Nils Marsille
Forum Replies Created
  • in reply to: BeoLab 2000 #39130
    Nils Marsille
    Beolab 200 is a link-speaker, so ther is only a ML connection on it.
    But you can buy a adapter cable to have a jack-connector, I boght one to to connect to my PC.
    I little hussy to start it with the Beo4 (key the follwing: MENU-0-9-GO-^-CD-CD), but it works perfectly.
    Hope this give you more to use this robust, quality speaker (I have 4 at home (kitchen, bathroom, office and a spare ..)
    Nils
    in reply to: Beo6 Best Practices #39384
    Nils Marsille
    Thank you so much, keep you update if any!
    in reply to: Beo6 Best Practices #39381
    Nils Marsille
    Hi Beozip,
    Have my Beo6 for battery replacement, but he says there is no support for parametring it etc. is the software “open” to access without a temporary login as the on e the installators used to have? I love to make it work for my installation (i am quircky indusrial designer ;)) so laove to see how it works (never got it setup since i acquired it second hand).
    thank you for all useful tips to get on trail.
    Nils
