Home › Forums › General Discussion & Questions › General Discussion & Questions › Searching for a spare part (ic for Beosound 9000
- This topic has 39 replies, 2 voices, and was last updated 1 month, 3 weeks ago by
KolfMAKER.
13 May 2026 at 11:19 #123552
edo69
BRONZE MemberHello everyone.
I am having an issue with my Beosound 9000: readinc CD, the sound disappear in 1-2 minutes, while the CD keep spinning and the timer goes on; this happens only with CD, while with other sources (radio, n. radio, n. music) everything works fine.
The technician individuated the problem in the Ic TDA1305T (DAC).
I have found the spare part on Ebay (n. 2 items), described as “original” and “brand new”.
Once arrived, the technician replaced the Ic with a new one; the result is that in 30 seconds, the sound becomes intermittent, then disappears.
Then he provided to replace the new Ic with the other new one, ant the result was: no sound at all.
At the ent, he replaced the new Ic with the original one; result: sound disappears in 1-2 minutes, exactly the same ad before.
So I am convinced that the Ic’s I have bought are not good, no obstain they have the Philips logo and the correct code.
The problem now is to find the correct spare part that was really original and brand new.
Does someone know where could I find it?
Thanks in advance to who will reply.
Favourite Product: Beosound 9000
13 May 2026 at 12:02 #123554 KolfMAKER
BRONZE MemberI am not fully convinced yet that the TDA1305T itself is the root cause.
The fact that the CD keeps spinning and timing continues, while only the audio disappears after 1-2 minutes, could also point to a thermal issue, power supply instability, muting circuit, soldering problem or an issue around the DAC/output stage.
Also, the different behaviour with the replacement IC’s does not automatically prove they are fake.
One important question:
Which version of the Beosound 9000 is this exactly? MK1, MK2 or MK3?There are differences between revisions/boards and that may matter here.
Do you know:
– the exact type / MK version?
– whether the service manual matches this unit?
– if the supply voltages around the DAC were measured when the sound disappears?
– if the mute signal changes state when the audio drops out?To me this still sounds more like a surrounding circuit issue than a pure DAC failure.
13 May 2026 at 15:21 #123557edo69
BRONZE MemberHello, sure I know which version of Beosound 9000 I have; is a Mk3 (type n. 2571).
We are consulting the BS9000 MK3 service manual.
Thanks for your opinion, I’ll send it to the technician.
Any other suggestions will be appreciated.
Kind regards
13 May 2026 at 16:31 #123559 KolfMAKER
BRONZE MemberThank you, that information helps.
Since it is a MK3, at least we know the technician is working with the correct service manual and the correct DAC type (TDA1305T).
However, the behaviour still does not fully convince me that the DAC IC itself is the primary problem.
The fact that:
- the CD continues spinning correctly,
- timing continues normally,
- and the audio first becomes intermittent before disappearing,
still sounds more like a thermal or surrounding circuit issue to me.
Possible areas worth checking:
- power supply stability around the DAC/audio section,
- voltage regulators,
- electrolytic capacitors,
- mute circuit/transistors,
- solder joints or hairline cracks,
- temperature-sensitive components around the DAC stage.
Especially because the failure develops after some operating time.
A useful diagnostic step could be freeze spray / controlled heat testing around the DAC and surrounding circuitry to see if the behaviour changes immediately.
Questions
- Does the sound always disappear after roughly the same amount of time?
- And does it return again after the unit cools down?
14 May 2026 at 08:56 #123582edo69
BRONZE MemberHello,
let me correct you:
the issue with the original Ic TDA1305T is that in 1-2 minutes the CD audio becomes mute, the CD keep spinning and the timer goes on while with other sources (radio, n. radio, n. music) there are no problems at all.
Individuated the Ic TDA1305T as the responsable of the issue by the technician, I providet to buy on Ebay n. 2 spare parts (original and brand new, they said).
When arrived, we replaced the original IC with a new one: we tested functioning, and after abour 30 sec. the cd signal became intermittent, then disappeared.
So we replaced the new Ic with the other new Ic; testing functioning, we had no sound at all.
Finally, we replaced the Ic with the original one, and everything came back the same as before (soun disappear in 1-2 minutes).
So we had 3 different responses by 3 different Ic’s.
What do you thingk about that?
This reply was modified 5 months ago by
edo69.
14 May 2026 at 09:08 #123583 KolfMAKER
BRONZE MemberThank you, this clarification is useful. What I now think is:
The fact that the original IC always returns to exactly the original behaviour probably means:
– the board itself was not permanently damaged during the IC replacements,
– the original fault is still present in the same signal chain,
– and the Ebay IC’s may indeed be questionable, but they still do not automatically prove that the original DAC IC is the root cause.The 3 different behaviours with the 3 IC’s are interesting:
– original IC → sound disappears after 1-2 minutes,
– replacement IC #1 → intermittent sound after ~30 seconds, then mute,
– replacement IC #2 → no sound at all.This could mean:
– the replacement IC’s are fake / reclaimed / defective,
– or they are more sensitive to an existing surrounding circuit problem.At this point, I personally would not continue buying more TDA1305T IC’s before doing more measurements around the original IC.
I think the important next diagnostic step is determining:
Does the audio already disappear directly at the analog output pins of the DAC, or only later in the muting/output stage?That would help confirm whether the DAC itself is really failing.
I would suggest checking:
– DAC supply voltages before and after audio disappears,
– BCK / LRCK / DATA signals,
– mute line / muting circuit,
– analog output directly on the DAC pins,
– freeze spray / thermal testing on the DAC and surrounding components.To me this still feels more like a surrounding circuit or thermal issue than a confirmed pure DAC failure.
14 May 2026 at 10:29 #123588edo69
BRONZE MemberThank you a lot; I will send your post to the technician and I’ll update you on what will happen.
Kind regards.
19 May 2026 at 16:03 #123661edo69
BRONZE MemberGoodevening,
today with the tachnician we check these line:
pin:
4. BCK -> Signal ok5. WS -> Signal ok
6. Data -> Signal Ok
19. MSUB – > before and after audio stop remain on 5v
1. VDDA – > 5v, before n after
10. VDDD -> 5v, before n after
28. VDDO -> 5v before n after.
Technician reamin on idea that the issue is the DAC.
19 May 2026 at 16:21 #123662 KolfMAKER
BRONZE MemberThank you, that is useful information.
If BCK, WS and DATA remain OK, and VDDA / VDDD / VDDO all remain stable at 5V before and after the audio disappears, then the digital input signals and supply voltages to the TDA1305T seem to be present.
That does make the DAC a stronger suspect than before.
However, I think there is still one very important measurement missing:
Is the analog audio signal still present directly at the output pins of the TDA1305T after the sound disappears?
If the analog output from the DAC disappears while BCK / WS / DATA and all 5V supplies remain OK, then I would agree that the DAC itself becomes very likely.
But if the analog signal is still present at the DAC output pins, then the problem must be after the DAC, for example in the muting circuit, output stage or coupling components.
So in my opinion the next decisive test is to check the analog output directly on the DAC pins before and after the fault occurs.
Let me know the outcome!
20 May 2026 at 10:54 #123668edo69
BRONZE MemberSorry, I missed to tell you about this test, that we already have done:
The result is that when the sound disappears, even the analog audio signal disappears at the output pins of the TDA1305T .
At this point, I think we have no more any doubt regarding the need to replace the TDA1305T to fix the problem.
As you already know, we already tried to replace the original DAC with other two, that I have purchased on Ebay, and, no obstain the Ic’s were guaranteed as “original” and “brand new”, noone of them, once mounted, werk properly.
Do you know any reseller of electronic components who could sell me a truly original and brand new Ic?
Thank you a lot for your precious cooperation
20 May 2026 at 11:25 #123669 KolfMAKER
BRONZE MemberThank you, that is a very important additional test.
If I understand correctly:
– BCK remains OK
– WS remains OK
– DATA remains OK
– VDDA / VDDD / VDDO remain stable at 5V
– MSUB remains at 5V
– and the analog audio signal disappears directly at the output pins of the TDA1305TThen I agree: this makes the TDA1305T itself the most likely cause.
At this point the problem is probably not the CD mechanism, not the digital signal going into the DAC, not the supply voltage and not the mute line.
The difficult part is finding a trustworthy replacement. Since the TDA1305T is an old Philips/NXP DAC, I would be very careful with Ebay or AliExpress parts. They may be reclaimed, relabelled or fake, even if they look correct.
I would try:
– NXP authorized distributor network
– Rochester Electronics
– professional obsolete component suppliers with traceability
– or possibly a donor board from another known-working unitPersonally, I would avoid buying more “new and original” ICs from unknown marketplace sellers unless they can provide proper traceability.
20 May 2026 at 16:18 #123673edo69
BRONZE MemberUnfortunately noone of these suppliers you suggested have the TDA1305t in stock.
I also tried with 12 other sellers, such as: Mouser, Farrell, Tme, etc. and noone had avaliability.
So I decided to purchase an entire DAC board with n. 2 TDA1305T inside, on http://www.audiophonics.fr; I will keep you updated
20 May 2026 at 21:02 #123679 KolfMAKER
BRONZE MemberI think purchasing the complete DAC board was probably the best decision at this point.
After all the measurements, the diagnosis now seems much clearer:
– digital data signals remain present,
– clocks remain present,
– supply voltages remain stable,
– mute line does not change,
– CD mechanism continues operating correctly,
– but the analog signal disappears directly at the DAC outputs.That combination now strongly points to an internal DAC failure.
Also, the fact that one replacement IC worked briefly before failing could indeed suggest reclaimed, marginal or counterfeit parts.
Using a complete donor DAC board is a much safer approach because it also eliminates possible uncertainties regarding soldering, surrounding components and PCB-related issues.
Please keep us updated — this has become a very interesting diagnostic case.
22 May 2026 at 09:38 #123709edo69
BRONZE MemberHello,
unfortunately the DAC board I have found on http://www.audiophonic.fr is not the same mounted on Beosound 9000; It is only used to disassemble one of the two Ic TDA1305T and replace the original one with it.
22 May 2026 at 12:20 #123710 KolfMAKER
BRONZE MemberThat sounds like a reasonable approach.
As far as I know, there are no known Beosound 9000-specific versions of the TDA1305T. The TDA1305T is a standard Philips DAC, used in many different audio products of that era.
Therefore, if:
- the donor DAC board is working correctly,
- the donor TDA1305T is healthy,
- the IC is removed without damage,
- and it is soldered correctly onto the BS9000 board,
then I would expect it to work in the Beosound 9000 as well.
What makes your case particularly interesting is that the replacement will also act as a diagnostic test.
If the donor TDA1305T works normally and the fault disappears, that would strongly confirm the original DAC was defective.
If the donor TDA1305T shows exactly the same behaviour as the original IC, then I would start to suspect that something else around the DAC stage may still be contributing to the problem.
In any case, using a known-working donor IC from a complete DAC board gives a much higher level of confidence than buying loose ICs from unknown marketplace sources.
Please keep us updated on the result after replacing the TDA1305T with the donor board one.
27 May 2026 at 20:25 #123752edo69
BRONZE MemberHello,
the board with the two TDA1305T is jusr arrived.
The day after tomorrow we will replace it and I will let you know the result.
27 May 2026 at 21:25 #123753 KolfMAKER
BRONZE MemberGood luck!
29 May 2026 at 13:21 #123763edo69
BRONZE MemberHello,
today I have bad news and good news.
Bad news: after replacing the TDA1305T, the problem persists.
so you were right, being not convinced that the fault was in said Ic.
good news: the techician tried to cool down dhe PCB32 board after the BS9000 became mute, and the sound came back.
now we have to find out which one is the component that overwarming itself cause the problem.
do you have any suspect?
This reply was modified 4 months, 2 weeks ago by
edo69.
29 May 2026 at 13:42 #123765 KolfMAKER
BRONZE MemberHi edo,
That is actually very useful news! If cooling down PCB32 brings the sound back, then the problem now looks clearly thermal and the TDA1305T itself is much less likely to be the root cause.
My first suspects would be:
- voltage regulator(s) on PCB32,
- electrolytic capacitors around the DAC / audio supply section,
- local decoupling capacitors,
- mute / output stage transistors,
- bad solder joints or hairline cracks,
- possibly a clock/buffer component around the DAC section.
Suggested steps:
I would not cool the whole board anymore, but use freeze spray very locally, component by component.
Start with the power regulators and capacitors around the DAC/audio section, then the muting/output stage components, and finally any logic/clock components feeding the DAC.
Also, it may be worth checking the DAC supply rails again with an oscilloscope, not only DC voltage. A regulator or capacitor can still show 5V DC while having noise/ripple or instability when warm.
1 June 2026 at 17:49 #123804edo69
BRONZE MemberHello
Thanks again for all your help.
The issue is increasingly complex.
As you already know, after replacing the Ic TDA1305T, the issue is still present.
These are today’s updates:
First of all, we were unable to find a can of spray cooler, so we did the test with a can of simple compressed air.
We ordered the spray cooler online, and it will arrive soon.
In the meanwhile, we noted that cooling the capacitor C403, the sound come out back; we replaced it, but nothing changed.
Then we replaced the capacitors C401 and C403, ’cause even cooling them, the sound come out back. But the problem persists.
We noted that wnhen the sound disappears, the TR405 output voltage starts to oscillate (from 3,08V to 3,22V, more or less), but we did not find what C403 got to do with TR405 .
So we are taking a pause due to the arriving cooler, that will allow us to make more accurate tests.
That’s all for the moment.
