Forum Replies Created
Stuart50_1
BRONZE MemberHi
Apple music is on the LG panel
Stuart50_1
BRONZE MemberHi
I am finding playing music n the Apple music built in app is not very load , is there a fix please
Stuart50_1
BRONZE MemberHi
Thanks for your help it all sorted thanks
Stuart50_1
BRONZE MemberHelp
I have just reinstated my set up Eclips gen 2 beolab 20 front beolab 9 ,back .
Cannot get the beolab 9 to work on speaker connection set up , they do play with the front speaker but not on their own ?
Hi have just ready that you cannot daisy chain from the front speakers to the back speakers is this correct . It advises using a splitter ?
is this correct or is there a work around Please.
KR Stuart
Stuart50_1
BRONZE MemberHi
This may explain why I have been underwhelmed by the base response on my set up.
There has been a definite lack of base experience in my set up .
thanks for the information if you have any tips on getting the best out of my set up I would appreciate it .
Eclipse 55 mk2 Tv
Beolab 20 front
Beolab 9 Back
I also have a Beosound 5 connected through a ML/convertor which plays through the speakers when I press join ?
Any help would be great .Stuart50_1
BRONZE MemberThanks for your help
Stuart50_1
BRONZE MemberHi
Stuart50_1
BRONZE MemberHi
it’s about what the beo6 can do in the full system.
but you did say in your replya full description of your setup will help – Main room, what is there and how is it all connected. and same for link rooms etc.
Stuart50_1
BRONZE MemberHi
My set up as followsLounge Eclipse Mk 2 55 inc with Beolab 9 back and Beolab 20 front and a sub beolab 2 also Beosound 5 connected to ML/NL convertor.
2nd room Beovision 14 with beolab 3
kitchen Beovision 6 2 hdmi version
bedroom Contour 42 .
not sure I get the best out of it all to be honest , Beovision 6 does not show on nl/ml convertor. Can get Beomaster on Beovision 14 and contour with link control on remote
have to use Join on Beoremote 1 BT to get music from Beomaster 5 in lounge .
also the sound experience in the lounge from the eclipse is poor compared to my old Beovision 10 it used to shake the room it was a fully immersive experience
the eclipse is no where near as good
whta are your thoughts?
any help would be appreciated
Stuart50_1
BRONZE MemberHi all
so why does my beo6 work on link room but does not work on the lounge settings where the Beosound 5 is ?
the link setting works fine ?
not sure why the lounge setting does not work , do you have to option the beo6 ?
if so howany pointers please
