Home › Forums › BeoWorld around the world! › Deutsche › Beovision 10-32
- This topic has 2 replies, 2 voices, and was last updated 25 minutes ago by
Nick_T.
23 July 2026 at 16:43 #124642
Nick_T
BRONZE MemberHallo zusammen,
ich möchte meinen 10-32 (original auf Motorstandfuss) an der Wand montieren.
Wer kann mir helfen und sagen welche Wallbracket passt? Ich weiß dass einen 6-22 Wallbracket zu schmal ist, und gehe stark davon aus 7-40 zu breit. TV muss nicht bewegt werden.Ich würde mehr sehr freuen euer Tipps zu lesen.
Liebe Grüße aus München
Signature: Beosound 4
Beolab 4000
Beoplay V1-40
Beovision 10-32
Beovision 14-40
And god knows what else….My B&O Icons:
23 July 2026 at 20:24 #124644 GuyModeratorSorry for reply in English!
You could use a BV6-26 or 7-32 wall mount, but be aware that the bracket orientation is different – see here: https://forum.beoworld.org/forums/reply/60350/
… and I am not sure that the wall mounting is designed to hold such a heavy TV.
I would try to find the proper BV10-32 wall mount – known as ‘Wall bracket – close, type 4708’. Or you could buy STB’s equivalent: https://www.stbbrackets.co.uk/product/wall-bracket-for-gypsum-and-dry-lined-walls/
Or you could try fixing the metal plate from your current stand onto the wall (drill new holes) and slide the TV on from above. I think someone from the forum has tried this successfully.
This reply was modified 1 hour, 23 minutes ago by
Guy.
23 July 2026 at 21:24 #124646Nick_T
BRONZE MemberThe idea with drilling holes in the base plate is my favorite-would give a nice flush mount. The easiest probably to do would be to find a 7-32 wall bracket- I’ve got my dealer searching for one in his treasure chest.
The STB seems a bit expensive for what it is.
Thank you so much for your concise reply. It is very much appreciated.Location: Munich, Germany
Beolab 4000
Beoplay V1-40
Beovision 10-32
Beovision 14-40
