Hi Johan,
Thank you very much for taking the time to look into this, I really appreciate it.
I also hope the 55″ uses the same method.
I’ll have a closer look when I get a chance. For now, I think my best option is probably to find a damaged or faulty BeoVision 7-55 and use the front glass from it.
Thanks as well for the epoxy suggestion. I’ll keep that in mind if I can’t find a replacement screen.
Many thanks again for your help!
Best regards,
Sebastian
