matador
Forum Replies Created
Viewing 20 posts - 61 through 80 (of 845 total)
  • in reply to: Beolab 3500 Table Stand size and shape… #66709
    matador
    I owe you one  for the fine drawing you made of the Playmaker stand.
    Your debt has been erased!       😀
    in reply to: Beolab 3500 Table Stand size and shape… #66707
    matador
    That’s perfect, all I needed to know for now.
    I may come back to you later in the modeling process to check the holes position (I bet B&O does’nt place them randomly and speaker orientation has it’s reasons).
    But for now it’s all good.
    Thanks you Madskp.
    in reply to: Beolab 3500 Table Stand size and shape… #66691
    matador
    Hi Madskp,
    a scan of the profile of the stand. Would you prefer the Scan as a PDF or a picture?
    A picture would be perfect.
    The pictures you posted will be a great help. Could you please measure the whole height of the stand ?
    Thank you!
    in reply to: Can I use a Beolit 12 without Apple devices? #66654
    matador
    As far as I know, no. Airplay is Airplay.
    Member Leogonewild did a mod on a Beolit (12 I think but maybe 15) to insert a google home inside. Quite a work if I remember correctly but neat and clean. If you like challenges…
    in reply to: Is this forum dead? #66623
    matador
    I actually wrote a longer piece about this a while ago, but decided not to post it, as it was more or less just my own reflections and not really particularly helpful.
    I’d like to read it.
    in reply to: Is this forum dead? #66622
    matador
    not the forum dying, more the users!
    It is all said*. Amen.
    *It’s a common usercase about high end brands in marketing schools.
    matador
    Interesting reading.
    Both seems to point out that a failed update doesn’t ‘brick’ the device (Apple Anxiety again…).
    In the end I believe it’s just a psychological issue like “if don’t update I will miss new features making my BS1 sounds like a BL90 and many other fancy stuff.
    It works, don’t touch anything (because ‘loudness’ is not really a thing I miss – more on my Beolit 12…).
    Thanks Mads.
    matador
    Just in case, both of them can be easily DIY’ed… 🙄
    in reply to: Beo6 not recognised when connected to PC #66567
    matador
    Hi Charlie,
    Even when you meticulously follow the wake up procedure for Beo5/6 it sometimes does’nt work. Then you try again the day after and it works.
    Once I was close to prove that it has to do with the conjuction of solar wind, the song playing in the radio at that exact moment, and the time of the days. But in the end I was unable to gather enough data to be sure.
    I’ve become comfortable that there is no rules when playing with those thing but this one: A dead Beo6 does not exists.
    You have to keep trying until it works.
    Good luck!
    matador
    Hi Madskp,
    1- I believe the antennas are the two side strips on the lower body of the unit. In the top part all I’ve seen looks like controls parts (rotating volume and touch panel. Nevertheless, Wifi does’nt seems to be the issue. More likely the link between the app and the device.
    2- Yes I’ve tried to reset the unit (thus erasing the wifi credentials) and use ethernet only: same behavior, the app sees the unit because it sets the gold color in the app and after that cant establish connection. Then again, even in wireless mode, the airplay connection is steady and strong.
    3- No, but see above.
    4- Yes it has and it was quite a surprise. The web server is the same as the one in the playmaker or the Beolit 12, same look and features that the Beosetup App.
    Then, yes, it could be a good place to try the update. But I’m still reluctant to do it (Years of Apple Update Anxiety…).
    Thank you for your help.
    in reply to: Fluid Sweet Spot? #66547
    matador
    to auto focus a sweet spot to the phone’s location (and therefore the listener’s position in the room).
    What crazy world we’re living in…
    matador
    Beosound Century-c…
    matador
    Realtime update…
    Ths unit was on test in my office. few minuts ago I wanted to move it and had to unplug it. Guess what? It continued to play for like 40 secondes until I pkugged it again.
    The BeoSetup App* shows battery level at 100% and Batteru health as “Good”. This need to be investigate in the days to come.
    B&O App still can’t maintain connection.
    in reply to: Trigger BeoCenter with 12v #66518
    matador
    Solution 1:
    If you use Google automation, find an IR emitter B&O complient and code some commands.
    Solution 2:
    Change the girlfriend?
    in reply to: Beosound 1 (cone) battery level and health… #66513
    matador
    Answer to myself,
    The battery is dead. After like 8 hours plugged to mains, the unit turns off as soon as it is unplugged.
    In the meantime I learned that the battery status can be checked in the app,
    but the unit doesn’t provide consistent communication with it so, impossible to tell.
    in reply to: Is this forum dead? #66512
    matador
    Why can’t we just all get along?
    Hi Stan,
    Why? Have you ever tried to get along with those weird guys from the Bower & Wilkins forum? Try, then you ‘ll know why!
    (Just kidding…)
    in reply to: Welcome #66504
    matador
    How do I report spam like this in the forum?
    https://forum.beoworld.org/forums/topic/ready-obat-aborsi-bogor-wa-081222292216-cytotec-terbaru-2/#post-66461
    With kind regards
    Peter, who didn’t find a “report” button
    Done.
    in reply to: Is this forum dead? #66496
    matador
    Wow, people left the forum for political reasons?!? Please don’t tell me what I missed, but I thought this kind of nonsense was mostly happening on my (US) side of the pond… 😒
    Sorry, meaning lost in translation.
    Political reasons are not politics related. I meant “reason that are not related with the content of the forum”, but more interactions between members.
    in reply to: Is this forum dead? #66477
    matador
    I honestly don’t understand historical people who leads people to any other source than BW.
    You (– We?– I’m still unable to count me in) have fight for our forum, upgrading the metal badge and “swearing allegiance”…
    I’m not good at fights maybe because I’m too blunt so I try to stay away from fights.
    But I can’t stand historical members point to “three posts members” a source where all (sorry) the rats have flew.
    I believe Beoworld is about knowledge, passion and share. Not about views, visibility and presence.
    I also believe Members have turned their mind for whatever reason I don’t get.
    Is BW dying? Maybe. I also feel the lack of activity.
    Are all my fellows playing somewhere else? As Stan says, maybe, but it’s beyond my skills.
    Am I angry to every each member that left BW for political reasons and leads to that kind of totally stupid thread? YES.
    And please, be all assured that it is a “political” reply because, deeply, it is worst.
    in reply to: Is this forum dead? #66456
    matador
    Is there another place on the web where people discuss B&O more actively than here?
    Thanks in advance and have a nice day.
    What a rude and disrespectfull attitude!
    Given your activity history, you just come here when you need help, without even saying hello or introducing yourself.
    If you don’t find the activity up to your expectation: feel free not to come.
    Morover it should be up to your skills to find by yourself another place that better suit your needs.
    Look, I’ll still help you: type the letter “B”, followed by the symbol “&” and again the letter “O”, capitals or lowercase doesn’ matter, in your favorite search engine, it should be a good start…
