Home › Forums › Product Discussion & Questions › BeoCenter › Pays to take more photos mystery part?Beocenter 9500
- This topic has 4 replies, 3 voices, and was last updated 3 years, 9 months ago by
trackbeo.
24 June 2022 at 01:07 #35702
lightitupBRONZE MemberHello BEO team help required finally replaced belts and rubbers in Tape Cassette, but unit has been apart for some time I have a foam stepped washer that for the life of me has no obvious home?
24 June 2022 at 09:53 #35703 GuyModeratorAre you sure that it’s from the Beocenter and not another project? I don’t recognise it from having dismantled mine (but I have the earlier single-belt tape deck) and I can’t see anything similar in the Service Manual’s limited exploded parts diagram.
24 June 2022 at 22:25 #35704 lightitupBRONZE Memberyeah that is a possibility I do have some Penta 1s apart and (two cats?) but was pretty random as there’s a slight indented in the chassis for the tape pulley that in fits perfectly into, put obviously can’t go there.
thanks heaps as I always say, if you can put back together with less parts, you’re better than the design engineer ?
I’ll have look at some manuals, it does fit here but serving no purpose that I can see.
24 June 2022 at 22:26 #35705 lightitupBRONZE Memberyeah that is a possibility I do have some Penta 1s apart and (two cats?) but was pretty random as there’s a slight indented in the chassis for the tape pulley that in fits perfectly into, put obviously can’t go there.
I’ll have look at some manuals, it does fit here but serving no purpose that I can see. Thanks Guy
25 June 2022 at 16:08 #35706 trackbeoBRONZE MemberTalking through my hat here, but that part *looks* like a mounting shock bumper: A narrow bolt/machine screw goes down into the whole thing thru the bottom (narrow) hole, tightening a flat metal washer which fits (stops at) the middle hole/shelf. Having now attached this bumper to the chassis, the top (largest) hole either supports a flat board that is affixed elsewise, or has an inverted screw on it, which slumps into the upper indent/saucer. Or invert it, if you have a screw fitting into an upper board or chassis part that rests on a base: it’s a rubber foot that can be firmly fitted to one item but without squishing the whole thing making it pointless. The key will be whether you also have an extra screw & washer lying around!?!
P.S. Just looked at your newer pic; not sure I would ever rest a mechanical part onto a (flexy) circuit board, thus agree with you that doesn’t look right.
