Home Forums Product Discussion & Questions BeoSound Theatre New product launch – beosound theatre?
Viewing 20 posts - 1,321 through 1,340 (of 1,347 total)
  • #38562
    Carolpa
      I have a BLC connected to a Beomaster 7000. I can use the B&O app to use the Core to select and play a Beomaster source but if I use the BLC in the App it sits there for a few moments and the drops back to no source. The BLC is set to VMaster. What am I doing wrong.
      Nothing….
      but change the option of the Beomaster 7000 to 1 or 2 and try again.
      #55374
      splud
        Has anyone lost the radio functions from both the beoremote 1 and the app? I really don’t wont to do another reset!
        Thanks 🙂
        #55443
        Severed_hand_of_skywalker
          Oh my god after over a month with no updates they have updated the beta app.  The Theatre screen is more compact now. Haven’t found any new features though.
          IMG_0143
          #55447
          YannChris
          FOUNDER Member
            All sources disappeared in NL/ML Converter.
            Regards,
            Yann.
            IMG_3983
            #55448
            YannChris
            FOUNDER Member
              It seems to be the same for Theatre
              IMG_3985
              #55565
              Sandyb
                Willie (of the podcast fame) went through an interesting Theatre Speaker Setup – Best Practices document.
                Its not super long – 15 slides, but if anyone missed it, its worth going through I think.
                In my case, there were setup / settings tweaks that I need to make, at least to be more in line with the suggestions.
                And for my second Theatre (standalone), the speaker role allocation that resulted from the setup/mic calibration process was certainly wrong / out of line with their suggestions for Standalone Theatre setups.
                Additonally, a further implication of this was that they suggest different listening positions (i.e different allocation of speakers) for Atmos and Non-Atmos content.  Not something I had done (at least for my standalone THTR room).
                Anyway, the document / slides are available on Discord under the BeoKnowledge section / Documentation.
                #56177
                BeoMedia
                  It might just be me late to discover this.
                  But, when I for the first time added Beolab Receiver 1’s to my Theatre I was given the option to choose which speakers were connected to these.
                  At the time I added the above my Theatre was running v3.4.1 (but afterwards updated to v3.4.2).
                  I recall other users requesting the option to being able to specify which speakers they had connected to their Beolab Receiver 1’s hence I post my findings.
                  #56247
                  BeoMedia
                    Willie (of the podcast fame) went through an interesting Theatre Speaker Setup – Best Practices document. Its not super long – 15 slides, but if anyone missed it, its worth going through I think.
                    Interesting – where do I find this please?
                    #60772
                    BeoMedia
                      How to use “Virtual Speakers”?
                      I have activated the function of Virtual Speakers in my otherwise 5.1.2 setup. As per below copy-paste from the Technical Sound Guide and tonmeister.ca, these “virtual speakers” are actually produced from the left and right front-firing speakers go the Theatre. However, when I active these “virtual speakers” while in 5.1.2 these left and right from-firing speakers of the Theatre still appear to be turned off when I go into the settings.
                      1. Am I meant to manually turn these these left and right front-firing speakers on in order to use “Virtual Speakers” function and if so what role do I designate to them?
                      2. Or, once I assign use of the “Virtual Speakers” is that all and do the left and right front-firing speaker create this virtual feature despite the settings show they are turned off?
                      “Beosound Theatre gives you the option to choose Virtual Loudspeakers that appear to be located in four different positions: Left and Right Wide, and Left and Right Elevated. These signals are actually produced using the Left and Right front-firing outputs of the device using this combination of binaural processing and crosstalk cancellation in the Dolby Atmos processing system.”
                      Source: https://www.tonmeister.ca/wordpress/2022/11/28/beosound-theatre-virtual-loudspeakers/
                      #60774
                      YannChris
                      FOUNDER Member
                        Here it is. Well done, Willie, for creating this helpful guide.
                        #60807
                        BeoMedia
                          Thank you for the guide, very useful and I have now printed it off.
                          According to this guide it appears that “virtual speakers” are really for single user applications and without other speakers connected.
                          As a side topic I can’t help but feel it is a shame that all of of the speakers in the Theatre, except the centre speaker, are meant to be turned off when you have external speakers connected (L+R front and rear). Do you also have most of the speakers in the Theatre turned off in a surround setup with external speakers?
                          #60810
                            I repurposed my Theatre front L/R to act as centre subs.
                            #60811
                            BeoMedia
                              Great idea – wasn’t aware that you could repurpose these drivers. Did you set them both to center subs? (on the diagram it would appear that is a rear center sub)?
                              I’ve just set them to “Subwoofer left” and “Subwoofer right”. I hope that will sound well.
                              I already have a Beolab 2 subwoofer set to the role of “Subwoofer centre”.
                              #60850
                                Not sure Sub Left/right makes much sense as they are both in the dead centre. Maybe list them both to be Sub/centre and the Beolab 2 to Sub left or right.
                                #60858
                                YannChris
                                FOUNDER Member
                                  Hello,
                                  Using the last Beta application, I have a problem with the Role assigment screen.
                                  After selecting the role, I do not find how to get out of the screen (see picture below) to go to the next speaker.
                                  All I can do is killing the app and of course the selection is not memorized.
                                  Do you have the problem or am I missing something?
                                  2024-11-10 IMG_5288
                                  Thanks for your help.
                                  Yann.
                                  #61926
                                  André Nielsen
                                    Hi Yann,
                                    I have the exact same problem, and I don’t use the beta version.
                                    Have you found a solution ?
                                    Regards,
                                    André
                                    #61927
                                    BeoMedia
                                      Hi there,
                                      I am not on any beta version either and I also experienced a similar issue. The only solution that worked for me was to factory reset the Beosound Theatre and start over. Then it all worked. My guess is all the updates have made the previous setup and settings corruptive.
                                      Factory reset is not as bad as it sounds – it is much quicker than to waste time on trying to make it work by not performing a factory reset.
                                      #61930
                                      YannChris
                                      FOUNDER Member
                                        Hi Andre,
                                        I found that the problem seems to be related to a setting in my iPhone.
                                        The “large character size” in the Screen Zoom of the “brightness and display” settings (at the bottom of the list) was selected.
                                        Turning to the “default” size solved the problem in the B&O app.
                                        I sent this information to the development team through the app but had no reply from them.
                                        Kind regards,
                                        Yann.
                                        #61940
                                        André Nielsen
                                          Wow, that worked!
                                          Thanks a lot:-)
                                          Kind regards,
                                          André
                                          #62087
                                          Kim Christiansen
                                            EDIT: After a factory reset all speakers are added to the list and the issue is resolved. I will leave the post for reference.
                                            Today, I attempted to add a pair of BL3 speakers to my BeoSound Theater setup and would like to hear if other forum members have experienced similar issues.
                                            Previously, I had only used a pair of BL5 without any problems. However, when adding the BL3s, I encountered the following issue: while the test sound plays successfully through all four speakers during setup the resulting speaker list only shows 2 or 3 speakers instead of all 4 after finishing the setup process. The configuration varies—sometimes it lists 1 BL5 and 2 BL3s, and other times 2 BL5s and 1 BL3.
                                            Even worse, when I disconnect the BL3s and try just to setup the BL5s again sometimes only 1 BL5 end up in the list.
                                            Currently, the BL5s are daisy-chained through PL1. For the BL3s, I used Y-splitters. I tested two configurations: both BL3s on a single Y-splitter connected to PL2, and each BL3 on separate Y-splitters connected to PL2 and PL3. In one instance, I managed to get all speakers recognized using two Y-splitters, but I need it to work with just one, as the BL3s will eventually be wired to the back.
                                            To troubleshoot, I tested the setup on two different iPhones and an Android device, but the issue persisted. Any insights or similar experiences would be greatly appreciated.
                                            Images show 4 speakers in the setup and the only 2 in the resulting list.
