Home › Forums › Product Discussion & Questions › BeoLink › Beolink Active 1636 PC Input
- This topic has 44 replies, 6 voices, and was last updated 2 years, 3 months ago by
Madskp.
16 December 2023 at 16:13 #43140
Guy
ModeratorOne other thing that intrigues me is that some OneRemote documentation implies that the BL Active can be used stand-alone with the OneRemote radio as an input – look at the ‘tip’ in the diagram below: I wonder if the adaptor cable does something funny to make stand-alone operation possible?
I contacted OneRemote about stand-alone use of the BL Active as shown in the diagram on my earlier post. Here’s their response:
We know for certain that it works in at least some installations with an open-end ML socket.
When I got your question none of us was really certain, so we tried it in our lab. The guide was written many years ago. The test showed that it did not work until we connected Beolink Active to a Masterlink source.
So, the answer is that sometimes it works.
Our test Beolink Active has firmware 1.1 and this does not work.My BL Active is SW1.1 also. Leaving aside connection of a OneRemote source, it could be worth trying a later SW BL Active (1.3 or 1.5?) to see if that works stand-alone with a source to the PC input – anyone able to do so?
EDIT: @madskp I just read back through the thread and saw that you were going to give it a try with SW1.6 – this may have been lost in the noise with the other ongoing experiments …
16 December 2023 at 16:29 #43141Madskp
GOLD MemberGreat with an answer from Oneremote, even though its not a clear answer.My BL Active is SW1.1 also. Leaving aside connection of a OneRemote source, it could be worth trying a later SW BL Active (1.3 or 1.5?) to see if that works stand-alone with a source to the PC input – anyone able to do so?
my recent testings in this thread was with a BL Active SW 1.6, and that does not operate stand alone.
There could of course have been a version in between that was working differently.
16 December 2023 at 16:32 #43142 Guy
ModeratorMany thanks – I missed that (and was typing my edit as you posted above!)
I am dubious that any version of Active worked stand-alone, but yes it was good of OneRemote to answer.
16 December 2023 at 16:43 #43143 Guy
ModeratorAn observation: If you disconnect the ML cable after initiating the BL Active with PC, the source will continue to play and you can adjust volume using remote or IR puck buttons, but you cannot turn off using either remote or buttons.
16 December 2023 at 16:59 #43144Madskp
GOLD MemberAn observation: If you disconnect the ML cable after initiating the BL Active with PC, the source will continue to play and you can adjust volume using remote or IR puck buttons, but you cannot turn off using either remote or buttons.
Interesting observation. Maybe it’s only source selection and standby that needs Masterlink to work since volume control keeps working
