Forum Replies Created
Peter
GOLD MemberThe owner of this site is Multicare who are the main service partner for B&O. They have repaired my Beomaster 4401 so have the experience.
26 March 2026 at 19:10 in reply to: Beomaster 6000 (type 2702) SQ-module, there are different models? #117319Peter
GOLD MemberI had one of those – the technical manual on site is the one I scanned in I think! There was a service manual as well though will have to see if I have the scan of that. As you know, the 6000 deals with two types of quad formats – SQ, as mentioned which is a matrix form of quad and CD4 which has 4 discrete channels. The input for that would be from a Beogram 6000 or 3400 but would require either a MMC6000 or 5000 cartridge as the rear channels are pressed at very high frequencies on the LP and then decoded back to the correct frequency. I had all of these in my time – I think I still have the cartridges and the BG6000 (though this was water damaged when at Bellac and has been converted into the totally mythical BG4001 and the CD4 module given to Tim Jarman! I confess to not being massively impressed with SQ – I do have a couple of LPs and CD4 was better but still not really my cup of tea. The BM6000 was quite a design for the time – always thought it looked like the Medical bed in the original Star Trek! Of course, as you well know, the innards are joyfully low tech! Very good looking set – the matching Beocord 5000 was of course only stereo and absurdly complex. I think I still have one somewhere but will be non operative! The quad fad was hamstrung by the cost and the lack of media so didn’t last that long. The Beomaster 3400 was in some ways rather easier to live with – though it did have the most bizarre tuning scale – I guess, as Tim states on Beocentral, that they had to do something to fill in the space! I think both the 6000 and 3400 on the Beocentral site were mine! To answer you question however, I do not think alternate SQ decoders were offered – not in the UK anyway.
Peter
GOLD MemberHave you tried the BL3000s working directly with the BM6500 just using Powerlink cables? It means moving the BM6500 into the room with the 3000s but if it works, it will be something to do with the cabling. If it does the same, then the amplifiers in the speakers have developed a fault – seems strange both should do this at once though. I have a pair myself though are now just decorative as my ridiculously complex ML/MCL/NL system is no longer in use! I did have a pair of 5000s but far too big so were lent to my dentist – probably on a permanent basis!!
Peter
GOLD MemberI have had most of the older things in my time and have given almost all away. The ones that really impressed:
Beolab 5000 system – the 60s amplifier and tuner along with the Beogram 3000 (had both the Thorens and Acoustical versions – the Thorens is the better). Beovox 2500s to go with the real speakers!
Beogram 4000 – beautifully built – the best of the series.
Beolink 7000 – still makes me smile – use mine with a BC9500 but rarely.
Beolit 700 – just a fantastic sounding radio which looks great
Beolab 5 – made B&O a maker of really high end speakers – I am sure the 50 and 90 are better now but the 5s were the real turning point.
Confess to being unimpressed with most of the TVs after the Avant CRT. I have an 11 which is less easy to use than my LG sets and the new remotes are awful – the Beo4 is far superior. Beolink 1000 possibly better still!
Peter
GOLD MemberThere is a thread about this on the old forum – don’t seem to be able to post a link but a google search on Beomaster rg611 will bring it up!
Martin (Dillen on site) will be the expert on this if he is still on site. Good pictures on the link if you scroll down – Beomaster 900 fitted on the one shown . Record player could have been the 42VF with an SP2 cartridge.
Very nicely made item – shame about the missing electronics – I do have a BM 900 at home which is unused – mine is the one called a 900K – have a look at Beocentral under Receivers – can’t remember if that is my one or one of Tim’s! There is a picture of the 900RG which is the model that took over from the RG611.
There are a couple of Beomaster 900 on eBay – will usually need attention! Multicare may also have some, having seen their store room!
Peter
GOLD MemberI bought a Moment – not that long ago – it really is not a good product – I now use it as a way to play my Amazon Echo Dot through Beolab 4000s! I am about to get a simpler device to do this so the Moment will be relegated to display only! No battery issues at present but I am sure it will do. I share your disdain!
Confess I also have a BV11 – less enamoured with that than you are – remote not easy to use in the dark and the drama turning it on with the Bang & Olufsen coming up before anything happens – confess the other sets in the house are now LG as they just turn on immediately. I have one that works with a B&O stage and is fine. I regret getting rid of the BV5 which still worked fine but connectivity was becoming tricky. Though of course my BC2 does not really connect to the BV11 as not HDMI – only sound.
The speakers are all fine though!
Peter
GOLD MemberI think the first suggestion from Guy is the best idea – If you already have a cable through the wall, as long as it has enough connections and some shielding, then just changing the plugs could be the answer. ML is the cable used to connect different devices together – powerlink is really just audio out and some command functions – the forerunner was MCL which distributed amplified sound and command signals. If you go to the tab at the top labelled Beotech, there are wiring diagrams for Masterlink and Powerlink. The other way is to pul through a powerlink cable attached to the masterlink cable but I suspect that this will be difficult.
Peter
GOLD MemberHarsh – possibly because they are not fitted with the front – have a look here.
https://beocentral.com/beovoxcx100
Small bookshelf speakers – not very extended bass hence the Beovox Cona but for computer use they are fine. Need an amplifier.
Peter
GOLD MemberInteresting – I did have BL3s for a while – used a Beomaster 7000 below the computer – didn’t really like them – never felt as if they sounded integrated – like two speakers – probably because too close. Went to CX100s which were better for me. Getting old so although CX100s are still there, no longer connected as gave away the receiver!
Peter
GOLD MemberI also had a Beolit 700 and worst than spraying them Blue, which would look good, I sprayed them Pink – as a present for my sister I hasten to add – I thought it looked terrible but better than the mess the panels were in – she loved it!
This is my 700 – I was correct, was mustard coloured.
Peter
GOLD MemberThe point of the 6000 is that the contact patch in deep into the groove but extremely thin. This is because it was designed to pick upm the CD4 encoding which required tracking at about 40kHz. Clearly this needed a very fine contact area to be able to do this. The 20CL is capable as is the MMC5000 but the use of CD4 is very limited – only the Beomaster 6000 and 3400 were quad equipped – had both as well as a Beogram 6000 with MMC6000 and even some CD4 records – academic interest really – somewhere still have the records though the BG6000 had the quad decoder removed and became a 4001!
Peter
GOLD MemberI always heard the BL2 is boomy. Plus the 19 looks super cool.
You can change the settings – and mine is blue!
Peter
GOLD MemberNot sure the Beolab 2 is that bad 😀 but I know what you mean – I found it fine with a TV and added to the sound but certainly less good with music. I have Beolab 5s now so no need for a subwoofer – relegated to playing with some Beolab 4000 in another room!
Peter
GOLD MemberI agree with Martin – my interest was always in the audio equipment which is now not really available. I confess my most used piece is my Beolit 700 – splendid piece of kit – though not sure Martin would approve as I sprayed the case blue – I think it was mustard before though can’t remember! Thanks to Multicare I do have Beolab 5s which are stupendous but are attached to my Beovision 11 which is clunky compared to the LG sets we have elsewhere.
Interested that ajames’ favourite piece is the 9300 – my favourite design is the 9500 – which sits in what we call the playroom – actually have two of these but have the other on long term (permanent!) loan with a friend. The ability to use it with a Beolink 7000 is the advantage amongst other things. Slightly noisy transformer on mine but managing with use of squash balls!
Peter
GOLD MemberI think that is good – you possibly could add that the 4004 was really designed for the 2400 system with a proto datalink system to allow remote control of the record player. One of the bits I still have ! Along with the 4001 🙂
It is difficult though as the majority of younger people will not want the old Hi-Fi systems – the new 4000c is obviously a very niche product though a splendid one – and are more likely to use standalone speaker devices – to be honest, this is what I now use most often as you can just ask for what you want and it is delivered rather that looking for CDs, tapes or LPs.
Therefore the market for Beoworld is less than it was at its height – not the forum dying, more the users! However I would agree that if I wanted to ask a question about B&O, Beoworld would be my first port of call.
Peter
GOLD MemberRunning a forum is difficult. I found Beoworld at its very inception mainly because they had borrowed some pictures from Beocentral which I had contributed to. Beocentral did notb have a forum and after an amicable discussion with the founder of Beoworld, Steve, we allowed use of our pictures. I had noted a nascent forum which was not much used so after discussion with Steve, I took over as moderator. At the time, I had a fairly large collection of B&O and therefore made it my task to answer every question to the best of my ability the day it was posted. After a time, we attracted quite a following and also the interest of B&O as their forum really ended up just being complaints which was not really very helpful to the brand. In our case, as we were not the manufacturer, we could sympathise but suggest solutions. The forum rapidly became the go to area for B&O questions and we had a large team of moderators – I will not embarrass them by naming them all, but Martin was a true font of knowledge as he had a collection that dwarfed mine!When Lee took over, the forum continued to expand and he was able to establish the prize draw which expanded the site even more. I suspect this was the golden age of B&O with music systems as well as TVs and speakers being in the range.The problem really became when the range contracted, many items were no longer made in Denmark and they had to compete with brands that were more advanced in some ways. They remained selling stylish and very good sounding equipment but the prices were becoming extremely high for items that were matched in utility by lesser brands. It is interesting to see the return of record players to the range but these are not priced to attract the same market as before.Thus the number of enthusiasts has fallen. I stopped being a moderator sometime ago and have relatively little B&O these days – though enough! I therefore cannot really help with newer equipment and most is not like the old systems which were designed to be easy to service.Multicare now have ownership of this site and do a fine job in my opinion. They are the go to people for repairs – they have fixed a number of bits for me and I have a nice pair of Beolab 5 speakers that I purchased from them. However we still rely on unpaid advice on the site and us oldies are getting fewer. I spend more time on the Triumph site if I am honest! I do have a B&O TV but the sets I ise most are LG because they have a better interface and, dare I say it, a better remote! The advantage of the Beo4 and Beolink 1000 is that they could be used in the dark as the buttons navigated you – the flat remotes are simply a triumph of style over function in my opinion.My B&O Icons:
3 June 2025 at 11:24 in reply to: Beosystem 3000c (£22,000) or this £45 Beogram – which would you choose? #66157Peter
GOLD MemberI confess I cannot see any reason to buy a 3000c – the 4000c is an icon of design and although also ridiculously expensive, I can see (just) the attraction. The 3000 is not so I would take your radial deck every time!My B&O Icons:
Peter
GOLD MemberThe Beogram 7000 has the advantage that it will work by remote control – however one normally cleans the record before playing it so one could argue that this is less important. The BG7000 is very expensive these days because it has the RIAA fitted so works with most modern systems as the RIAA is quite often not in the amplifier (I am sure know this but the RIAA is an amplifier to boost the signal from a magnetic cartridge and also equalise the frequency response.) The BG7000 is an OK record player but for the money I would be tempted to look elsewhere especially if records are unlikely to be your usual media played. The CD player is good and the tape player also fine. These systems originally started as the 5000 system and was a midrange offering – they eventually became the top of the line though the actual devices did not change that much – one could argue that the CD5500 was probably the best of the CD players though all except the CD50 are decent choices. Shame you don’t have the Beolink 7000 as this allows a huge amount of extra functions. However also expensive and becoming a bit less reliable these days. I have used my 7000 system (long since gone!) with both passive and active speakers – Pentas are great but used everything from S45s to M100s and even BBC LS3/5as and all sounded good. I confess I went back to a BC9500 as prefer the styling and user interface though still use the Beolink 7000.I play my Amazon Dot through one of my B&O systems as it allows voice control – works well!My B&O Icons:
Peter
GOLD MemberI am sure Multicare would offer to help but this is going to be quite expensive.My B&O Icons:
Peter
GOLD MemberI take it you mean the 6000! The one that looks like the display for the medical beds in Star Trek – fantastic machine – manages to look space age but uses moving ribbons instead of LEDs. Can’t remember what I did with mine! The matching cassette deck in possibly the most unreliable device I ever had! There is a video on Mend It Mark (Youtube ) of him fixing one – respect! The BM6000 is a fascinating bit of kit though the 4400 outperforms it. However the looks are wonderful – pretty sure I scanned the service manual for Beoworld a few years ago. Best of luck with the reassembly.
