Forum Replies Created
carolpa
BRONZE MemberI actually had a technician from B&O do the setup. Really expensive, and he had did not connect the speakers to the BV.
The cable from the BL3500 upstairs is spliced with the Masterlink that goes into the T1611. The other end of that Masterlink goes in the BV7.
I was wrong about the other two linkrooms downstairs; the kitchen and bedroom are spliced together and go in the MCL sockets in the Beomaster. So not speaker 2.
I am not sure what you mean by “Data en Powerlink”.
Powerlink: is the connection from Audio or Vidiomasters to send audio signals (left and right in the same cable) with (opptional) communication info to the amplifiers of the active B&o speakers; Beolab (8pin plugs). The way you connected your Penta’s to the BV7.
Datalink: is the connection including communication, between sources such as CD players, record players, etc and Beomasters/Beosound; but also direct connection between Beomaster/Beosound and Beovision (7pin plugs). The way the Beogram 7000 or Beogram CD 7000 is connected to a Beomaster 7000 for example.The MCL socket should be the same as the Speaker 2 connections of the Beomaster 7000. Could you indicate were they are connected?
The T1611 is also connected to your BM7000 I presume? How is it connected?
There are no speakers connected to your Beomaster 7000 (just to be sure)?
carolpa
BRONZE MemberHi Joris, see maybe this thread: https://archivedforum2.beoworld.org/forums/t/46773.aspx
I am sure there are more threads that you can find by hard googling :-). Using a tag editor can help you out. Album cover images should not be too large.
Let us know your progress!
Regards,
Johan
Niet te groot = max. 1000*1000 pix
carolpa
BRONZE MemberYes, Beolink room 1 upstairs: BL3500 Masterlink is parallel connected to the BV7 via the T1611.
Downstairs kitchen: Beovox Cona and Beovox CX50 with MCL2A-IR.
Downstairs bedroom: Beolab 4500, with MCL2A-IR.
Those two units are also connected to the T1611 in a splice box.
In the bedroom, I alsop have a light control that does not respond to the remote, but only to touch.
At the moment, I have the loudspeaker DIN-cables connected to the PowerLink sockets on the BV7, and the sound from the BV7 is good. On the right side of the BV7 (seen from behind) there is a block of six DIN sockets. Two of those, the topmost right and the bottom right, are for speakers, but I am not sure how to use those.
Let me just clarify that the Pentas are the only loudspeakers in the living room; there is no center speaker on the BV7.
How are the MCL connected to the T1611? If you try to connect MCL directly to ML then for sure you will end up in problems.
The T1611 is designed to connect non-ML Audio or Videomasters to a ML Video or Audiomaster. So in your setup to connect a BM7000 (non ML Audiomaster) to the BV7 (ML Videomaster).To my knowledge your set up should be:
BV7 – ML connected to T1611 – Data en Powerlink connected to your BM7000
BL3500 is parallel ML connected to the BV7
Both MCL2A’s are parallel connected to speaker 2 of your BM7000 carolpa
BRONZE Memberv. 7.0.1 repairs some of the problemsBut Apple doesn’t send an update notice (until now), so without first deleting the app (then setting my iPhone off/on) and reinstalling the app, the original v 7.0.0 was active!Note: the DLNA music server was instantaniously found.Edit: I still encouter problems with playing complete albums! The app now shows on a regular base: not abble to add to playlist for non Mozart devices. carolpa
BRONZE MemberYour system:
Living: BV7 (Beolab’s connected to the BV7) – MasterLink connected to a T1611 (the black box) – Powerlink and Datalink (TV-Aux) connected to your BM7000? correct
Beolink room 1: BL3500 Masterlink parallel connected to the BV7? correct?
Beolink room 2: ????? what is connected here and how is it connected?
Please elaborate……
carolpa
BRONZE MemberJmen wrote:
It also was necessary to re-add my Home Media server to all IOS devices after the v7.0.0 “update”.
Not sure why there is so little effort made regarding DNLA integration. Happy to hear of any solutions found for any of the above
Ah, interesting I’ve been fighting with the B&O App for a few days now trying to get it to pick up my MinimServer which worked in the past when I was using Android phone but switched to the Apple echo system, but never came around to config the home server options until now.So are B&O ditching DLNA support in general or is it just early version bugs that we’re seeing with v7.0.0 of the app?
the trick to get Minimserver back on track is:
- delete the server (if present)
- restart the B&o app
- Now Tidal is shown instead; choose the settings icon
- choose HomeMedia
- Add new
- then restart Minimserver (on another device) and Minimserver will show up
- select the + to add Minimserver
And you will notice that the B&o app is missing some features
So, no possibility to start a whole album…..No, way to add something to a que……. carolpa
BRONZE MemberHighlights:
Beovision: AV9000 – superb picture at the time and a amazing sound wrapped up in the ultimate design
Beosound: I love the design of the 90th such as the Beosystem 4500 and 6500. The sound is great and I learned a lot about the multiroom capabilities with these systems.
the most iconic B&o music design for me is the Beosound Shape though.
Beolab: the 5’s
Multiroom: Netlink – no masters no slaves. All can be extended and mixed….. even old and new
edit:
I almost forgot – the Beogram 4000 family timelessly designed
carolpa
BRONZE MemberHello, I just received from support Bang&Olufsen that this is not possible. The tablestand and wallbracket seem to be different.
greetz, Jos
They look almost the same, but the weight difference in enormously because you need some contra weight to balance the BS5 standing free.
the wallbracket is made of plastic, the table stand of metal. carolpa
BRONZE Member1. BV7 and BM7000 in same room no speakers connected to BM7000. Then BV7 in option 2; BM7000 in option 0.
connection: BV7 – ML connection to T1611 – DL & PL connection to BM7000
2. BV7 and BM7000 in two rooms Beolabs connected to the BM7000
Both set to option 2
connection: BV7 – ML connection to T1611 – DL connection to BM7000
make connections without any B&O connected to the mains, then connect everything to the mains but be sure the T1611 must be done as the last
carolpa
BRONZE Membercarolpa wrote:
Today I did some work on my NL and noticed that the secondary linked products do work again!
I linked Beosystem 7000 and Beosound 3000 to one Beosound Shape. The cd3000, bg6000 (a.aux of the 3000), cd7000, ph7000 & tp7000 are sources off the Shape.
Assuming you have the BS Core with the Shape, I do not quite know what you mean.The sources from my linked (ML -> NL) BM/CD 6500 have been there all the time – I haven’t noticed any changes.
This – as an example – is with one of my M3’s:
What is bothering me, is that they still haven’t made it possible to link a ML source to the products on the Mozart platform (in my case the BS Theatre)
The ‘Join workaround’ of course is possible there.
But it would be nicer, if one could choose e.g. the CD6500 directly from the Beoremote – especially since the Theatre setup is my main room for listening to CD’s.
MMthe BS3000 and BS7000 BLC both connected to the same Shape (Beosound Core) as primary and secundary beolink. carolpa
BRONZE MemberWhat sort of TV do you have? And what is the connection between TV and BM7000? Check that the cables are all fully inserted.
Assuming that TV and BM7000 are correctly connected, and the Pentas are connected to the TV, then the TV should be in V.OPT 2 and the BM7000 in A.OPT 0.
Using the BL1000, in the main room, with the system at stand-by:
Press SOUND then 0 then STORE (to put the BM7000 in A.OPT 0)
Press PICTURE then 0 then STORE (to put the TV in V.OPT 2)
Slip of the pen, you mean:
PICTURE 2 STORE
carolpa
BRONZE MemberWhy not keep the 9’s as is and add the 8’s as heights/WiSA…..I am sure, you won’t regret that.
So true!
carolpa
BRONZE MemberWhat I understand:
If Wisa connected, you should still be able to use the BL8 independably from the Theatre (when the Theatre is not playing something).If they are DPL connected this is not possible anymore.
So it all depend how you want to use your setup.
carolpa
BRONZE MemberI have all types of B&o remotes, from Beomaster 6000 Commander to Beoremote Halo and almost everthing in between.
Only special ones, for example the Beolink 7000, had some kind of “back light”.
So the issue of finding a button is as old as the B&o remotes. And Yes, one seems to be easier to handle in the dark than the other!Since I got a Demo Beoremote One (IR version) before the official introduction, I’m prefer this remote.
I learned quite quickly, even in the dark, to find the right buttons. Now I owe and use on a daily base several ones. I hardly use any Beo4 anymore, sometimes I use one of the Beolink 1000 family though (because some commands are so simple to execute).Until now none of my BR1’s have had any technical issue.
carolpa
BRONZE Memberdid anybody try to use a fixed IP address for the BS Core?
without fixed IP address: what happens if the router’s lease time for an IP address is extended to for example 1 week
if WiFi-connected: try to push the Core to the 2.4GHz and to a fixed channel (f.e. 11)
2 August 2025 at 09:38 in reply to: Beolink NL\ML with Beosound 9000(with system diagram)…please help if you can! #68158 carolpa
BRONZE Member- I asume that Networklink and Ethernet are on the same network/domain (black and green in your drawing).
- Set the BLC (Beolink NL/ML converter) as “VMaster” (or ASlave; Configuration-Settings). Note: don’t to forget SAVE after every change made!
- Tick the box of the “CD” on the page “Configuration-Experience mapped to NL” (note: here you can change the name from “CD” to f.e. “cd9000” also)
- Set the Core in your Office: in the B&o app select the Core; select “Settings”; on the “Product settings” page select “Configure”; select “Beolink”; select “Link to other Products”; in the primary selectbox select the BLC; hit the “Connect” button.
- Now goto “Your Content” (somewhat higher in the list) and select “sources”; select “in local list”; check the boxes of the sources for this Core (be sure the cd9000 is slected); click “Save”.
- Now the cd9000 source should be available as source of the Core (see your Halo) and can be joined by other NL products.
carolpa
BRONZE MemberI needed to search the message option as well. If it’s gone ok you should have an private message now.
I did send you a reply. Regards
carolpa
BRONZE MemberSome Beosound Shape covers cause some change of plans. All items are NEW in original box, never installed. Just out of the box to see the color. Just -40% of the new price. Excl shipment, EU only.
– 3 sets of Dampers, €225 per set
– 3 sets cover Braz. Clay, €150 per set
– 1 set no fabric, €150 per set
– 1 Wild Dove cover, €75
– 1 set Pink Kvadrat, €225
– 1 Grey Kvadrat, € 115
– 2 sets Infant. Green, € 150 per set
– 1 Infant Green cover, €75Hallo Mark,
Voor welk bedrag neem je afscheid van alle items.Private Message werkt niet, tenminste zonet niet. Misschien werkt het wel van jouw kant?
groet
carolpa
BRONZE MemberInteresting, which hardware are you running minimserver on? Perhaps for context I need to mention that I am running the applications and the music on a Synology NAS, where the minimserver app is available in the package center. That one did not work for me before. The default media server from Synology does not work well either. Perhaps DSM 7.x has a better version, I am still on DSM 6.x
For the moment and the longest time it is running on Windows. But some years ago it did run on MacOS and I did some testing with Linux (Raspberry Pi) in the past.
carolpa
BRONZE MemberAnd minimserver also does not work
I disagree!
I use Minimserver for several years now. It is seen by all my B&o and yes, also by my Beosound 5 Encore.Plex I rejected in the past as music server. So I have no knowledge anymore about the correct settings.
EDIT: Does the “DLNA default protocol info” contain music protocols? It shows (but the box is short….) only video protocols. -
