer Problem #64090
    hcraig244
    SILVER Member
    These don’t need to be dead centre but just thereabouts, the accurate alignment will follow when the backplate and core are offered up to the magnet once everything has hardened off…….and in case anyone was wondering about the last pic it was taken through this magnifying glass, my eyes are not what they once where ;¬)
    in reply to: S45-2 Woofer Problem #64087
    hcraig244
    SILVER Member
    Remove the old adhesive from magnet and backplate, not a lot there so easy task, and having applied some epoxy join them together….
    in reply to: S45-2 Woofer Problem #64084
    hcraig244
    SILVER Member
    Next task is to soften the glue holding the dust cap in place, this needs to come off so I can see what im doing when putting everything back in place and to give me a clue when centering the core inside the coil.
    in reply to: S45-2 Woofer Problem #64082
    hcraig244
    SILVER Member
    Michael….thank you for those kind words ;¬)
    Cleaned up the core and backplate and applied apoxy last night….dried out nicely.
    in reply to: S45-2 Woofer Problem #64046
    hcraig244
    SILVER Member
    All apart and ready for cleaning up prior to fresh epoxy, the coil still reading an encouraging 3.7 ohms….
