Home › Forums › General Discussion & Questions › General Discussion & Questions › Searching for a spare part (ic for Beosound 9000
Viewing 20 posts - 21 through 40 (of 40 total)
  • #123812
    KolfMAKER
    Hi Edo, thanks for your update.
    I actually think this is progress. The fact that replacing the TDA1305T did not change the behaviour strongly suggests that the DAC itself was not the root cause. What I find more interesting is that:
    • cooling around C401/C403 restores the sound,
    • replacing C401/C403 did not solve the problem,
    • and TR405 starts oscillating when the audio disappears.
    That makes me wonder whether C401/C403 are simply close to the actual faulty component, rather than being the fault themselves.
    At this point I would focus on TR405 and the components directly around it. It may be useful to measure the base, collector and emitter voltages of TR405 before and after the fault occurs.
    Once the freeze spray arrives, I would also try cooling TR405 and the surrounding components individually rather than cooling a larger area of the PCB. To me, TR405 and its local circuitry now look like stronger suspects than the DAC.
    edo69
    Hello, I begin to have some doubts regarding the possibility to repair the PCB32.
    Right today, I have readen that the PCB 32 is a multi-layer board (4 layers); do you think that the issue could be in an internal conductive track?
    In this case, we can not check nor repair internal tracks.
    Favourite Product: Beosound 9000
    #123818
    KolfMAKER
    I would not worry too much about the 4-layer PCB at this stage.
    Yes, an internal track or via failure is possible on a multilayer board, but based on the symptoms I do not think it is the most likely explanation yet.
    The reason is that you already have several strong clues pointing towards a localized thermal issue:
    • TR405 starts oscillating when the fault occurs,
    • the behaviour is repeatable and temperature-dependent.
    To me, that still sounds more like a component, solder joint, via, regulator, transistor or local control circuit problem than a hidden internal PCB track.
    I would wait for the proper freeze spray and continue narrowing down the exact area by cooling individual components one at a time.
    In particular, I would focus on:
    • TR405,
    • components directly connected to TR405,
    • nearby capacitors, resistors and diodes,
    • and any ICs or regulators in the same section of PCB32.
    Only if the freeze spray testing fails to identify a specific component or area would I start considering an internal PCB defect as a more likely possibility.
    At this point I still think there is a reasonable chance that the actual fault can be isolated and repaired.
    edo69
    Hello,
    finally we had the possibility to test PCB32 components with the cooling spray.
    the result was that the sound remains for more time cooling the LF33cdt.
    So we will buy some and we will replace it in 2 weeks, ’cause the technician is going to holidays.
    I will let you know…..
    #123942
    KolfMAKER
    Thanks for sharing again Edo. This is actually the most promising clue so far.
    What caught my attention is that cooling the LF33CDT does not just bring the sound back temporarily, but appears to extend the operating time before the fault occurs. That makes the LF33CDT a much stronger suspect than the components investigated earlier.
    Since the LF33CDT is a 3.3V regulator, a thermal problem there could potentially explain many of the symptoms observed so far, including why the DAC initially appeared to be the culprit.
    If I were troubleshooting this, I would not only replace the LF33CDT, but also:
    • Inspect and reflow its solder joints,
    • Measure its input and output voltages before and after the fault,
    • Monitor the 3.3V rail while the unit warms up,
    • Check whether the output voltage changes when the regulator is cooled.
    At the moment, this seems like the strongest lead you have had so far. Please keep us updated after the replacement.
    edo69
    Hello,
    GOOD NEWS, AT LEAST!
    We finally got to replace the LF33CDT and now the BS9000 sounds great!
    Te tested it for more than 1 hour, without any problem.
    The funny thing is that I have bought 4 of this component at the price of 7 Euros.
    Once again, thank you for all your support.
    #124123
    KolfMAKER
    That is excellent news! Congratulations on finding the real fault.
    This has turned out to be a very interesting troubleshooting case.
    In hindsight, the LF33CDT explains many of the symptoms. A regulator can become thermally unstable without completely failing, so measuring a nominal voltage with a multimeter does not necessarily mean the supply is healthy. Small voltage dips, oscillation or excessive noise can easily upset the DAC and surrounding circuitry.
    I think your systematic approach deserves credit:
    • Verifying the digital signals,
    • Replacing the suspected DAC,
    • Using thermal testing,
    • And finally narrowing the fault down with freeze spray.
    Thank you for taking the time to report the final solution. Threads like this become very valuable for other Beosound 9000 owners who may encounter the same problem in the future. Great info for the community!
    Enjoy your rescued & fully working BS9000!
    edo69
    Hello, unfortunately I sang victory too soon.
    Once replaced the LF33CDT, as you already know, we tested the BS9000 for about one hour, changing often CD and song, without any problem.
    I brought it home and reconnected it.
    In the same day I listened to various CDs without any problem.
    The next day I turned on CD, and The CD begun to spin, the counter advanced properlìy, but no sound.
    I tried more times, always with the same result.
    The day after, I turned on RADIO from another room (trough Beosound 2000), radio worked fine, Then I tried with CD and it worked well.
    Yesterday and the day before, always no sound. Not in yhe loudspeakers, nor in the headphones.
    We have to start searching again where the trouble is…
    There is something more: sometimes the commands do not reach BS 9000 (that is in option 0): happens sometimes that I give the command “CD” with the Beo4 to Beovision 7 (with option 2) and the BS 9000 does not turn on.
    It even happened that, giving the command “n. music” with Beo4, the display on Beovision 7 is not “n. music”, but “n. music 1” and Beosound 5 (in “master audio off”) does not turn on.
    So I think that:
    BS 9000 is still not working properly;
    I even have a problem with masterlink connections (or BS9000 working not properly, crashes the masterlink connections)
    It’s always more complicated.
    • This reply was modified 3 months, 1 week ago by edo69.
    #124426
    KolfMAKER
    Sorry to hear that Edo. The new symptoms actually make the diagnosis even more interesting.
    The fact that:
    • the CD spins correctly,
    • the counter advances normally,
    • radio always works,
    • and sometimes switching to Radio first and then back to CD restores the sound,
    suggests to me that this may no longer be a simple thermal failure.
    I now wonder if there is an initialization, muting or power sequencing issue on PCB32.
    The replacement of the LF33CDT may have improved the original thermal problem, but there could still be another fault in the same area.
    I think it would be useful to compare two situations:
    1. Cold start → select CD → no sound.
    2. Cold start → select Radio → then switch to CD → sound OK.
    In both cases I would check:
    • Is the analog audio present at the output of the TDA1305T?
    • Is the 3.3V output of the LF33CDT stable (preferably with an oscilloscope, not only a multimeter)?
    • Does the muting circuit behave differently between the two cases?
    I would also carefully inspect and, if necessary, reflow the solder joints around the LF33CDT, its input/output capacitors, nearby vias and connectors. A marginal solder joint or via could easily explain why the behaviour changes after source switching.
    The good news is that the investigation now seems to be focused on a much smaller area than before.
    edo69
    A maybe important thing I forgot to tell you is that in the last few days, I did 4 times the test TM71,  with CDs in all positions except #1, as suggested in service manual.
    Any time the test did not get to its end, because first open and close the glass, and it’s OK; then the sledge, attempting to move from position 1 to 6, always crashes into the CD in position 2, and the BS9000 turns OFF.
    #124428
    KolfMAKER
    That is an interesting observation, but I am not yet convinced that it is directly related to the CD audio problem.
    To me, it sounds more like a separate issue involving the sledge positioning or calibration.
    If TM71 always fails because the sledge crashes into the disc in position #2, I would first suspect:
    • incorrect home/reference position,
    • sledge position feedback (sensor or encoder),
    • mechanical alignment,
    • or a servo control issue.
    The important question is:
    Did this behaviour already exist before replacing the LF33CDT, or is this the first time TM71 has been run?
    If TM71 has never completed successfully, it may simply be revealing a second, unrelated fault.
    On the other hand, if this behaviour only appeared after the recent work, it would be worth checking whether anything around PCB32, its connectors or the servo-related signals has changed.
    For now, I would treat the TM71 failure and the intermittent CD audio as two separate problems unless there is clear evidence that they are connected.
    edo69
    Tanks for your opinion and suggestios.
    Is not the first time I check the TM71, and it always went fine.
    Just the first times, when i tiried this test, I haven’t readen that the position #1 must be without the CD; once learned this, this test never gave me any problem.
    I try to remember that the last time I did test TM71 was after the replacement of TDA1305T, and went fine.
    Me too I’m thinking that TM71 fault and intermittent audio are due to different reasons.
    The strange thing is that sometimes the CD works perfectly, even for hours, and sometimes works with absolutely no sound.
    • This reply was modified 3 months ago by edo69.
    #124441
    KolfMAKER
    Thank you, that is important information.
    I also have another thought.
    A worn laser in a Beosound 9000 usually causes problems reading the disc itself. In that case, you would typically expect symptoms such as difficulty reading the TOC, long “Reading…” times, failure to start playback, or skipping during playback.
    However, in your case the CD appears to be recognised correctly, the counter starts normally, and the disc continues playing.
    That seems to suggest that the digital data is being read successfully, making a laser problem less likely.
    Can you confirm one detail?
    When there is no sound, does the time counter still continue to advance normally from 00:00 as if the CD is playing correctly?
    If the answer is yes, I think that points even more towards a problem after the data has already been read from the disc, rather than a laser or optical pickup issue.
    I still think the key is to compare the “sound OK” and “no sound” situations and determine exactly what changes between those two states.
    edo69
    Hello, in response to your question, yes, the time counter still continue to advance normally from 00:00, even in case of no sound.
    #124495
    edo69
    That’s incredible,
    with the BS9000 at home, linked with Beovision7 and Beosound5 via master link, as usual, this morning the CD worked fine; I have listened to 2 whole CDs.
    After lunch, I turned on again the CD, and it worked, but no sound at all.
    As usual, the CD was spinning and the time counter advancing. I changed track and CD, but always no sound.
    I really I don’t know what to think.
    HAve a nice weekend
    #124507
    KolfMAKER
    Thank you for the update.
    Actually, I think this gives us another important clue. The fact that you were able to play two complete CDs without any problems strongly suggests that the laser and CD mechanism are fundamentally working correctly.
    When the fault occurs:
    • the CD is recognised,
    • the disc spins,
    • the time counter advances,
    • you can change tracks and even change CDs,
    • but there is simply no audio.
    To me, this now sounds less like a CD reading problem and more like an audio routing, muting or initialization issue.
    I have one question that may help narrow it down further: When CD is playing with no sound, could you try the following?
    1. Switch to RADIO and confirm that radio audio is present.
    2. Then switch immediately back to CD.
    Does the CD audio return, or does it remain silent?
    If switching sources restores the CD audio, that would point towards a source selection or muting problem.
    If the CD remains silent even after switching back from RADIO, then we should continue looking around the CD audio path on PCB32.
    I think this simple comparison could provide a very useful clue.
    edo69
    Hello, I did the test you suggested me, more times.
    When I turn on the CD, i have no sound; switch to radio and it works; come back to CD and again, no sound.
    What is happening now is that I turn on the CD, and there is no sound, if I let the CD go, after some minutes, the sound comes out, and goes on….
    #124549
    KolfMAKER
    This is actually a very significant new observation.
    The behaviour has changed from:
    “the sound disappears after some time”
    to:
    “there is no sound at first, but if I let the CD continue playing, the sound appears after a few minutes and then remains stable.”
    To me, that points much more towards a temperature-dependent analogue circuit than a CD reading or source selection problem.
    The fact that:
    • the CD is recognised immediately,
    • the time counter runs correctly,
    • tracks can be changed,
    • Radio works normally,
    • switching Radio → CD does not restore the sound,
    • but simply waiting does,
    suggests that some part of the audio circuitry only starts working once it has warmed up.
    At this stage I would try the opposite of freeze spray.
    Instead of cooling components, I would carefully warm individual suspect components or small areas (for example with a hot air station set to a low temperature or a hair dryer from a safe distance).
    If warming a specific component causes the sound to appear much sooner, that would be a very strong clue.
    I would start with the area around the LF33CDT, TR405 and the surrounding analogue circuitry on PCB32, since that area has already shown temperature sensitivity during your earlier tests.
    One additional thought: although the LF33CDT has been replaced, I would still verify the 3.3V rail with an oscilloscope during the first few minutes after power-up. Since the earlier thermal tests pointed to this area, it would be useful to confirm that the regulator output is not showing excessive ripple, oscillation or instability while the unit is warming up. It would also be worth carefully inspecting the solder joints and nearby components around the replacement regulator.
    edo69
    Hello,
    some days ago I went to my repair boy to take my BS9000 at home, perfectly functioning (this said the technician).
    He was right, the cd now works properly, and the audio, by the earphones plug is perfect.
    He did just replace a capacitor (not reported in the diagram into the mkIII service manual) (!!!) to fix the problem.
    But he had not the possibility to check the master link plug; I did it at home and now the sound is present, but at a very very low volume.
    He now suggest to replace ALL the capacitors in the PCB 32 board (about 30), having them 25 years of working behind them.
    We will do that, as soon as we  have procured all the capacitors, and I will let you know.
    I’m thinking that this will be the right time.
    See you
    #125097
    KolfMAKER
    Ik zou het vriendelijk formuleren, maar hem wel adviseren om vóór een volledige recap eerst nog een paar gerichte metingen te doen.
    That is good news regarding the original CD problem, but I would personally hesitate before replacing all ~30 capacitors on PCB32.
    The fact that CD audio is now perfect through the headphone output suggests that the original CD/DAC audio problem has actually been solved.
    The remaining problem now seems much more specific: CD audio is present through Master Link, but at a very low level.
    Before doing a complete recap, I think a few checks could help narrow this down:
    • Which capacitor did the technician replace to solve the original problem? Its value, location and what circuit it is connected to would be very interesting, especially since it is apparently not shown in the MK3 service manual.
    • Does RADIO still play at normal volume through Master Link while CD is very quiet?
    • Is the low CD volume the same through both the BeoVision 7 and BeoSound 5?
    • Can the technician trace the CD audio signal from the now correctly functioning CD/DAC section towards the Master Link circuitry and find where the signal level drops?
    Especially if RADIO has normal volume through the same Master Link connection while CD is very quiet, that would suggest that the Master Link connection and at least much of its circuitry are working correctly.
    I would therefore try to locate where the CD signal loses amplitude before replacing every capacitor.
    There has already been quite a lot of rework on PCB32, and replacing another 30 SMD components on a multilayer board also introduces some risk of damaged pads, vias or new soldering problems.
    So my preference would be: diagnose first, then replace components selectively.
    And please let us know which mysterious capacitor finally solved the original problem — that may be one of the most useful findings from this whole repair!
