Home › Forums › Product Discussion & Questions › BeoCenter › Newbie with beocentre 9300 query
- This topic has 6 replies, 2 voices, and was last updated 2 years, 4 months ago by
Guy.
13 November 2023 at 03:25 #50424
Simonjrwinter
BRONZE MemberHi there,
I’ve managed to buy myself a beautiful B&O setup owned by an older couple since new and in pristine condition. It’s a Beocentre 9300 with a pair of RL6000 speakers and a BEO4 remote.
the sound is wonderful and I’m really pleased with it. However while the remote control turns on And off the unit and enables me to switch between sources and adjust the volume, I’m unable to pause or otherwise adjust the cd/radio using any other buttons. I’ve looked through my phone camera and can see the ir working when I press buttons, but am unable to do anything else. Do I have something faulty? Am I missing something? Any advice greatly appreciated.
thank yousimon
13 November 2023 at 04:33 #50428 GuyModeratorTwo further thoughts:
BC9300 has a ‘lock’ that prevents you from changing channel/track etc when recording to cassette. Could you have inadvertently started recording?
Do you have a plasma TV switched on in the room – problems have been caused in the past! See here: https://archivedforum.beoworld.org/forums/t/22716.aspx
(In that linked thread you could also try Peter’s option setting solution in the third post, but I don’t think that this is the problem)
13 November 2023 at 15:43 #50425 GuyModeratorHi and welcome to Beoworld!
A strange fault! Can you do all the operations OK from the BeoCenter’s touch panel?
Also is the remote a standard Beo4? (not the ‘Hotel’ version which has reduced functionality). It should work fine with any of the following – which is yours? (click to enlarge and check the button labels)
13 November 2023 at 15:53 #50426Simonjrwinter
BRONZE MemberThank you Guy,
- It look to be the same as the first one although it doesn’t have the two little black dots on the yellow arrow next to the “go” button, simon
13 November 2023 at 16:20 #50427 GuyModeratorThat version should work fine, especially as you can see it transmitting. The black dots will have worn away with use.
Did you try the BeoCenter front panel? Pressing the numbers while playing a CD should jump to that track, and you should be able to search for radio stations, for example?
Then try pressing numbers on the remote while a CD is playing for the same result. The up and down arrows on the remote should step through tracks also. Try holding the remote very close to the remote sensor.
I must admit that most of my experience is with the earlier/similar BC9500. I have read on the archived forum that BC9300 could suffer from remote control problems, but I find it strange that only some functions are working!
13 November 2023 at 16:48 #50429Simonjrwinter
BRONZE MemberBrilliant!
I tried the option thing and it all now works. Thank you so much. I love it even more now!
simon
13 November 2023 at 16:54 #50430 GuyModeratorBrilliant! I tried the option thing and it all now works. Thank you so much. I love it even more now! simon
Great news! Glad you got it working!
I would have suggested the ‘Option Setting’ earlier but was hesitant because you said some functions did work with the remote – normally when in Option 0 the remote will do nothing at all!
Anyway, stick around and enjoy the Forum – there’s lots of useful advice for when you add to your collection ?
