Home › Forums › Product Discussion & Questions › Other › Making a short conversion lead for use with Beovision tv’s › Reply To: Making a short conversion lead for use with Beovision tv’s
#60350
Guy
Hi Tony,
I have just answered your PM and attached this from the BV6 manual: (I think you already have the 8-pin connection list?)
stand
But have you considered buying a purpose built lead from here?  https://shop.oneremote.dk/shop/69053-oneremote/4172-tv-stand-converter-snut/
I know from experience that the BV10-32 will fit onto the BV7-32 stand, but there is a problem with the geometry of the stand components versus the Centre of Gravity of the BV10-32.
Here’s a side view of the BV7 stand:
IMG_5544
And a side view of the proper BV10-32 stand:
IMG_5552
When you put a BV10 on the BV7 stand, the TV drops all the way downwards and tilts fully upwards due to the orientation of the two (near parallel) cross members.  The different orientation/geometry of the BV10 stand hold the TV (stops it dropping) let allows you to tilt the screen up or down.  The entire mechanism appears stiffer and more controllable.
When I temporarily used a BV7 stand for my BV10-32, I wedged a rectangular piece of rubber in the gap between the supports to stop the TV dropping downwards.
