Home › Forums › Product Discussion & Questions › BeoSound › Theatre › New product launch – beosound theatre?
- This topic has 1,346 replies, 114 voices, and was last updated 1 year, 3 months ago by
sven-inge.neij.
1 September 2022 at 11:13 #37282
Millemis
BRONZE MemberA YT video, that shows real life pictures of the BS Theatre:
Not that most of you will understand much, but it is nice to see the product at the launch event.
1 September 2022 at 11:25 #37283 vikinguk
BRONZE MemberCould do with a bit more detail on how the tv screen slots in. How stable will the screen support be on the motorised wall hinge version?
Graham
1 September 2022 at 11:36 #37284 vikinguk
BRONZE MemberAnswered by the end of MMs video. Attachment is not a slot but a drop in stand with rear attachment for the screen.
Graham
1 September 2022 at 11:41 #37285 vikinguk
BRONZE MemberThis is the product that B&O should have produced 5-10 years ago. Price is a problem going forward, especially as discretionary spending is going to be hit by the economic crisis.
Graham
1 September 2022 at 11:44 #37286 Millemis
BRONZE MemberTechnical Sound Guide, here we come!
You could start here:
https://www.tonmeister.ca/wordpress/2022/08/31/bass-management-in-beosound-theatre/
1 September 2022 at 12:08 #37287 matador
ModeratorBeing blessed enough with a somebody who would fancy gift me with a Stage if I ever wipe out all the little Yamaha cubes around the sofa, I’d like to know how the it compares with the Theatre in matter of “just” sound, not connectivity or expandability or whatever else. Lest’s say just in terms of sound and “spacialization” (pseudo rear channels).
1 September 2022 at 12:56 #37288
SandybBRONZE MemberHalo works with the Theatre.
Says so in the product sheet.
1 September 2022 at 13:28 #37289 Steve at Sounds Heavenly
GOLD MemberHi Sandyb,
Yes, that is correct. However, it is worth noting that the B&O website and spec sheet are incorrect as the Theatre has 4 wired Powerlink ports (RJ45), not 8 as quoted.
Kind regards, Steve.
1 September 2022 at 13:30 #37290 matador
ModeratorOk,
After watching this thoroughly and to echoes Trackbeo’s post, there is something that bother me. (Bother me as to be taken as from someone who can’t afford it, if it matters. And also from someone who spend time “reverse engineering” wood lamellas on BL18):
The wood strips are so apart you can see the plastic structure holding them. It would work for a far (should I say “ignorant”) point of view, but to client used to B&O perfection it’s look like a pale copy (not even to mention the totally ‘not B&O forward design’).
It’s easy to criticize when I’m not ever gonna buy it, but still, eager to hear what you think.
1 September 2022 at 13:57 #37291 vikinguk
BRONZE MemberIf you think of the BV10 or 11 etc, arguably the cheaper component was always the tv screen itself. As TV’s are now relatively cheap, adding a TV to the BS theatre produces a combined product at about the same price as those previous Beovisions, and at least you should be able to upgrade the screen from time to time without replacing the sound bar.
Graham
PS. But I will stick with the BV11 as my main TV!
1 September 2022 at 20:12 #37292 PGNick
BRONZE MemberSorry, I wasn’t specific.
Can I control an LG OLED (C9 and newer) connected to a Stage or Theatre with the Halo remote? Turn on, channel change, volume etc?
1 September 2022 at 20:38 #37293 Millemis
BRONZE MemberYet another video from the launch:
1 September 2022 at 22:04 #37294
SandybBRONZE MemberThanks for the video.
Looks like this is not coming with HDMI matrix support. Only 1 PUC socket (enabling control of 2 units) is clearly a weakening commitment to PUC.
And while software updates may bring Matrix support, I’m not optimistic at all that it will come.
On the Discord today, while Christian K wasn’t quite sure, and was non committal on this issue, reading between the lines I dont think my conclusion is wrong, especially given his brief comments.
I know many have reduced their use of external sources, but there are surely still a good number who do continue to use them. Matrix integration on all the previous BVs allowed super clean installations, with source boxes etc hidden / out of the room, and just fed to various BVs in various rooms.
Unless that support is added to the Theatre, its a no go for me.
Anyway, lovely product otherwise.
1 September 2022 at 22:41 #37295
beosinceBRONZE MemberI think the Beosound Theatre is a great product from the spec sheet. I love that they included some of the B&O magic with the moving wall bracket and foot. I think the PUC control was reduced due to the abundance of HDMI-CEC, which works great.
1 September 2022 at 23:12 #37296 BeoTool
BRONZE MemberI must have missed it, beosince – where is the magic movement shown?
1 September 2022 at 23:43 #37297
SandybBRONZE Memberyeah, I sort of expected a few years ago for PUC to be de emphasised.
That said, higher end installations with sources in a rack hidden in separate room, and serving one or more rooms with BVs (and therefore the clean installations they often show in their own photos) will not work with the Theatre.
Unless Matrix support is added.
But I am very doubtful – as we can see, the one port is clearly a de-prioritization of PUC / IR.
2 September 2022 at 03:47 #37298
shoutj74BRONZE MemberIntriguing – seems indirectly like a tacit acknowledgement that trying to keep a TV OS up to date is pretty hard for a company the size of B&O to do, the partnership with LG acknowledged. It smarts a bit after spending $20K on a BV11 for it to feel so out of date so quick. Thankfully the addition of smart box Firestick/Google TV/Apple TV rescues it from the second hand sales page on Marketplace.
Did wonder why on the second video they showed an Apple TV in the bracket system. Assume that this is to demonstrate that there is space for this, and also because Dolby Atmos audio is not provided by most onboard AppleTV apps? If this is the case, hope that you can turn the screen off and drive the Atmos audio via the Apple TV box.
2 September 2022 at 11:20 #37299 carolpa
BRONZE MemberHi Sandyb, Yes, that is correct. However, it is worth noting that the B&O website and spec sheet are incorrect as the Theatre has 4 wired Powerlink ports (RJ45), not 8 as quoted. Kind regards, Steve.
Isn’t how you interpreter it? Sure there are 4 Powerlink ports (same as Eclipe, Harmony, BV11, BV14, Avant, etc). But 1 port holds 2 Powerlink connections.
So 2 connections per ports times 4 ports make 8x Powerlink.
2 September 2022 at 13:57 #37300
IgullordMemberSteve, Michael, in “Beotalk Emergency”: https://youtu.be/-GI-3EZVVlI you mentioned the white papers describing the measurement of room acoustics by using a mic in various positions, giving a 3D analysis of the room in terms of frequency peaks and dips, modals/phase etc. Can you please give us the proper links?
Is the new “Roomsense” system more of a “sound management system”, akin to Harman/JBL Synthesis and the upcoming Dirac Sound Field Management system?https://www.audioholics.com/room-acoustics/history-of-multi-sub-sfm/the-birth-of-sound-field-management
https://www.dirac.com/the-arrival-of-spatial-room-correction-technology/
By binding a multi-speaker setup together spectrum/phase-wise, across the designated channel signals, it´s possible to correct phase/modal anomalies in the room even more than the vanilla EQ algorithms, particularly in the sub 500hz region. As far I can see the new Beosound Theatre can control up to 1 subwoofer (7.1.4), maybe using he lower end of the full range speakers to “help” in flattening freq/phase in that lower region?
I´ve seen this link:
-however I think a deeper explanation of this new B&O algorithm would be most welcome.I saw your very interesting interviev with G. Martin: https://youtu.be/IOV0IpgKhX0
He explains the beaming tech behind BeoLab 90, using the various drivers to co-operate by canceling/augmenting each other in the magnitude/phase domain to control the directionality. Obiously he knows the deeper theory of “painting the room acoustically”Maybe the Tonmeister himself could come onboard this one?
Thanks a lot!
Kind regards
Favourite Product: Beosound Theatre, Beolab 28, Beosound Level
2 September 2022 at 17:34 #37301 Steve at Sounds Heavenly
GOLD MemberHi,
If I recall correctly, this link should allow you to browse most of the technical papers submitted by B&O team members that are in the public domain:-
https://www.researchgate.net/institution/Bang-Olufsen
