Chris D
Forum Replies Created
Viewing 1 post (of 1 total)
  • in reply to: Eclipse Gen 1 Cable Connections #124324
    Chris D
    Thanks David!  That really helps. The two cables that disappear down on the right (LAN CTRL and HDMI)  are currently orphaned on my system, I guess they had to be plugged in before the LCD panel was placed on the sound centre. Not sure if there is any other way to plug them in somehow with the panel in place.
    I appreciate your help.
