Home › Forums › For Sale & Wanted › Wanted › wanted motor for casettedeck Ouverture 4000
- This topic has 8 replies, 4 voices, and was last updated 2 years, 9 months ago by
Riverhead Studios.
21 February 2023 at 01:05 #44034
Riverhead StudiosBRONZE MemberI am a newbie here – I have a Beosound Ouverture 4000, and according to the repair person it needs a new motor for the casettedeck, as it makes a squealing sound when a tape is playing and then the casettedeck stops and unit switches off.
I live in New Zealand, how do I find or get a new motor? Any equivalent replacements possible?
Kind regards, robert@riverheadstudios.co.nz
8 May 2023 at 04:21 #44038 GuyModeratorThe BeoSound Ouverture was called BeoSound 4000 outside of Europe, as explained here: https://beoworld.org/prod_details.asp?pid=952
8 May 2023 at 11:15 #44035solderon29
GOLD MemberIs Ouverture 4000 a model?
The cassette motor in the Ouverture is not usually a “squeaker”,but may have been put under strain by having an incorrect drive belt fitted at some stage?
Contact Martin Olsen,member “dillen” here.Martin has vast knowledge of vintage B&O,and a seemingly inexhaustible supply of salvaged part’s too!
Nick
8 May 2023 at 12:22 #44036 matadorModeratorIs Ouverture 4000 a model?
C’mon, I think we can be forgiving there, Bang & Olufsen being the first to have numerous confusing model names, right?
8 May 2023 at 16:15 #44037solderon29
GOLD MemberSo,is it an Ouverture or perhaps a Beocenter 4000?
Both feature cassette decks but are quite different beasts.
Might save some time and help the guy if we can establish that,right?
Nick
8 May 2023 at 16:33 #44039 matadorModeratorExactly.
9 May 2023 at 02:26 #44040 Riverhead StudiosBRONZE MemberApologies for the model description, the manual book says Beosound Ouverture. I know in Europe it is called Beosound 4000.
Perhaps anybody with a link to the person that can help me to locate a working casette mechanism/motor , please contact me. My repair person from the official B&O dealer in New Zealand has taken 7 months to tell me he may have located one, but that is not yet confirmed.
I will try to find Martin Olsen, member “dillen” but as a new member I am learning to navigate through all this new stuff.
The cassette deck motor has likely been under some strain as a piece of tape got jammed between the capstan roller, almost out of sight for a few hours before I discovered that piece of tape stuck.
I bought it secondhand, previous owner never played tapes, so when I played my first tape on it it was kind of sticky – presumably years of dust – and got wound around the pinch roller. The repair person at B&O dealer removed the tape wound around the roller , but apparently missed a little bit, which I found after a few hours of play.
Since then it played for a while – long or short – before stopping with a squealing sound. Dropped the unit off at the dealer again, and now 7 months later – some good news but nothing yet confirmed.
The cassette mechanism seems a trouble some piece of engineering, as all Beosound Ouverture models handed in for repair at B&O here in NZ have no working cassette mechanism.
Appreciate your responses.
Kindest regards
Robert van de Voort
9 May 2023 at 15:31 #44041solderon29
GOLD MemberIt’s a good mechanism,but the weak link is the rubber belt which perishes with age.
The replacement type/size is crucial too,and Martin can almost certainly help with that too.
Now we have established the machine type,I can dig among my own salvaged parts,but I don’t remember having one of those motors spare.
Nick
10 May 2023 at 05:28 #44042 Riverhead StudiosBRONZE MemberThe belt is here and ready to be replaced, only the motor seems to be the issue to be replaced.
All other belts and moving parts in the Beosound Ouverture are checked and ok according to the technician.
Thank you all for your kind assistance so far.Cheers
Robert
