Forum Replies Created
mcevedy@mac.com
GOLD MemberI have replied in the other post – I suggest that the previous owner has sent this to be retipped by a firm who have upgraded the cartrisge from what is likely an MMC4 and has put a contact line diamond on it – likely to be very good!
mcevedy@mac.com
GOLD MemberThe original MMC20CL had a sapphire cantilever and a contact line stylus which was the top of the line for the MMC20 range. The MMC1 and 2 had again a sapphire cantilever and a contact line stylus. The cantilever on this example looks to be metal – probably aluminium as the sapphire cantilever is transparent. I would suggest this is something like an MMC4 that has been altered and a contact line stylus put on – I have a MMC20SH on my Beogram 4001 which is a MMC20 S originally but with a better cantilever and a shibata stylus. I wanted a black cartridge to match the black arm and I am less keen on the Soundsmith cartridges – personal taste – they are demonstrably excellent but have a different sound compared to the MMC20 originals.
You must be logged in to view attached files.My B&O Icons:
mcevedy@mac.com
GOLD MemberThe MMC6000 used a diamond tip designed by Subir Pramanik – (an aside, his wife worked at B&O in customer service – spoke to her a few times – a lovely lady). The stylus was a modified Shibata type but with an even smaller contact width. B&O did do a demonstration kit with large styluses showing the different profiles. I have had the SP15, 4000, 5000 and 6000 in my time. The 6000 seems to get deeper into the groove than the others – it was designed along with the 5000 to play CD4 records which used a carrier frequency up to 40k – I did have a 6000 system and a couple of CD4 records – not really a fan. The 6000 was however a superb record cleaner!! I would run a record once without listening and then clean the stylus before playing the record to listen! It would clear dust after what you thought had been a good clean with a record brush! I suspect you likely have a more useful cartridge now. My favourite was always the MMC20CL – I suspect however than most of these cartridges will suffer from hardening of the suspension – I confess to using my record players much less these days as my hearing is nolonger capable of discerning very high frequencies so the esoteric cartridges are wasted upon me!
mcevedy@mac.com
GOLD MemberJe zou Multicare kunnen proberen, wellicht hebben ze nog wat reserveonderdelen, zij zijn de officiële B&O klassiekerreparateur.
mcevedy@mac.com
GOLD MemberMulticare very kindly picked mine up on their way back from Edinburgh. One amplifier had decided not to work and I guess the second one would follow soon. Have replaced them with Beolab 5s but they will be used elsewhere no doubt on their return. Have had them from new and in very nice condition.
mcevedy@mac.com
GOLD MemberMy S45-2s are S/N 1756035 and have Philips tweeters – written on back of tweeters in red print. Just had a look!
mcevedy@mac.com
GOLD MemberEr staat er eentje op eBay, maar die is lang en duur! (excuse my Dutch!) It is in Croatia.
mcevedy@mac.com
GOLD MemberYou are quite correct – containment is definitely answer – however ! The remote that is best for the 9500 is the Beolink 7000! Especially of you have a link room. Just the best remote that B&O ever made.
Had a quiet afternoon so sorted my 9500 system out – added a Beogram 4000 and a Beolab 2 to the Beolab 4000s. Next is to sort out the Beomaster 4401 system – have even found the CD/Tape splitter so can add the CDX!
I confess my least favourite bits of B&O are their modern TVs. Just seem less intuitive that other makes which is so not classic B&O. And the present remotes are too difficult to find one’s way around if low light conditions. Next job is to see how many of the Beolink 1000s and Beo4s are working properly!
mcevedy@mac.com
GOLD MemberDoes it work by itself with the u pins in? Or has it other issues?
mcevedy@mac.com
GOLD MemberMulticare are the official Classic B&O repairer – having seen how they repaired some of my kit, I can only heartily recommend them. You could get them couriered up?
23 January 2025 at 17:33 in reply to: Beomaster 5000 & components (Beogram, Beocord & Beocard CD-5500) #63025mcevedy@mac.com
GOLD MemberHave the manual – the 5000 has the ability to use both DIN plugs (the choice for B&O equipment ) but also has RCA sockets – you could test to see if theamp is working aback attaching another device with a line output into the RCA sockets – you could use something like an Amozon eco dot – you need a mini jack to RCA socket lead into the Tape in sockets. Switch to TP and see if it works. Not an awful lot to go wrong in the Beogram – I take it you can hear it playing the record if you listen closely next to the record – that is the stylus is contacting the record – there is a mute circuit but suggest if not used to fixing stuff to get someone who is to looks at it! Is it a radial BG5000 or the later 5005/5500? I had one of these systems many years ago – worth fixing!
23 January 2025 at 17:08 in reply to: Beomaster 5000 & components (Beogram, Beocord & Beocard CD-5500) #63023mcevedy@mac.com
GOLD MemberThe Beogram will only work if plugged into the correct socket. It should have a 7 pin DIN plug and the different devices are recognised by the Beomaster through a system called Datalink. It therefore knows what is playing and will switch the signal on from the correct socket. Will have a look to see if I have the manual!
23 January 2025 at 16:58 in reply to: After 25 years – My challenges upgrading my B&O Ecosystem #63022mcevedy@mac.com
GOLD MemberYes that is the Cathode Ray Tube Real Flat Avant . Superb set – I gave mine away – mine was the DVD version. Still has a great picture but ‘only’ 32″ and is a large bit of furniture and heavy. The chap I gave mine to wanted it for video gaming as he needed a SCART socket for the console he was using. We have a system called freecycle and one puts an advert up on there and invariably someone comes and gets it! In this case definitely put ‘needs collection’!
mcevedy@mac.com
GOLD MemberI would try some Danish Oil on the wood. My SC80 was not varnished so you might find it is just the wood drying out. A very light sand of the worst bit might be necessary.
21 January 2025 at 11:40 in reply to: After 25 years – My challenges upgrading my B&O Ecosystem #62958mcevedy@mac.com
GOLD MemberNot sure which thread this should go on but am also in a situation where I need to make a change to my old system. I wonder if someone would be able to advise. I don’t know much about how that stuff works. I purchased all my stuff in year 2002. I have the following equipment: 2x Beolab 6000 2x Beolab 8000 Beosound 9000 CD tower 2x Beolab 3 (this is in a different room and is connected to some sort of amplifier (hidden in a cupboard) 1x Beolab 3500, connecting directly via a cable through the wall. Beovision Avant I also have Bose speakers (outside on terrace) connecting into the living room via a Converter Amplifier Type 1741. I also have a Playmaker The TV is the central piece managing everything (the thorn in my foot) The Beolab 6000 + 8000 can do surround via the remote control, I think this is only possible with the TV piece. I want to get rid of the TV as it is of no use to us since many years and do not wish to have a tv replacement, it is a big lump I really can do without. I wonder if this is possible and what I would need to purchase to connect everything together and also what will not work, maybe I will have to lose some functionality like the surround. Is there some amplifier from BO which would do the trick of connecting everything ? There is a BO shop in my area where the system is, maybe I can ask them too. Thanks
The Beosound 9000 should manage this bar the surround. I would guess you have a MCL system in the house using the Avant as the master – that is if this is the CRT Avant. If it is, all you need is an ML to MCL converter and I suspect you already have this (amp in cupboard!) Will need to look at the way it is wired but did something similar myself with little in the way of problems.
mcevedy@mac.com
GOLD MemberI embarrassed to let you know the true extent! However I think I had almost every type of Beomaster with very few exceptions – I didn’t have a 6500 but did have 5000, 5500 and 7000. Equally I had the BC9500 (actually on my third! – fantastic bit of kit!) but neither 9000 or 9300. I essentially stopped audio when they stopped doing touch sensitive controls, only going back for the BC2 with the touch sensitive aluminium – very clever and I don’t know why the stopped this. I have relatively few bits now:
BC2, BC9500, BM4401, BG CDX, BG4000, 4004 and ahem 4001. Also BM/BL 5000 and BG3000 Thorens, a collection of phones though just given Multicare a box full of 6000s. I did have a stupid number of speakers including 3800s with the tulip stands – these are a UK speaker really for complex reasons due to purchase tax. Now have far fewer though do have M100.2s and Beovox 2500 Cubes. Have a fair amount ‘lent’ to friends but don’t want it back. One of my most used items is a Beolit 700 – fantastic device! I have not mentioned the TVs … To be honest, B&O TVs are no longer in my view what they were – B&O used to be all about ease of use and ergonomic brilliance and the new equipment has rather lost that in the pursuit of styling. Still like it and there is nothing else that has taken its place. Sadly my most used music devices are Amazon devices! I did tell B&O that voice control was the most important step forward about 20 years ago but that was before Amazon and Google perfected it. Laughably, the major use of my Moment is to allow an Amazon Dot to play through Beolab 4000s via the line input!
I do have a close typed list of all I had – on three pages! However I am slowly recovering!
17 January 2025 at 16:28 in reply to: Beolab Penta MK3 Purchase and Adding a Beolab 2 Subwoofer? #62837mcevedy@mac.com
GOLD MemberHi Adam,
They seem willing to fix almost anything – they have just made a new circuit board for my BM4401 and saw my Pentas when the delivered my Beolab 5s and said no problem – no rrom in van that time but they are returning at some point – only one of my amplifiers has gome but I dare say the other will swiftly follow! They have a treasure trove of old equipment and of course are doing a lot of work with Beograms for B&O. Splendid group of people and always seem happy to try! I need to find something really tricky to test them!!
mcevedy@mac.com
GOLD MemberThis is a disease! It is contagious but can be treated – strict discipline from wife/partner required! I finished with a linked system utilising MCL,ML and NL all together!
I attach a few pictures – I have given away a huge amount and now just have a few remnants – though am now concentrating on buying the really silly bits!! Beosound 5 and Moment anyone?
mcevedy@mac.com
GOLD MemberThis set is based on the ICC3 chassis by Nordmende = as such this was quite a common chassis so you may be able to find parts more easily than you expect. If issues, contacting Multicare may be helpful as they seem to repair almost anything! My first B&O set was an MX2000 – served the purpose well though did fail and one of my patients who ran an electronics repair shop fixed it and told me of its provenance! To be honest, he was not very complimentary but I liked it!
mcevedy@mac.com
GOLD MemberActually I recognise it ! I scanned it for the old Beoworld site so apologies for any quality issues if you get it – the circuit diagrams are clear though.
