Territorial_
Forum Replies Created
Viewing 9 posts - 1 through 9 (of 9 total)
  • Territorial_
    Hi Mads, yes, I’m still making and selling the adapters. At the moment I’ve had some difficulty finding time for the project since I’m building a house. I believe I still have one ready in stock, if I remember correctly.
    Territorial_
    I was thinking about the pricing of 140€ for the adapter, wires and weight + cartridge + shipping
    You can pick the cartridge type you want from the Ortofon website.
    OM Series
    So for example, with
    OM 5S 185€+Shipping
    OM 5E 195€+Shipping
    Super OM 5E 225€ + Shipping
    For the price its plug and play kit. includes everything.
    I have adapters ready but it takes about 5 days to receive the cartridge after I know which type you’re interested in.
    Territorial_
    I’m excited to announce that the Ortofon OM cartridge adapter for SP-compatible B&O turntables is now ready!
    This adapter is designed specifically for Ortofon OM5 cartridges and is compatible with models like the Beogram 1202 and 3000. It follows the original specs for geometry and stylus pressure (1.5–2g) while requiring only minimal modifications to your turntable. The design also replicates the original aesthetic, including a transparent stylus holder.
    I’ll be producing a limited batch of around 5 units, so if you’re interested in purchasing one, feel free to send me a message.
    https://vimeo.com/1050185784/64000f2530
    IMG20250124231206IMG20250124222316
    Territorial_
    The painting is complete, and I successfully matched the tonearm’s original color. Now, I need to work on the tip section. Currently, it’s painted in the same aluminum color, but I want it to be transparent.
    We tested printing with clear filament, but the results were slightly cloudy. Next, I’ll try wet-sanding the clear part’s surface and applying a couple of coats of clearcoat. Hopefully, this will achieve the desired result.
    Here’s a quick teaser shot, adapter design vs the original.
    What do you think? Any feedback on design?IMG20241124112325
    Territorial_
    Yes, you understood correctly. I’m designing an adapter that allows Ortofon’s OM series cartridges to be used with B&O’s SP series turntables, specifically models like the 1202 and 3000, and similar ones with an aluminum tonearm. This only requires minimal modifications to the turntable.
    As for the project status, I’ve already tested the first prototypes and confirmed that the mounting and weight adjustments work well. I’m currently refining the final design for the transparent part, ensuring it also provides proper support for the cartridge and the needle assembly.
    Here’s couple quick renders of the product.
    2
    1
    in reply to: SP12 stylus? #60225
    Territorial_
    Check this out and PM me if you’re interested.
    Adapting Ortofon OM-Series for SP Turntables – Small Batch Coming Soon
    in reply to: Beogram 3000 (5228) Plays tricks on me #48281
    Territorial_
    The problem has been successfully resolved. After replacing both the diode(1N4007) and capacitor(2u2 365V -> Replaced with 2u2 450V), the problem has been fixed.  Thank you so much!
    in reply to: Beogram 3000 (5228) Plays tricks on me #48280
    Territorial_
    I try to replace the capacitor first. Does anuone know the exact model of it?
    in reply to: Custom Beogram SP10 Sp12 Sp 14 stylus #34936
    Territorial_
    Oh, i need this! Could you build one for me?
