Home › Forums › BeoWorld around the world! › Deutsche › Beovision 10-32
  • #124642
    Nick_T
    Hallo zusammen,
    ich möchte meinen 10-32 (original auf Motorstandfuss) an der Wand montieren.
    Wer kann mir helfen und sagen welche Wallbracket passt? Ich weiß dass  einen 6-22 Wallbracket zu schmal ist, und gehe stark davon aus 7-40 zu breit. TV muss nicht bewegt werden.
    Ich würde mehr sehr freuen euer Tipps zu lesen.
    Liebe Grüße aus München
    Signature: Beosound 4
    Beolab 4000
    Beoplay V1-40
    Beovision 10-32
    Beovision 14-40
    And god knows what else….
    Guy
    Sorry for reply in English!
    You could use a BV6-26 or 7-32 wall mount, but be aware that the bracket orientation is different – see here:  https://forum.beoworld.org/forums/reply/60350/
    … and I am not sure that the wall mounting is designed to hold such a heavy TV.
    I would try to find the proper BV10-32 wall mount – known as ‘Wall bracket – close, type 4708’.  Or you could buy STB’s equivalent: https://www.stbbrackets.co.uk/product/wall-bracket-for-gypsum-and-dry-lined-walls/
    Or you could try fixing the metal plate from your current stand onto the wall (drill new holes) and slide the TV on from above.  I think someone from the forum has tried this successfully.
    • This reply was modified 2 months, 4 weeks ago by Guy.
    Nick_T
    The idea with drilling holes in the base plate is my favorite-would give a nice flush mount. The easiest probably to do would be to find a 7-32 wall bracket- I’ve got my dealer searching for one in his treasure chest.
    The STB seems a bit expensive for what it is.
    Thank you so much for your concise reply. It is very much appreciated.
    Beolab 4000
    Beoplay V1-40
    Beovision 10-32
    Beovision 14-40
