Home › Forums › Product Discussion & Questions › BeoVision › HD Sat Module Beovision 7 40 vs 32
- This topic has 4 replies, 4 voices, and was last updated 2 years, 2 months ago by
Anonymous.
30 December 2023 at 01:05 #51736
GuyModeratorI am not sure whether the part is compatible, but even if it is there could well be a requirement for a dealer software update for the BV7-40 – see here: https://archivedforum.beoworld.org/forums/p/30066/239251.aspx#239251
A more modern set-top box is likely to have a better user interface anyway, and possibly better performance especially if you are after DVB-S2 rather than DVB-S.
EDIT: Here’s the fitting guide that was referred to in that other thread: https://beoworld.org/download.asp?file=DVBST-BeoVision7-40MKIII-fittingguide-eng.pdf
30 December 2023 at 12:03 #51735kirin
BRONZE MemberHi all,
I have a quick question: I have a Beovision 7-40 since many years, in use with a Sat Set top box. It is the Mk3, the first with HD resolution (1920 x …), having only the analog tuner.
Now I would have the opportunity to get a rare Beovision 7-32, the latest model, also full HD, but equipped with the Sat Receiver.
Is it possible to put this to my existing Beovision.7-40, are the specs the same?
Thanks and a happy new year!
30 December 2023 at 13:05 #51737Beofile7
BRONZE MemberI cannot answer your question directly but here is my experience…
I also have a Mk3 analogue only BV7/40. The “picture board” failed. It was replaced under warranty and then suddenly I had digital channels! I have often questioned whether there is a Sat receiver in there somewhere too? Short of connecting a dish and trying it I don’t know but via operation there is nothing to suggest that it is not there? It all behaves as if it is there. Unfortunately the digital freqs were changed a year or so ago so i have now lost the digital channels and of course there is no analogue so it is only useful for Chromecasting now?
30 December 2023 at 14:05 #51738kirin
BRONZE MemberGood afternoon,
many thanks for the answers so far. Guy, you are completely right, the issue with sw update sounds logically, also have seen that in the manual (also many thanks!). Then I do not even try this procedure, unless there is anybody who knows how to perform the sw update and who has this tool. I am pretty sure that no dealer is doing this any more.
Have a nice day
30 December 2023 at 16:47 #51739Anonymous
InactiveHi,
the digital board (2boards) are the same for all even
bv 10-32/40 but the holders and cables are different
about sattelite or not the input board of digitaltuner
is 2 different one with sattelite also, the analog
tuner i s a separate board
