Home › Forums › Product Discussion & Questions › BeoSound › Eclipse soundcenter as decoder for Beolab speakers and LG tv
- This topic has 5 replies, 5 voices, and was last updated 2 years ago by
Ianc2.
13 March 2024 at 10:25 #53437
johnjohnny
BRONZE MemberHi everyone,
I have got an Eclipse MK1, bought in early 2020; the TV was turned off for 8 months because I moved to a new town, 2 weeks ago I moved the TV in the new home but now it has some troubles. The TV doesn’t stay on, it powers off intermittently; in addition two vertical lines of pixels remains completely black. The soundcenter work correctly.
I brought the TV to B&O service; to restore the TV I have to replace the motherboard, for the switching off issue, an the panel, for the black pixels, for a total expense of 2400 €.I’m evaluating whether to repair it or not, I’m thinking of buying a new oled LG tv.
In addition of the Eclipse I’ve got Beolab 8000 speakers, Beolab 2 sub, Beolab 3 speakers and a Beosound 35. If I buy the LG tv I would like to continue using the B&O speakers; is it possible to use the soundcenter as decoder between speakers and LG tv? Something like Beosound Theatre…
Otherwise what device do I need?
Thank you in advance.
15 March 2024 at 12:45 #53438Ianc2
BRONZE MemberI have read it is possible to add a later model 65” lg screen with different bracketry and modifying the eclipse aluminum slightly .
i will look at mine this weekend for a reminder , but i believe only hdmi and 1 rj45 connect to the screen , so in theory it could be used with any size/brand screen .
i have a spare Vizio tv i can try this with .
15 March 2024 at 13:54 #53439 RavstedBRONZE MemberYou mind find this post useful
20 March 2024 at 05:58 #53440elicityelicity
BRONZE MemberIn my opinion, you should not fix it. There are many better TVs out there these days and at reasonable prices. If you want entertainment, you don’t need to use TV, you can listen to free phone ringtones on these websites that also provide ringtones.
21 March 2024 at 16:00 #53441pestria
BRONZE MemberGiven the number of people on the site who’ve developed beolink related products (eg MasterDataTool) and also the frustrations with Beocore. I often wonder if they’ve missed a trick by not extracting modules from the B&O TV sets – these units typically have great sound and connectivity options, but screens that get quickly out of date or become uneconomic to repair.
22 March 2024 at 03:00 #53442Ianc2
BRONZE MemberI have read it is possible to add a later model 65” lg screen with different bracketry and modifying the eclipse aluminum slightly . i will look at mine this weekend for a reminder , but i believe only hdmi and 1 rj45 connect to the screen , so in theory it could be used with any size/brand screen . i have a spare Vizio tv i can try this with .
I looked , and yes entirely possible to do this .
I think the thread ravsted linked to that replaces the old oled with a newer model is the best way to go . And what I will do should my panel ever develop problems .
however if you are wall-mounted and do not need a motorized mount etc it can be a totally seperate system using a tv wall-mount to space the panel off the wall inline with the sound center .
It will not look as good from the side though , should you have a doorway next to tv like I have .
The thing I like most about the eclipse is its integrated look , it looks much better than a theater in that regard .
I slso like that it has compartment on the back perfectly sized to integrate an Apple TV 4K .
It will fit other older models , but new 4k is smaller and more efficient .
I went a step further and ordered the correct length power and hdmi cables to make install better … -
