filip_kbh
Forum Replies Created
Viewing 20 posts - 101 through 120 (of 167 total)
  • in reply to: Beogram CD 7000 tray belt #45955
    filip_kbh
    C2103 is the one all important capacitor to change. Search on the forum and you will get a lot of hits. There could be others but I would start with this one. Since I changed it in my Beogram 7000 CD player, it plays absolutely everything. Before the change, it was very picky about which CDs it would play.
    in reply to: Beomaster 7000 2-way does not work #45900
    filip_kbh
    D10 and R18 on the powerboard, not the computer board. On the computerboard the F 1A fuse blows, so will have to restore the proper voltage rails first.
    I will need to do some more measurements when I have time. Thank you for the help so far.
    in reply to: Beomaster 7000 2-way does not work #45898
    filip_kbh
    D10 was indeed not working. Also R18 was defective. After replacing these two, I now have +40V back on p14-6. Yay. A small victory.
    There are still some problems though. On P18-5 I now don’t have -40V – I have no idea why as it worked before. And none of the voltages on P15 are correct, so I don’t have 28V on p15-6, I don’t have 12V on P15-3, and I don’t have -12V on P15-2. Sigh. P24 also still gives around 5V instead of the specified 11V.
    in reply to: Beocord vx5000 #46426
    filip_kbh
    Die Bogener – I love your pictures – but when I press them, they never zoom in; they always take me to pic-upload.de 🙁
    in reply to: BeoLink 7000 not moving down #46518
    filip_kbh
    When in Auto mode, it will only move the upper panel down when you lift it up from the table. If you want it to lie straight on the table you must do it manually.
    in reply to: Beocord vx5000 #46416
    filip_kbh
    Can you run the VTR without a cassette? See section 7-1 in the service manual.
    Also, if the fan motor is blocked, the VTR goes into standby within 1-2 seconds according to the service manual.
    in reply to: Beocord vx5000 #46414
    filip_kbh
    Did you clean the black part with the white pin with an arrow in the middle – not sure what it is called – to the left of the drawer motor. It will corrode and could cause all sorts of problems.
    in reply to: Beocord vx5000 #46417
    filip_kbh
    This thread by Die Bogener is also worth a read.
    in reply to: Beomaster 7000 2-way does not work #45897
    filip_kbh
    Looks  like D10 is shorted. Will change it.
    in reply to: Beomaster 7000 2-way does not work #45896
    filip_kbh
    Finally had some time to look again, and also I understand the schematics a bit better now.
    Checking the voltages on board P9. On pin 3 there should be 40V but I measure around 26V – it drops ever so slightly and keeps dropping until 25.87V when I measure with the multimeter. 40V is supposed to come from 2P14-6.
    On board 2 P14, pin 6 gives me also around 26V – logically. Seems like it passes through C10 which I did not change – it measures 57uf capacitance and should be 47 – so I guess it is slightly out of spec – could that be the issue?. P18 measures the specified -40V.
    On board 2 P24 should give me 11V but it gives around 5V.
    Any help is appreciated.
    in reply to: Verbinden von Beocenter 9300 mit Beolink 6000 #46283
    filip_kbh
    Keine Ursache. Du brauchst 2 Powerlinkkabel (die hast du schon), und 2 Stromkabel (davon hast du schon einen). Also brauchst du eigentlich nur einen Stromkabel (Euro 8-Form) zu kaufen, oder du hast einen übrig von einem anderen Produkt, den du verwendet kannst.
    in reply to: Verbinden von Beocenter 9300 mit Beolink 6000 #46281
    filip_kbh
    Falsch! Die beiden Lautsprecher benötigen Stromversorgung.
    in reply to: Beogram 6500 only one channel working #46043
    filip_kbh
    Look at the muting relay. It may have corroded.
    in reply to: Beomaster 7000 2-way does not work #45895
    filip_kbh
    yes. I have an RDS BL7000. Worked before the recap of the BM.
    in reply to: Beomaster 7000 2-way does not work #45893
    filip_kbh
    Also no readout of RDS. Guess I will have to seek professional help.
    in reply to: Beomaster 7000 2-way does not work #45891
    filip_kbh
    Well, that was an easy fix. A wire had broken off. After soldering it on, I also soldered one pin on the big chip on the panel as it looked slightly suspicious, and now 2-way IR is back. It now reports the radio channel. Yay! Still no read out of Volume, and it seems like the range is limited.
    in reply to: Beomaster 7000 2-way does not work #45890
    filip_kbh
    I’m getting a little bit frustrated. 1-way function was working. I decided I wanted to play a new record that I bought today, so I assembled the Beomaster. Now, IR does not work at all. And I didn’t touch anything. Must be a connection, I guess.
    in reply to: Beomaster 7000 2-way does not work #45889
    filip_kbh
    Regarding TR10:
    Base to Collector: 0.570 V 3.3 M Ohm
    Base to Emitter: 0.273 V 333 Ohm
    The diodes have been tested and they check out fine. I have inspected the board and there are no cracks as far as I can see.
    in reply to: Beomaster 7000 2-way does not work #45885
    filip_kbh
    Hm. I have about 28V on the diodes
    in reply to: Beomaster 7000 2-way does not work #45884
    filip_kbh
    Hmm – I have a hard time trusting my ESR metre. On the front panel board, I get open line readings on these:
    C3, C5, C7, C8, C9, C11, C12, C16, C18, C23, C24
    However, testing with the multimeter, only these ceramics give me no reading/reaction:
    C5, C11, C23, C24. Still it’s a lot of ceramics …
    Putting power on the board, only C5 is suspicious with a voltage across it of 0.142 V DC
