Home › Forums › Product Discussion & Questions › BeoSound › Theatre › New product launch – beosound theatre?
- This topic has 1,346 replies, 114 voices, and was last updated 1 year, 3 months ago by
sven-inge.neij.
21 November 2022 at 17:04 #37662
Beo911
BRONZE MemberThere was also an update for BL90 yesterday.
21 November 2022 at 17:13 #37663NQVHNWI
I’m still stuck on v3.1.0.1187 (april 22). What V. are you now showing?
21 November 2022 at 19:54 #37664Beo911
BRONZE MemberThe version from 03/22 was v0.23.699
The latest version says v3.1.0 and was rolled out yesterday. If you have your settings on auto-update, you should have the same version.
21 November 2022 at 19:58 #37665NQVHNWI
BRONZE MemberThanks for confirming. Yes I’m on auto update but v3.1.0 as far as I can ascertain is from April this year.
I may be wrong on this but I think
3.1.0 = BL90 firmware
v0.23.699 = BeoApp control??
21 November 2022 at 19:59 #37666355f
BRONZE MemberMy Theatre arrived today following a problematic eclipse that B&O was good enough to resolve.
First problem is that the visa mount for the 55 does not fit the LG G1 maybe LG changed the locating screws for the G2?? panel; its to short, missing the top location studs, so the guys fabricated a metal insert to allow the top screws to locate.
Setting up was seamless enough but when doing so to change the stand position it asks to re- calibrate via the mic all over again and wont allow anything else?
The app is not that intuitive but i suppose i will get used too it
The motorised stand now has one operating plane; not two as in the eclipse, this means the tv stays away from the wall by quite some distance, meaning its eal life movement is not that much.
I exchanged for this product as i did not want to get caught with another out of date beovision after only 6 months.
Sound wise, its very good; although im really not getting the ‘surround experience’ in appropriate films at all.
Matched with Lab 28 the soundstage opens up; i would not be happy with just the theatre for that reason alone as for B&O suggesting a sound ‘triangle’ with lab 28 at the rear; it would not work for me,one is to aware of the sound being ‘in front’ and the app is quirky and keeps stating its ‘offline’
21 November 2022 at 22:03 #37667Beo911
BRONZE MemberThanks for confirming. Yes I’m on auto update but v3.1.0 as far as I can ascertain is from April this year. I may be wrong on this but I think 3.1.0 = BL90 firmware v0.23.699 = BeoApp
This is what i get:
1. Latest SW version BL90
2. Previous SW version BL90
3. Latest SW version Beo-App
22 November 2022 at 10:37 #37668Themanthemyth
BRONZE MemberSo as a standalone it’s not anything special?
22 November 2022 at 10:56 #37669Sandyb
BRONZE Member~Certainly more capable as a stand alone than a stand alone Eclipse / Harmony.
For those who added extra speakers to their previous BV’s, then you’d probably want to still add extra speakers to a Theatre. The difference with the Theatre is that you first additional extra speakers may be just rear speakers – as opposed to a first addition being front L/R with previous BV’s.
22 November 2022 at 11:00 #37670Themanthemyth
BRONZE MemberMy question is if it’s worth it as a standalone all in one atmos system. From the reviews the Atmos from the Theatre hasn’t been as impressive as the Sennheiser Ambeo. It sounds like it catters more to people with Beolab speakers.
22 November 2022 at 11:05 #37671NQVHNWI
Indeed. The BSTH blows the Eclipse out of the water. In the 4-5years I had one, I had the soundbar muted and relied on phantom BL90 and the BL3.
As a side note, and thinking how the BSTH manages sound distribution, I think there is a good case for B&O to refresh the BL14 concept (but without the sub) i.e. a very small discrete loudspeaker set for added spatial/ATMOS ambience without dominating the viewing room more than it may already be?
Hopefully B&O are paying attention?
22 November 2022 at 11:31 #37672NQVHNWI
Honestly, I think it is the usual story – price. These magazines want everything super-cheap and offer a subjective justification in their own way. Sennheisers advertising revenue has to be justified.
B&O has always been a lot more expensive but always comes with added extras. Think Beovisions with PUC, motorised stand and a Surround Processor compared to well…a TV panel, internal speakers on a plastic stand with a plastic remote? There is no real comparison or off-set for the added value.
The BSTH brings a lot of the typical fully-loaded Beovision features with the ability to recycle panels often. This also includes adding or re-tasking Beolabs to the system. It keeps legacy systems alive for a lot of us. Frankly – and perhaps most can determine from my rampant comments of the forum recently, I am greatly relieved for the BSTH. I was greatly concerned as to what was going to replace the Eclipse. Harmony is not may favourite design and way way too expensive for the frill of rotating screen loudspeakers. The Stage and Contour are to me, Beovision dead-ends in so far as product integration.
With the BSTH, I can also see my financial exposure to Beovisions reduce from circa +£10k every 5 year replacement (~£2k/year, may be more if parts run-out quickly – i.e. Gen1 Eclipse) to one where replacing the screen only could significantly reduce that overhead to less than £400k/yr.
People ultimately have a choice. Go buy the Sennheiser Ambeo if you feel it is “better”? As a standalone, it may well be better for you and your needs but don’t pretend these “written” reviews are in anyway objective. Most of them – including those who have done the BSTH as well as other Soundbars are Chancers with a GoPro and a mic putting out an opinion sitting in a shop.
For me, I’ve re-discovered B&O Video and I’m happy that my long-standing investments are still relevant for some time to come.
10
22 November 2022 at 12:37 #37673beojeff
BRONZE MemberAfter yesterday’s Beosound Theatre firmware update, Home Control is now available! Home Control shows up on the Beoremote One LIST and gives us the Home Control screen on the TV. I really didn’t expect B&O to give us that feature. Nice. However, the LIGHT and CONTROL list commands still do not send commands to the BLI.
Yesterday, my dealer confirmed that there is indeed a problem adding WISA (at least via Receiver 1) speakers to the listening positions. He advised that B&O is aware of the issue and should have an update to fix it very soon. Could anyone using wireless speakers describe what happens when you add the speakers? Does the app crash after scanning for wireless speakers? For me, running a scan for wireless speakers crashes the app, but when I restart the app the wireless speakers are shown as added. However, I have no option to tell the Theatre what type of beolabs are connected to the Receiver 1. After running Room Sense, the wireless speakers are greyed out and cannot be added to the speaker group.
22 November 2022 at 13:53 #37674DHA
My soundbar history before the Theatre was the, then top of their range, Sony HT-ST5000. It replaced a cheaper 5.1 surround system that would not work in the new room we were building as the layout does not lend to cables and speakers sat around the seating positions so I went down the soundbar route. The Sony worked well, when it worked, and provided good surround effects in the majority of viewing. Atmos I will cover shortly. But the bar was plagued with software issues from day one (reboots when powered down, an error during atmos soundtracks that made it emit a loud piercing noise that happened at random so Sony couldn’t care much about it).
It is approaching 6 years old and the software issues are becoming more regular so I looked for a new soundbar. The Ambeo was on the list but the reviews were mixed in a few places and viewing it in store I didn’t totally like the looks. The Theatre to me looked and sounded great so that is the road I went down.
I’m using it stand alone at present. It produces a lot “cleaner” sound than the Sony. Voices are much easier to hear in both TV and the limited film clips I have watched since getting it over the weekend. The Sony added lots of bass to everything when I think how the sound of both systems compare (Sony had a wireless sub as part of the setup) for example watching masterchef last night the dialogue sounded a lot less bassy on the Theatre. But the Theatre does have bass, I think it just applies it a lot more correctly rather than with everything if that makes sense?
On the Atmos front. I have been using Soundbar based Atmos for nigh on 6 years. It is VERY dependent on the mix provided. Sky did it well on the live football, it sounded similar to the stadium noise you would hear. Movies really really vary, some do it well but most you are probably only getting something close to a 5.1 listening experience and won’t have a full atmos type effect. But with the “right” atmos sequence the bar does very well and is quite enveloping but you still pick out the smaller sound details (way way above what the Sony it replaced could do).
22 November 2022 at 13:55 #37675DHA
BRONZE MemberAs an aside I am wonder if the hiss/white noise I am experiencing is due to the power cable. It didn’t seat that well in the port when I set it up, took effort to put it in place but didn’t feel that secure. I might try another cable to see if that resolves the issue.
The shop is looking at the on-board diagnostics to see if they can see any issues
22 November 2022 at 14:24 #37676NQVHNWI
BRONZE MemberAs an aside I am wonder if the hiss/white noise I am experiencing is due to the power cable. It didn’t seat that well in the port when I set it up, took effort to put it in place but didn’t feel that secure. I might try another cable to see if that resolves the issue. The shop is looking at the on-board diagnostics to see if they can see any issues
I dont think seating it will cause a hiss? If the BSTH is completely standalone and does not have a TV panel hard-mounted to it, and can you can disconnect, pick it up and place it on a power socket away from your current supply – particularly one on a different breaker if you can – that should identify if the BSTH is faulty or not?
22 November 2022 at 15:03 #37677JK217
BRONZE MemberNew user here, and sorry if I’m asking anything out of order here. I’ve been looking at ways to improve my aging system and have been thinking about a complete overhaul. I currently have a Sony Bravia, with a Pioneer Elite AVR 5.1 system. Nothing about my system is easy, the ARC to the receiver often powers it down, when the tv powers on, and the selection of inputs, along with the slow google OS on the tv, makes it impossible for my wife to even turn on the tv when I am not there. So I want to simplify, but not necessarily lose a ton in sound quality. I’m in a converted warehouse loft space with 16ft ceilings and a pretty open living space. Just trying to provide as much flavor as possible.
My wife will be on board with this if it’s easy to turn on, and select cable or streaming, with one remote, and she really likes the appeal of no wires. We use AppleTV, and our cable box as the two main input sources. I guess, I’ll have to travel to a dealer to be able to see/hear in person, but the specs seem like it’s powerful enough to put out enough sound.
I’m hung up on adding rear surrounds. I believe I am reading it correctly, that if I want to add two wireless speakers, the only wireless standard supported is WISA, and am I correct that when I look at B&O’s product offering on their website, for a wireless rear surround option, the BeoLab 18’s are the least expensive option at $11k per speaker? None of the Beosound series of speakers will function wirelessly on the WISA standard? Will any of the Beosound series work via power link in a wired application?
Reading this thread, it seems like many of you have extra legacy speakers ready to be called into service as surrounds, but if, like me, you are building from scratch it seems a little daunting.
I owe it to myself to get to an actual dealer, to ask a lot of the same, but until then, appreciate the insights provided here.
22 November 2022 at 15:30 #37678Sandyb
BRONZE MemberBl18s yes, after the cheaper BL17s were discontinued a couple of years ago. That said, they are available used, which is what I have done, and will use them wirelessly / WISA with my Theatre.
Older BL speakers can be used WISA, though a B&O transmitter / receiver needs to be added to the chain. Definitely some on this forum who have done this, rather than shell out for new WISA capable Beolabs.
22 November 2022 at 16:04 #37679355f
BRONZE MemberI completely agree with Mr 10% if you have the eclipse mk1 , when the panel packs up its scrap.
I purchased the MK2 as my now defunct dealer told me it was ‘futureproofed’ as the LG panel is seperate, within two months the G2 panel arrived and it wont fit! so the only hope one has for the MK2 is to source a S/H G1.
The Theatre solves the problem; in a way B&O will have to keep this updated as its existence is to offer a solution to all brands.
The sound is better than the eclipse by far, for these reasons alone I am pleased with it.
22 November 2022 at 18:50 #37680 Severed_hand_of_skywalkerBRONZE MemberI believe I am reading it correctly, that if I want to add two wireless speakers, the only wireless standard supported is WISA, and am I correct that when I look at B&O’s product offering on their website, for a wireless rear surround option, the BeoLab 18’s are the least expensive option at $11k per speaker? Will any of the Beosound series work via power link in a wired application?
Yes any old Beosound speakers will work with the theatre through powerlink or you add the wireless transmitter (I wouldn’t use wireless unless you REALLY had to).
I wouldn’t go with BL18’s as rears unless you have a ton of cash as it’s overkill for most rooms. You can get used BL3 or BL4000’s or even a used BL17 for rears and it should work just as well (again depends on how big the room is).
I also moved from an ARC receiver to the Theatre and it’s very seamless to use and switch inputs. It’s all not as daunting as it sounds.
22 November 2022 at 18:56 #37681beojeff
Yes any old Beosound speakers will work with the theatre through powerlink or you add the wireless transmitter (I wouldn’t use wireless unless you REALLY had to). I wouldn’t go with BL18’s as rears unless you have a ton of cash as it’s overkill for most rooms. You can get used BL3 or BL4000’s or even a used BL17 for rears and it should work just as well (again depends on how big the room is). I also moved from an ARC receiver to the Theatre and it’s very seamless to use and switch inputs. It’s all not as daunting as it sounds.
You’ll see in my recent posts that the Theatre isn’t working with the Receiver 1 right now. However, B&O is working on fixing this.
