Home › Forums › Product Discussion & Questions › BeoLab › BL3500 and the MCL/PL connector › Reply To: BL3500 and the MCL/PL connector
#125210
Madskp
GOLD Member
That brings me to one more use case.
If I connect the MK2 version of this project between a Powerlink source and the BL3500, and PIN 4 (5 V+) is enough to power the ESP32, I can transform a BL3500 into a normal Powerlink speaker. just send the init sequence to BL3500 when ESP32 boot. (and it boots every time Pin4 gets +5v 🙂 will test it soon
That could be usefull for some pepople. There have from time to time been questions on the forum on how to use the BL3500 as a center speaker for a TV where that solution could be used
