Home › Forums › General Discussion & Questions › General Discussion & Questions › No software updates on various B&O products: Essence MK2, Beosound 1 MK1 …
- This topic has 9 replies, 2 voices, and was last updated 3 days, 10 hours ago by
27 April 2025 at 10:42 #65337GOLD Member
strange phenomenon which I’m unable to solve:
Multiple devices do NOT get software updates. Every check with the B&O app or through their webinterface says that I already have the latest software.Latest software from B&O should be 6.x (April 2025) but the affected products are all a few software versions behind (2.x).
4 Affected products:
– 2x Beosound 1 MK1
– 2x Beosound Essence MK2Beoremote Halo or the M3s are on the latest software without any problems.
Is there any solution for this?
27 April 2025 at 10:48 #65339ModeratorHave you checked against the latest listed releases here?ย https://update.bang-olufsen.com/products
According to page 3 of the link, Essence Mk2 latest update was released 9 Apr 25.ย I will connect my Essence later and check that it updates OK.
Location: Warwickshire, UKMy B&O Icons:27 April 2025 at 10:52 #65341GOLD MemberThanks for the helpful links of software releases.
Both Essence MK2 are stuck on version 2.x while the B&O website shows your mentioned April 2025 update with version 6.x
But the Essences and the Beosounds will not recognise that there is newer software available. All stuck a few versions earlier.27 April 2025 at 11:03 #65343ModeratorI just connected my Essence – it is showing as avail:
Location: Warwickshire, UKMy B&O Icons:27 April 2025 at 11:07 #65345ModeratorAnd has successfully updated to version 6.0.57105.69827962
Location: Warwickshire, UKMy B&O Icons:27 April 2025 at 11:09 #65347GOLD Membermine doesn’t. Still says software is up to date.
27 April 2025 at 11:16 #65348ModeratorThat’s a bit strange.ย Are you sure it is connected to the network, and that the network has access to internet?ย You could maybe connect straight to your internet modem/router using RJ45 and try again.
Location: Warwickshire, UKMy B&O Icons:27 April 2025 at 12:22 #65351GOLD MemberThat’s a bit strange.
Exactly ๐
Yes, all devices are connected to the internet, play multiroom audio, streaming B&O radio from the internet etc.
27 April 2025 at 12:31 #65354ModeratorHave you got ‘Power Saving’ turned on in Settings?ย Apparently that ‘limits certain functions’, so I suppose it could include SW update.
You could also try a reset to factory settings and set up again.
Location: Warwickshire, UKMy B&O Icons:28 April 2025 at 06:50 #65363GOLD MemberGood morning,
– Power savings where off
– reboot didn’t helpDid a factory reset on all 4 devices yesterday and set them up again. That finally helped: All 4 are on software version 6.x april 2025 now.
Thanks for helping ๐
