Home › Forums › General Discussion & Questions › General Discussion & Questions › New Level firmware withdrawn
- This topic has 27 replies, 6 voices, and was last updated 3 years, 3 months ago by
CalvinNorton.
6 July 2022 at 15:16 #35694
LeMirage
BRONZE MemberI lost you in the last part Trackbeo, but thank you so much for your efforts. For the moment I just accept the fact that my master Level in the stereo pair needs a switch of and on every three days.
a different interesting question, maybe Steve has the answer for this since he had a youtube battery with changing the battery.
If using the Level for longer periods (some users maybe always) can one remove the battery and just store it to avoid unnecessary tickle charge ? And still being able to use the Level om AC power only?
6 July 2022 at 19:22 #35695Mbee
BRONZE MemberNew bug on the new software for Level : I can’t do a room calibration anymore, it says that the mic is turned off (but it isn’t).
7 July 2022 at 07:32 #35696LeMirage
BRONZE Member@Mbee, confirmed, just tested and same here….
(Level stereopair)
oh dear, the B&O experience with these speakers can be SO much better if they get their things together on the software department
7 July 2022 at 07:46 #35697 Steve at Sounds HeavenlyGOLD MemberHi,
Another new bug, my (cabled) stereo paired Emerges lost their pairing in the night for the first time ever after updating to 10017 recently. By the way, I don’t suggest removing the battery from the Level when not in use.
Update: I checked from my router and I could see the Ethernet connection to both speakers, but they weren’t able to pair within the B&O app, only the primary speaker would play. I removed both speakers from my account and added them again, went back through the setup process and they are working.
I will monitor their behaviour and I have reported the bugs, lets see if we get a response.
Kind regards, Steve.
7 July 2022 at 17:20 #35698 carolpaBRONZE MemberLol, no it’s a different red dot, bigger and clearly stating the device is “offline” and the app can’t find the device…. (but the Level still is able to stream and being controlled from the buttons on the Level, not via the Halo nor the app)
I think I’m the one to LOL………
I do recall I have seen this dot (I remembered after your reply), but I hardly ever see it
8 July 2022 at 17:59 #35699Mbee
BRONZE Member@Mbee, confirmed, just tested and same here…. (Level stereopair) oh dear, the B&O experience with these speakers can be SO much better if they get their things together on the software department
I’ve checked : I can do a calibration when I’m in radio or deezer mode, but not in Bluetooth (Level alone, not stereo paired)
17 July 2022 at 15:38 #35700LeMirage
BRONZE MemberRoom callibration seems to work again…..
strange. Maybe the multiple reboots of both Levels helped….,
still on firmware 1.8.10017.12375
24 December 2022 at 22:55 #35701CalvinNorton
BRONZE MemberAs soon as the official developers release updates, I recommend installing it immediately. Since updates are made for a reason, at least improved security criteria and software optimization. At work, we use a CRM system that was developed by https://www.networklondon.co.uk/it-support-essex/. These guys release updates quite often that improve security. With each update, the CRM system only gets better. Our competitors have long been trying to find out what we use to automate the production process.
