Forum Replies Created
AdamSBRONZE MemberI must admit I’m struggling with this one.
Beogram 4000 (or 4002, actually…) – absolute classic and a design icon known by anyone interested in audio worldwide
BeoSound 9000 – one of the most instantly recognisable bits of B&O kit and another design icon in its own right
I get the re-creation of both of these, but Beogram 3000? Really? It’s a middle of the range and unremarkable turntable from the last generation of B&O decks and the chief selling point I can see for picking it as a candidate is that there are plenty kicking around and suspect very few people will be bothered about a hundred vanishing off the market!
I’ve no doubt that the system will sound great and it looks lovely, but this is straying dangerously close to the UK comedian Harry Enfield’s “I Saw You Coming” shop sketches, for my liking.
Come on B&O – how about something NEW for your centenary?!
AdamSBRONZE MemberI have a personal theory that is completely and utterly unsubstantiated by anyone, but here goes:– Beolab 90s are currently £141,000 in the UK– The next model down in the range are the Beolab 50s, which are £52,000That’s quite a big gap.Just saying…. 😉 AdamSBRONZE MemberNo.
Just……………..NO!
AdamSBRONZE MemberWhat makes you think they need re-capping?
I’ve owned dozens of B&O cassette decks over 30 years or so, and not one of them has required re-capping.
AdamSBRONZE MemberWell, I take it back. Not seen one of those before!
AdamSBRONZE MemberThis deck would have an MMC1, 2, 3, 4 or 5 in it – are you sure some of the writing hasn’t rubbed off?!
Alternatively, can you post a picture?
AdamSBRONZE MemberExcellent news – enjoy!
AdamSBRONZE MemberI didn’t actually need to do mine as the foam was fine – as above, it was the crossover damaging them!
As to the capacitors, I have absolutely no doubt that the capacitors in the Danish Sound Parts kit will be correct – my question was whether they were right before this? Like I said, someone had been at mine before I owned them, and one of the capacitors in each crossover was wrong – I only found this out when I fitted the new capacitor kit.
AdamSBRONZE MemberIf you’re lucky, it may just be the foam behind the driver. There’s a sheet of foam that is pressed by the plastic cover behind the midrange and tweeter to provide pressure form the rear to hold it in place. This foam can age and deteriorate, so the midrange isn’t being held in firmly, and can rattle. Change the foam or add a bit more in, and this may well fix it.
If you’re unlucky, it may be the same problem i had with both my MS150 midranges, where some idiot re-capped the crossovers in the past and put the wrong capacitor values in the midrange circuit, allowing too much low frequency to get to the driver, and eventually causing the voice coils to overheat and fall off the formers. When you re-capped, were all the new capacitors the same value as the ones you took out?
AdamSBRONZE MemberBeocenter 9500 every time.
Beocentral explains it, and isn’t very complimentary about the 9300! – https://beocentral.com/beocenter9300
AdamSBRONZE MemberSorry for the obvious question, but your 45rpm LP isn’t a version made of clear or see-through vinyl is it?
24 January 2025 at 13:04 in reply to: Beomaster 5000 & components (Beogram, Beocord & Beocard CD-5500) #63048 AdamSBRONZE MemberQuality Dream Audio have an excellent reputation and I have no doubt that they’ll sort everything out for you, but you’re also only just down the A3 from Tim Jarman in Farnborough. To say that Tim has an “encyclopaedic” knowledge of B&O would be to under-state the amount of information in a encyclopaedia!
You can contact him through his website here if you’d like him to take a look: https://beocentral.com/contact
16 January 2025 at 13:17 in reply to: Beolab Penta MK3 Purchase and Adding a Beolab 2 Subwoofer? #62784 AdamSBRONZE MemberPersonally I wouldn’t dream of ruining a pair of Pentas by adding the Beolab 2 unless you particularly like boom, thump and appalling timing!
Is a Beolab 19 out of your price range, as this is a far better unit?
As an aside, Peter, I didn’t know Multicare could service Penta amplifiers. I may have to speak to them as both of mine are completely knackered…
AdamSBRONZE MemberThere’s a gear in the centre section of the mechanism that crumbles with age and fails – this is usually what causes this.
Search “Beosound Century gear” on eBay for a selection of newly-made reproductions that will fix the issue.
AdamSBRONZE MemberDid you order the belt from Danish Sound Parts (formerly Beoparts)?
If not, then I wouldn’t necessarily trust it to be correct!
AdamSBRONZE MemberWonderful – I’ll have a look at that later!
Mind you I’m still sulking that my B&O room from last year was so comprehensively out-done! 😉
(and I still want to know where I can buy a B&O rug!)
AdamSBRONZE MemberAs above, dismantle the switch and clean both the PCB contact and the underside of the tactile dome as they can give problems.
I had a Beogram 5000 come my way a few years back where so much dust and muck had got under the switch dome, when you pressed Play, the deck would start but then immediately stop again, then re-start itself and keep doing this over and over again until I pulled the plug!
AdamSBRONZE MemberYes, sadly your tweeters have had it – bad luck!
A low resistance reading suggests that the coil has probably overheated and individual turns of the coil wires have melted together (which would also cause the rattling you’re hearing), so they won’t be salvageable, sadly.
AdamSBRONZE MemberMy experience with those supposedly “correct” replacement tweeter diaphragms has been very poor. They are usually poor quality and the last ones I bought had the wrong diameter voice coil and had the lead-out wires in completely the wrong place for the dome they were supposed to be replacing.
To cap it all, when I returned them for a refund, they allegedly “got lost” in the post.
I would buy a complete correct replacement tweeter. The S75s are very good so definitely worth it.
AdamSBRONZE MemberI had my MS150s repaired some years ago by Richard Allen speakers – they serviced them but were so impressed with their sound that they tested them properly and presented me with the frequency chart saying they had some of the flattest frequency responses they had come across in a pair of speakers and were very impressed. I actually sold them as this series of speakers had tweeters that seemed to shriek to me at higher volumes – I preferred the older M100.2s which I still have though I doubt they actually perform as well. I also prefer the finish of the earlier speakers – B&O seemed to be using slightly poorer materials though the electronics performed probably better. I seem to remember these Yamaha speakers were very bright and needed very good sources or could be shrill. But excellent speakers they seem to be in need of a slight polish though 😀
I know, Peter, I know, I’m working on it! Sadly both tweeters are dead and beyond repair, so I need to source a set from Japan before work can continue. And, of course, in the meantime, I’ve bought another pair of speakers that need some work…
Interestingly, I know the NS-1000Ms have a reputation as being ‘bright’, but i f you look at their frequency response, there is a bit of a lift in level at the 15-16kHz region, but they actually tail off above this, and are around 3dB down from nominal at 20kHz.
As to NS-1000M versus MS150.2, I know where my money will still go…
