Home › Forums › Product Discussion & Questions › BeoLab › BL3500 and the MCL/PL connector › Reply To: BL3500 and the MCL/PL connector
#125207
swo
GOLD Member
Madskp wrote:
Just to clarify from my own and other peoples testing the BL3500 MK II  can only work as a normal Powerlink speaker when used with a Beolink Wireless 1 which send the correct signal to wake it up. I have not been successful at getting the BL3500 MK II going with other Powerlink sources.
That brings me to one more use case.
If I connect the MK2 version of this project between a Powerlink source and the BL3500, and PIN 4 (5 V+) is enough to power the ESP32, I can transform a BL3500 into a normal Powerlink speaker. just send the init sequence to BL3500 when ESP32 boot. (and it boots every time Pin4 gets +5v 🙂 will test it soon
  • This reply was modified 1 month, 2 weeks ago by swo.
