Home › Forums › General Discussion & Questions › General Discussion & Questions › New here – Please can anyone help ? Turntable based system
- This topic has 6 replies, 3 voices, and was last updated 3 months ago by
Dave Wilkins.
16 June 2026 at 08:23 #124032
Dave Wilkins
BRONZE MemberHi
I am interested in getting a refurbished Beogram 4002 turntable . But as this will be my first step into Bang and Olufssen I wonder if anyone could help please ?
I have a current Hi Fi system based around a Linn Sondek , Linn speakers and Cyrus amp/CD .
I would like to run a separate turntable based system to contrast and compare to the Linn before I fully swap to B and O .
Can I use the 4002 with its pre amp to play into my current speakers or do I need to use an amp ? If I were to get B and O speakers as well as the turntable would that work ?
Sorry if the questions are a bit basic ! I have the B and O book on order from Crowood press to help educate me and joining here will obviously help !
DWW
Favourite Product: Beograd 4002
Signature: DWW
16 June 2026 at 11:36 #124038 GuyModeratorHi and welcome to Beoworld!
When you say a ‘refurbished’ Beogram 4002, has the Beogram been retro-fitted with a pre-amp, because it didn’t come with one as standard? It will need a pre-amp if you wish to connect to a ‘line’ input of most amplifiers. Some amplifiers will have a built in pre-amp, in which case the input is often labled as ‘phono’.
The Beoworld product page for the Beogram 4002 is here: https://beoworld.org/beogram-4002/
Beoworld has a FAQ about Beograms here (read the para ‘Which BeoGram will work with my System?’): https://beoworld.org/beogram/
If your Linn Sondek is using an external pre-amp, you could (with the right adaptor) connect the Beogram to that, and then to your Cyrus amp and Linn speakers.
There are two main types of B&O speakers:
Beovox: Passive speakers that need a seperate amplifier. Most non-B&O amplifiers can drive these, but you might need to be careful with impedance – keep volume levels low when first testing.
Beolab: Active speakers that have their own power amplifier built in, and require their own mains power supply. If part of a B&O system, there are usually connected by Powerlink cables (with 8-pin DIN plugs at each ed) from a B&O Beomaster or Beosystem with Powerlink outputs.
If your Beogram does not have a built in pre-amp, you could get a pre-amp with volume control and then drive Beolab (not Beovox) speakers directly. The site Sponsor SoundsHeavenly supply such a pre-amp, and will probably be able to offer further advice: https://soundsheavenly.com/products/volume-controlled-pre-amp-for-b-o-beogram-to-beolab-speakers
I hope this helps!
16 June 2026 at 12:06 #124039Dave Wilkins
BRONZE MemberGreat that is really helpful thanks ! I have still to buy the turntable so will look out for the Sounds Heavenly amp and leads if I go with the B and O speakers as well which I think will be the way forward . That way I can have the B and O as a separate turntable system .
Thanks !
Signature: DWW
16 June 2026 at 12:44 #124040 GuyModeratorNo problem. Come back and visit once you have it all up and running. 😊
24 June 2026 at 12:12 #124113Dave Wilkins
BRONZE MemberHi
I have made some progress ! After listening and comparing speakers I have bought a pair of Beolab 3 speakers and a Beolab 2 subwoofer . To say I am pleased with the result would be an understatement ! The difference between them and my old Linn speakers is huge .
I am currently playing my Sonos Port through the speakers .
Next on the agenda is a B and O turntable .
A big thank you to Steve at Sounds Heavenly for the cabling advice and superb service !
Cheers
DWW
Signature: DWW
26 June 2026 at 14:27 #124183mcevedy@mac.com
GOLD MemberHave you listened to a Beogram? I have had most in my time and still have a 4000, 4004 and a 6000 masquerading as a 4001! They are very good turntables but are not Linn Sondek level. You also have the issue of cartridge compatibility – they only take B&O cartridges or Soundsmith cartridges. The latter are new. These are quite expensive – I have had one though I prefer the original B&O ones but most will be getting rather old and the suspension will get stiff and can collapse. Equally the styli do wear.
I confess to liking the BG4000 the most – hideously over engineered – the later models were made more economically and sounded much the same – the platter on the 4000 and some early 4002s is much heavier and the motor system differs – AC versus DC – Beocentral has a good description of the decks. Choice of cartridge is important – I use mainly MMC20CL cartridges though have had a couple of cartridges retipped to good effect.
Shame you are in Devon as I would lend you a deck to try – I am at the exact opposite end of the country!!
26 June 2026 at 15:16 #124184Dave Wilkins
BRONZE MemberHi ,
Thanks for your reply !
I am hoping to get the Beogram turntable and run it side by side with the Linn Sondek so that I can compare the sound . However I have now got the Linn running “line in ” through the Sonos Port and its sounds brilliant through the Beolab’s .
I am fascinated by the “linear tracking” on some of the models and would really like to listen to those models .
Cheers
DWW
Signature: DWW
