Saint Beogrowler
Forum Replies Created
Viewing 6 posts - 1 through 6 (of 6 total)
  • in reply to: Beogram RX-2 Problem with Play Button #59277
    Saint Beogrowler
    New belt from Beoparts (now: Danish Sound Parts) was the fix for both the RX-2 and 1800.
    in reply to: What are the speakers, b&O lovers use? #41690
    Saint Beogrowler
    I’ve tried quite a few. For years now, the M70 for me is the perfect mix of pleasurable listening experience and critical listening when paired with a classic Beomaster, mostly the BM8000 or the BM6000, the little BM2400 has been in my rotation for the past 6months or so and still the M70s sound great to me.
    in reply to: Beogram 1700 #40640
    Saint Beogrowler
    I’ve always liked these. The brass thing that raises and lowers the arm gets gummed up with old lubricants on these. A good cleaning and new lubricants helps, and setting appropriate tracking force will probably fix all
    in reply to: Beogram 1700 #40639
    Saint Beogrowler
    I’ve alexia’s liked these. The brass
    in reply to: Beomaster 4000 – wicked pop when turning on #35273
    Saint Beogrowler
    Try letting it warm up with the speaker
    switch off for five minutes or more. Even
    after the most thorough of adjustments
    I’ve always had a pop when starting these
    cold.
    New capacitors and work
    are only going to make
    this receivers more delightful.
    in reply to: Beomaster 4000 switch repair #40753
    Saint Beogrowler
    A donor switch panel is what I’ve used. An annoying job but very well worth the time.
