David Harratt
Forum Replies Created
  • in reply to: Beolab 3 sticky? #124318
    David Harratt
    Thanks, I will check those posts out!
    in reply to: I need an IR eye for a Beosystem 4 #124284
    David Harratt
    Thanks Guy,
    I’ve decided to listen to my head over my heart on this one and use a modern non B&O receiver as my main switch/ processor after all.
    I’ll keep the beosystem 4 and the IR info in mind for a future project though.
    Thanks again:-)
    in reply to: I need an IR eye for a Beosystem 4 #124070
    David Harratt
    Hmm, that link doesn’t seem to work for me.
    But thanks for the reply, maybe it’s worth me just getting the cable anyway. If it works, great, if not, I’ve only lost out on the cost of a cable.
    I believe Sounds Heavenly supply the necessary wiring instructions with the cable anyway.
    Thanks for the reply,
    DH
