Dave Wilkins
Forum Replies Created
  • Dave Wilkins
    Hi ,
    Thanks for your reply !
    I am hoping to get the Beogram turntable and run it side by side with the Linn Sondek so that I can compare the sound . However I have now got the Linn running “line in ” through the Sonos Port and its sounds brilliant through the Beolab’s .
    I am fascinated by the “linear tracking” on some of the models and would really like to listen to those models .
    Cheers
    DWW
    Favourite Product: Beograd 4002
    Signature: DWW
    Dave Wilkins
    Hi
    I have made some progress ! After listening and comparing speakers I have bought a pair of Beolab 3 speakers and a Beolab 2 subwoofer . To say I am pleased with the result would be an understatement ! The difference between them and my old Linn speakers is huge .
    I am currently playing my Sonos Port through the speakers .
    Next on the agenda is a B and O turntable .
    A big thank you to Steve at Sounds Heavenly for the cabling advice and superb service !
    Cheers
    DWW
    Signature: DWW
    Dave Wilkins
    Great that is really helpful thanks ! I have still to buy the turntable so will look out for the Sounds Heavenly amp and leads if I go with the B and O speakers as well which I think will be the way forward . That way I can have the B and O as a separate turntable system .
    Thanks !
    Signature: DWW
