Hiort
Forum Replies Created
Viewing 7 posts - 141 through 147 (of 147 total)
  • Hiort
    GOLD Member
    Did a quick check with the latest AppleTV 4K connected to the Soundcenter (HDMI D) and had it configured as per the instructions (4K SDR, Match content On).
    When I play a movie from Netflix that is Dolby Vision, the panel signal that it is indeed Dolby Vision being played.
    Hiort
    GOLD Member
    Interesting.
    Thanks for sharing. I was not aware of this. I recently got my hands on a 1stgen Eclipse.
    Its says in the guide that you should use the HDMIs in the TV it self rather than the ones in the Soundcenter if you want to benefit from Dolby Vision. I will do some tests and report back, since I have the latest ATV available.
    However, if you use the HDMIs in the TV it self I do not think you can use the PUC cable, hence you need to use the AppleTV remote.
    in reply to: Acquired a second life Eclipse 55″ and need advise #34045
    Hiort
    GOLD Member
    Thanks Jean,
    I will check with my dealer.
    Do you know if it’s a difficult task to replace the panels?
    in reply to: Beovision 11-40 Dimming #33240
    Hiort
    GOLD Member
    I had my BV11-46 for some 7 years now and never seen something like that. Works like a clock.
    in reply to: Profile image update #33025
    Hiort
    GOLD Member
    I was able to change my avatar to a picture of my selection. Go to your profile and choose edit in the left column.
    An option to change picture will appear. Worked with the Safari browser.
    in reply to: Beolink Multiroom #33120
    Hiort
    GOLD Member
    “Slightly updated in that I see Deezer Flow on there – dont remember seeing that there before. Either way, nice for the Deezer users no doubt.”
    Note that Deezer Flow is only available if you have some of “mozart platform devices” as source, like Emerge, Balance and Level.
    in reply to: Thank God the Beoworld Forum is back #33075
    Hiort
    GOLD Member
    Cannot agree more! Thanks for all hard work to everyone that has been involved!
