Home › Forums › Product Discussion & Questions › BeoCenter › My Beocenter 9500 Restoration
- This topic has 44 replies, 7 voices, and was last updated 2 years, 2 months ago by
Guy.
30 October 2023 at 18:46 #42824
GuyModeratorThe function of the ‘Line In/Out’-plug is also understand – but … is it only a plastic pin which presses the inside contacts together, or an electrical connection – for example a jack plug whose 2 contacts be short-circuited ? –> I’m looking for alternative if I dont can get such original plug.
It’s an electrical connection within the plug – here’s a blurry photo of mine:
If using a standard DIN plug, connect pins 1 to 3, and 4 to 5 as you can (just) see below.
30 October 2023 at 20:02 #42825 BodoBRONZE MemberThank you, Guy !
Connected two by two. OK .
Yes – trying a DIN-Plug without the middle pin (3).31 October 2023 at 10:12 #42826 BodoBRONZE MemberHey Guy.
Got it ! But the activation dont works with the Remote Control. Perhaps the reason is, that it is the BC9000 – not the BC9500. Finaly i use the main-panel and there the following steps: ‘programm – call – clear’. And now it works.
Thank you for help. You give me an idea how to work.
31 October 2023 at 10:34 #42827 GuyModeratorI see. Early versions of the BC9000 did not have the ability to set A.OPT 0, so that would not have been the problem. I think Option setting is a bit strange on the BC9000.
If the remote control is now working that’s good news.
13 January 2024 at 15:49 #42828 GuyModeratorBeoCenter 9000/9500 owners may wish to be aware that an eBay seller is offering a few door repair kits (both new and removed from working units) like the kit I referred to back here.
I ‘look after’ two BC9500s, hence have just purchased a new door repair kit in anticipation of future problems.
Here’s the link (search his other items for the cheaper ‘second hand’ kits also available): https://www.ebay.co.uk/itm/166490397618
(I have no affiliation with the Seller, but have purchased several items in the past).
