Forum Replies Created
1 August 2026 at 13:59 in reply to: Apple TV remote wakes Theatre audio but not LG panel – Beovision Theatre LG G6 #124796
Brett Collinson
BRONZE MemberSOLVED – I went back and tried Apple TV > LG > Theatre, rather than Apple TV > Theatre > LG and that works just fine. I didn’t need to disconnect the Theatre<>LG LAN, so the Beoremote works if I need to control the TV settings, but for everyday use, I can just and only use the Apple TV Remote, including the correct power-on behavior.
Thanks Bill for the prompt to try this again.
31 July 2026 at 21:33 in reply to: Apple TV remote wakes Theatre audio but not LG panel – Beovision Theatre LG G6 #124776Brett Collinson
BRONZE MemberThanks. I might try it again to see if it works. What I hadn’t done before is disconnect the LAN cable.
One of the reasons I didn’t do with this setup in the past is that I want Apple Music Dolby Atmos sound to play through my Theatre via the Apple TV. Do you know if it will do that if the path is ATV > LG > Theatre?
31 July 2026 at 16:37 in reply to: Apple TV remote wakes Theatre audio but not LG panel – Beovision Theatre LG G6 #124770Brett Collinson
BRONZE MemberATV is connected via Theatre – not LG TV directly. I tried that, but it introduced it’s own problems and I seemed to be fighting against the system.
Lan cable still connected between Theatre and TV.
CEC turned on everywhere.
31 July 2026 at 14:26 in reply to: Apple TV remote wakes Theatre audio but not LG panel – Beovision Theatre LG G6 #124766Brett Collinson
BRONZE MemberHey Bill – thanks for checking in, and good to hear it’s clean on your G4 setup!
Quick update on mine: the audio side works just like you describe – Apple TV remote wakes the Theatre and routes sound no problem.
The holdup is the LG G6 panel itself. Rather than switching to the Apple TV feed, it often wakes showing its own TV volume overlay – so it hasn’t actually picked up the HDMI A trigger at all. I have to manually cycle the source (or grab the Beoremote) to get it onto the right input.
I went back and forth with B&O support on this for a while. Disabling CEC on the Theatre’s HDMI A does fix the source-switching handoff – but it breaks the Apple TV remote’s ability to power the Theatre off. So more of a trade-off than an actual fix.
Their first response was basically “just use the Beoremote One.” I pushed for a technical escalation, but that’s where it’s landed for now – no further movement expected from support.
My best guess is it’s a firmware gap between the Theatre’s LAN integration and the G6 specifically. A few of B&O’s own documented setup steps (Auto Device Detection, for one) don’t even exist anymore on current webOS.
Also – no CEC blocker box on my install, so that’s not the variable for me.
Will update here if anything changes!
10 May 2026 at 20:52 in reply to: Apple TV remote wakes Theatre audio but not LG panel – Beovision Theatre LG G6 #123533Brett Collinson
BRONZE MemberWhy not just use the Beoremote?
With the Apple TV being my only input source, the Apple TV Siri Remote is perfectly suited to the job. All the buttons are relevant (as compared to the Beoremote where the vast majority of buttons aren’t needed) and it has a scroll wheel and track surface for navigating menus and playback controls – which are more useful for those jobs than the standard Beoremote buttons (even those the Beoremote itself is a beautiful object).
10 May 2026 at 17:22 in reply to: Apple TV remote wakes Theatre audio but not LG panel – Beovision Theatre LG G6 #123530Brett Collinson
BRONZE MemberIt feels like I should be able to make this work via B&O’s suggested connection setup.
Here are more precise details of my setup and behavior as I’ve tested it more…
<b>Core Issue:</b>* New Beosound Theatre & LG G6* Only input is Apple TV* Turning on TV with Apple TV Remote doesn’t activate Apple TV connection properly<b> </b><b>Setup</b>* Beosound Theatre – running latest software: 6.1.0.17* LG G6 – running latest software: 43.10.69 (2026-05-08)* B&O app on iPad – running latest version: 7.5.1* Apple TV – running latest version: 26.4<b>Connections</b>* B&O & LG integration: LAN cable connected, eARC HDMI connected to HDMI 2 on TV* B&O app running on TV* Apple TV HDMI connected to HDMI A on Theatre* SimpLink (LG’s HDMI-CEC implementation) activated, and CEC enabled on HDMI A source in B&O app* No other input sources on Theatre or TV<b>First Time Experience → Ideal</b>* Theatre restart from B&O App (via Troubleshooting menu)* Turn on via Apple TV Remote* Theatre and TV wake from standby* TV displays brief HDMI 2 Loading screen* Apple TV shown<b>Subsequent Experience using Beoremote One</b>* Turn off via Apple TV Remote or Beoremote One* Turn on via Beoremote One and using HDMI A source* Theatre and TV wake from standby* No HDMI 2 Loading screen* Apple TV shown, but it takes considerably longer to appear from the blank screen than during the First Time Experience<b>Desired: Subsequent Experience using Apple TV Remote</b>* Turn off via Apple TV Remote or Beoremote One* Turn on via Apple TV Remote* Theatre and TV wake from standby* Nothing is shown on screen* If I press Settings button on Beoremote One or any button on LG remote, Apple TV shown→ Problem: Can’t just use Apple TV Remote to start TV<b>Other things I’ve tried:</b>* Reset TV to Initial Setting – no different to First Time Experience and then Subsequent Experience* Turning on and off various Quick Start+ and Always Ready settings on TVMy B&O Icons:
