Forum Replies Created
9 April 2025 at 16:10 in reply to: VAM1250 for BeoSound 9000 MK3: who knows a reliable source to buy > SOLVED #65042
Igor Jané
BRONZE MemberOk thanks, then I undersarand that the 1204 1205 1206 1252 and 1254 are not compatible with the ones you and me have? I found this feom ebay that is coincident in shape and specs as a CD-Pro2..
but the seller feedback to my questions is that the unit is not compatible with mine…. do you think that is possible to find a unit directly from B&O? Thanks again! Igor
8 April 2025 at 20:27 in reply to: VAM1250 for BeoSound 9000 MK3: who knows a reliable source to buy > SOLVED #65037Igor Jané
BRONZE MemberHello everyone! Bad news I tried a unit from ebay, the seller recommended it after I sent him pictures and reference of my pickup (attached picture of the pickup I received), he told me my pickup is a VAU 1254 on a VAM 1250, finally I’ve received it today and installed it very carefully and it does not work on my unit…, is not even capable of read any disc, doesn’t even start spinning because the pickup is not working properly (I installed mine back and still reads some cds like it did before).. I don’t feel like testing from more sources because many look and have similar references…. please @kolfmaker do you think I can ask Keith Saunders to provide one for me? The one you bought from him worked properly? Thanks again in advance!!
igor
4 April 2025 at 17:10 in reply to: VAM1250 for BeoSound 9000 MK3: who knows a reliable source to buy > SOLVED #64945Igor Jané
BRONZE MemberHi! Ok thanks! I have just ordered a unit from an ebay seller from germany that seems to fit the shape and requirements, if it works I will post the results and the reference. Thanks again 👍🏻
3 April 2025 at 22:01 in reply to: VAM1250 for BeoSound 9000 MK3: who knows a reliable source to buy > SOLVED #64929Igor Jané
BRONZE MemberHello, yes here you have a picture of the sticker and the pickup of my mk2. Regards.
3 April 2025 at 19:28 in reply to: VAM1250 for BeoSound 9000 MK3: who knows a reliable source to buy > SOLVED #64922Igor Jané
BRONZE MemberHello, I have a mk2 and the sticker shows the same exact reference. Can it really be the same laser pickup, as my version is a mk2? Will follow the progress if the unit you have is worlking for you, and if you can give us the reference to find it would be useful. Thanks a lot!
3 April 2025 at 19:15 in reply to: Beosound 9000 sledge touches the back of the CDs – The solution #64921Igor Jané
BRONZE MemberHello everybody! I have just tried the @znarf75 restraighting solution using a small hammer, some cloth and a very flat surface, just to bend slighltly the part to the original shape. In fact, it was very very slightly deformed. After that I recovered the damper with the shrink tube as @pierre69, and the result is that de BS9000 now works perfectly. Thanks a lot to all of you guys, it would be a very very rought job to discover it on my own, and probably making some mistakes that could cause other misadjustments, etc. Then thanks again! I will tell you how it is working and if keeps the shape with the use.
igor
31 March 2025 at 15:55 in reply to: Beosound 9000 glass door appears to sit too low/push down #64796Igor Jané
BRONZE MemberHello! Thanks a lot, it solved the issue 👍🏻
30 March 2025 at 15:17 in reply to: Beosound 9000 glass door appears to sit too low/push down #64779Igor Jané
BRONZE MemberHello. I have the same problem, did you find the solution? Thanks a lot in advance 👍
