Home › Forums › Product Discussion & Questions › BeoVision › Eclipse Gen 1 Cable Connections
- This topic has 3 replies, 2 voices, and was last updated 3 months, 4 weeks ago by
David Honner.
29 June 2026 at 11:36 #124274
Chris D
BRONZE MemberWe moved our Eclipse Gen 1 65″ to another apartment and when the movers removed the Eclipse from the wall, they removed the LCD panel from the sounds center, but didn’t take any photos of the cable connections! Can anyone tell me what cable connects from the sound center to the LCD so they communicate? I can’t find any documentation no matter where I look and all the youtube videos seem to skip this detail.
Thank you!
30 June 2026 at 01:47 #124289David Honner
BRONZE MemberA photo of my own connections. I think the antenna cable may be different depending upon region, but the other two cables should be the same connections wherever you are.
You must be logged in to view attached files.1 July 2026 at 02:04 #124324Chris D
BRONZE MemberThanks David! That really helps. The two cables that disappear down on the right (LAN CTRL and HDMI) are currently orphaned on my system, I guess they had to be plugged in before the LCD panel was placed on the sound centre. Not sure if there is any other way to plug them in somehow with the panel in place.
I appreciate your help.
1 July 2026 at 02:24 #124325David Honner
BRONZE MemberSTB brackets have a kit to swap out the Eclipse screen for a newer LG panel. The instructions talk about where those cables plug in. Check out this page and either watch the video (cables shown at 0:56) or download the instructions for a diagram of where they go.
I suspect you’re right about needing to plug into the soundbar part first before putting the screen on. Removing and replacing the screen shouldn’t be too difficult and the instructions will help guide you.
This reply was modified 3 months, 4 weeks ago by
David Honner.
