Home › Forums › General Discussion & Questions › General Discussion & Questions › Playmaker configuration
- This topic has 4 replies, 4 voices, and was last updated 3 years, 1 month ago by
Guy.
13 February 2023 at 05:44 #43826
Giorgione
BRONZE MemberI just bought a slightly used Playmaker and finally managed – after many attempts – to set it up wirelessly, using “easy wireless setup” was the only method that worked for me eventually. Network indicator is solid white now.
The PM shows up in B&O setup up, even though only filed under Settings/Products but neither can I change the devices name, even though the modification option opens up but doesn’t safe the new name, nor can I access the configuration menu.What am I doing wrong? The B&O setup app connection with my BV11 works flawlessly, even though it’s of no use for me. Thanks for your help!
13 February 2023 at 17:55 #43827 GuyModeratorI seems to remember that I had problems renaming the PlayMaker if I included symbols (such as &) in the new name. It was a few year’s ago so I could be wrong!
14 February 2023 at 02:03 #43830 GuyModeratorThe new name has an hyphen.
I just found my very old post on the subject – it was specifically the ‘&’ sign that another app had problems seeing:
https://archivedforum2.beoworld.org/forums/p/8941/78595.aspx#78595
14 February 2023 at 08:39 #43828 kuyttendaeleMemberIf my memory serves me right then I did the initial setup wired. In the web interface of the PM I could change its name.
Karel.My B&O Icons:
14 February 2023 at 13:16 #43829 matadorModeratorJust tried right now from a wireless connection to the Playmaker’s own web page and it did work. The new name has an hyphen.
