- This topic has 81 replies, 25 voices, and was last updated 7 months, 4 weeks ago by
Madskp.
19 May 2022 at 05:06 #34875
Loudspeaker
BRONZE MemberSquare4 kindly reminded me of this topic and asked if I would like to create a thread on the new forum and as I recently bought a very iconic piece of B&O, I thought this would make a good welcome back to this topic.
It looks and smells absolutely disgusting as it has a very thick layer of nicotine all over it. Luckily it looks to be in a very good condition for its age under the filthy layer, so I’m sure this will be a nice example after a clean and polish.
19 May 2022 at 17:29 #34876 square4BRONZE Member??
That’s a nice one Dennis.
19 May 2022 at 17:45 #34877 mexkingBRONZE MemberNice one Dennis, happy desmoking, Henrik did you get my mail ?
21 May 2022 at 08:39 #34878 square4BRONZE MemberMy white Beogram 6000 is starting to have some issues
So now i have replaced the whole setup with my oak setup
And all the instructions for use are there for them all
Henrik
23 May 2022 at 08:17 #34879 kuyttendaeleMemberGot myself a Balance (and an Essence remote) for my 2nd appartement. Replacing the Ouverture.
27 May 2022 at 09:44 #34880 square4BRONZE Member23 September 2022 at 16:09 #34881Loudspeaker
BRONZE MemberAdded another couple of items to my collection of preproduction units yesterday. These fit in nicely with the other items I have from the same model range as they fill in some of the gaps between the earlier samples and units from the final production in terms of changes made during the development stage.
As some of you might know, I have a Beogram 3000 with orange text named ‘Beogram 5005’, a Beogram CD 50 with built-in control panel and a Beomaster and Beocord 5000 named 4000 with wooden trim and a different front panel design.
The newly acquired Beomaster 5000 has rosewood trim on the sides as well.
This CD 50 didn’t come with the fancy built-in control panel though, but upon closer inspection it isn’t identical with the ‘normal’ sample I have.
The CD 50 with control panel is quite a different beast on the inside. It was based on an Aiwa DX-1000 whereas the final model was based on an Aiwa DX-1200 according to this website, where a detailed comparison between the two CD 50s can be found.
The one I picked up yesterday doesn’t differ nearly as much from the production-version as far as I can tell. The display is bit different though and it looks like it might still feature a repeat function, which the production-version doesn’t seem to have as far as I can tell from the owners manual, but I have yet to use a CD 50, so I’m not entirely sure.
The production-version:
The early prototype:
The early protype has additional functions shown to the left of the segment display:
The newly acquired unit:
I’m still on the hunt for a Beogram 5000 with rosewood trim – it would be even nicer to find one named Beogram 4000. The seller had a red labelled Beogram 5000 as well but without wooden trim. That one he intented to use instead of his TX2, so it wasn’t for sale.
23 September 2022 at 16:20 #34882Dillen
ModeratorVery nice finds, indeed.
Here is a Beogram 5000 in palisander (red label), just to give you an idea what it looks like. 🙂Martin
23 September 2022 at 16:44 #34883Loudspeaker
BRONZE MemberI have found one for sale at Bremdal Radio:
If 2751029 is the serial number, it most likely isn’t a preproduction unit though. This is quite interesting on the other hand, as this suggests, that it was possibly to buy these with wooden trim back in the days; a rumour I haven’t been able prove before finding this one for sale some time ago.
23 September 2022 at 18:15 #34884 TignumGOLD MemberThat BeoMaster 5000 with the rosewood sides is ABSOLUTELY GORGEOUS. Lucky you!
6 October 2022 at 06:33 #34885 square4BRONZE Memberat the weekend I bought this beogram 3400, it was supposed to be used for spare parts for my own 3400 quadro.
But this one is just perfect, the only thing is that the lid has small scratches after many years of use.
Instead of using it for spare parts, I will move the quadro module into it instead.
Henrik
4 December 2022 at 09:11 #34886 square4BRONZE MemberI have bought a set of the very very rare beovox 5702 type 6257, and they are the best speakers I have, they are better than both m100, m150 and ms150
4 December 2022 at 09:16 #34887 square4BRONZE MemberI also bought these beovox m70, because of the trumpet stands which are to be used for the beovox 5702
Henrik.
18 December 2022 at 20:56 #34888RobinWal
BRONZE MemberLast week my Beolab 5 arrived. Finally….
19 December 2022 at 08:22 #34889 TignumGOLD MemberCongratulations RobinWal! And welcome to the (new) forum. The speakers look amazing on the concrete floor. Enjoy! (while I keep on dreaming of them some more :-)). Johan
19 December 2022 at 13:00 #34890 kuyttendaeleMemberJust before summer bought an Balance + Essence remote for my appartement at the coast.
19 December 2022 at 13:32 #34891NQVHNWI
BRONZE MemberThis would come under addiction – expensive addiction at that:
Just purchased a used Kaleidescape Stratos S 6TB Movie Player to go with my 5.1 BS Theatre combo and get the most out of the system:
Better than BR 4K video (Uncompressed Studio Video at 10 to 30% more data)
Full uncompressed sound (Raw Atmos).
Sounds frigging awesome!
19 December 2022 at 17:34 #34892beojeff
BRONZE MemberHow long does it take to download a movie at 4K with uncompressed audio?
19 December 2022 at 17:41 #34893NQVHNWI
BRONZE MemberSo far, it looks like 2.5 to 3hrs. This depends on the file size. Typical BR discs store 66Gb, and I’m seeing 80 to 100Gb downloads on my favourite must-haves.
The latest Stratos C apparently can do it in 15 to 20minutes.
Main thing for me is the uncompressed sound. Staggering with the Theatre.
1 January 2023 at 17:25 #34894Loudspeaker
BRONZE MemberI recently acquired a couple of remotes more in the form of these Beo4 hotel versions. I’m still missing at least one of the consumer versions of the Beo4 (DTV + V.AUX), but I have most of the regular versions now. Still looking for some of them in better condition though. And there are many different hotel versions, so the collection is far from complete.
The Cinema looks to have been used regularly, but a mint one is probably not easy to find. A mint Play-version should be fairly easy though. I have a Beo5 as well.
I also bought a Beo1 and my first BeoRemote One.
/Dennis
