Home › Forums › Product Discussion & Questions › BeoVision › DVB-T2 HEVC external receiver compatible with BV7-55 and Beo4
- This topic has 5 replies, 5 voices, and was last updated 1 year, 12 months ago by
Guy.
1 April 2024 at 11:36 #54037
pleonipiBRONZE MemberHi to everybody
like I wrote in another topic, at least in Italy ( I don’t know if also in other EC countries) there will be a switch-off of DVB-T (the one that is compatible with my BV7-55 MKII DTV receiver) toward DVB-T2 HEVC.
I contacted B&O customer care, they don’t preview any hw/sw update for BV7. In other words, when switch-off will be active, BV7 will no more run like a TV, just DVD player or external sources like Chromecast.
During last year many decoders that are Android TV have been put on the market, like Telesystem UP T2 4K that seems to be one of the best. But of course it cannot be managed with Beo4.
Does anybody know how to let a decoder be inserted into the pucs list and let its codes to be recognized ? Is there an open database ?
Or anybody know of an hevc external decoder already compatible with Beo4 ?
Many thanks for your answers
2 April 2024 at 10:33 #54038SaltineSurfer
BRONZE MemberHumax are selling Freeview HD (DVB-T2) boxes in the UK. I don’t know if they still use InfraRed for remote control though – if so, it might still work with the PUC IR blaster you can plug into the back of the BV7.
2 April 2024 at 11:10 #54039 MillemisBRONZE MemberThis however assumes, that there is a useable Humax entry in the PUC list of the BV7.
Otherweise that has to be loaded into the tv by a B&O technician.
Same goes for any other external box.MM
2 April 2024 at 12:12 #54040 GuyModeratorI am not sure why is says it’s made for Scandinavia, but perhaps this would work:
https://shop.oneremote.dk/shop/69102-bo-dvb-t2-aerial/4171-dvb-t2-iii-boxer-tv-modtager/
But if there is a Humax box in your PUC/STB list then I would look for a Humax DVB-T2 receiver as suggested above. I used a Humax HD-FOX-T2 for many years with my BV3 and then BV6-26. There is also the HDR version for recording – lots available on Uk eBay who may post to Italy.
2 April 2024 at 13:03 #54041 RavstedBRONZE MemberIn Scandinavia we do not use the HEVC codec/compression. A Danish T2 receiver does not work in e.g. Italy or Germany unless you can read in the specs that HEVC is supported….
2 April 2024 at 14:48 #54042 GuyModeratorIn Scandinavia we do not use the HEVC codec/compression. A Danish T2 receiver does not work in e.g. Italy or Germany unless you can read in the specs that HEVC is supported….
I see. I just had a look at the spec for my HD-FOX-T2 and I don’t think HEVC is supported. Looking at Humax’s Italian website this model would work: https://it.humaxdigital.com/product/digimax-t2/
It has IR remote which is supposed to be a learning remote, but I doubt it would learn the B&O IR frequencies. You could get lucky and find that it is controlled by one of the older Humax IR PUC/STBs.
