Home › Forums › Product Discussion & Questions › BeoLab › DIY Beolab 8000 Wood frets (STLs included).
- This topic has 191 replies, 92 voices, and was last updated 2 months ago by
skolesen.
31 August 2024 at 13:44 #58759
matador
ModeratorHi everybody,
The STL files were available to download to everyone free. The change of platform for the forum, I beleive, has broken some links or made unavailable attachments, thats why you can not see the stl files that use to be there.
In the meantime, I’ve seen the clamps I designed, available for sale everywhere even to the point they give the Ikea-like guide I’ve also designed.
The ownership of the clamps may be questionnable (anybody trying to made his own clamps will inevitably end with that design…) but the instruction diagram is clearly a steal.All that being said, I just can’t answer each individual request and send the STL’s by mail.
And this without saying that some request are at least “dry” and sometimes even rude.So I’ll check with Multicare if the attachent feature is off or if I just need to reupload the files, but until then you all just gonna have to wait or, if you’re in a hurry, buy them to a fellow that did download them for free some month ago.
Sorry if I’m bitter, and sorry you all, nice people, have to undergo the consequences.
M
31 August 2024 at 17:49 #58779 multicareGOLD MemberSo I’ll check with Multicare if the attachment feature is off or if I just need to reupload the files, but until then you all just gonna have to wait or, if you’re in a hurry, buy them to a fellow that did download them for free some month ago.
Files have been added to the original post, some of the unknown filetypes were not added correctly.
1 September 2024 at 08:31 #58794 matador
ModeratorThank you.
2 September 2024 at 13:56 #58801n-time
BRONZE MemberI found these in my downloads, not sure who is the author. Maybe it will help some of you.
Matadoration: External link removed.
2 September 2024 at 14:38 #58803n-time
BRONZE MemberLink deleted, see my post below.
2 September 2024 at 16:38 #58804 multicareGOLD MemberI found these in my downloads, not sure who is the author. Maybe it will help some of you. *Edit: I uploaded it to Makerworld.
Hi, thanks for this but please see post 58779, we added the files to the original post.
5 September 2024 at 13:28 #58881 matador
ModeratorI found these in my downloads, not sure who is the author. Maybe it will help some of you. *Edit: I uploaded it to Makerworld.
Now it’s done but the least would have been to ask permission to do that.
If I’ve decided to make them available to Beoworld only and not on any random STL files platform, its for a good reason: Beoworld gives and you give back to Beoworld.
If you take time to read the full thread you’ll know that those clamps have been stolen again an again and even to be shamelessly put on sales.
First it’s a steal and a scam and second, it takes trafic away from Beoworld that needs people to come here for clamps and start a new passion that will feed the forum and then all of us.Anyway, if you’re sensitive to all of that, please remove your upload. Me as moderator will delete your link since the files are now again available on the first post.
Regards.
8 September 2024 at 11:34 #58952yongjiang li
BRONZE Memberthanks for the file, perfect result after half day of working
8 September 2024 at 11:34 #58953yongjiang li
25 October 2024 at 22:46 #60440Ton Versteeg
BRONZE MemberHi All,
Do other people have the issue that the STL are very tiny in Bambu Studio? The Cover seem to be a normall size.
All hyped to do this project, hopefully I can pick up a set of 8000’s this weekend.
21 November 2024 at 10:50 #61071Behrad Moini
BRONZE Member21 November 2024 at 17:04 #61076 Severed_hand_of_skywalkerBRONZE MemberHow does it look from the top down, though? Is there a significant gap between the wood and the metal? The others I’ve seen appeared to be poorly fitted.
23 November 2024 at 20:39 #61113 matador
ModeratorDon’t know what you mean by “poorly fitted” but what pushed me to design this clamps was that the ones on the market have a bulgy look, too round, too thick, too ‘not elegant’. So I tried to reduce the arc of the grid as much as i can.
In the first post you have have a top view and also the template for the cardboard top plate that should give you an idea of the whole render.
Maybe it can answer your question.
Cheers.
1 January 2025 at 19:59 #62161H Nebs
BRONZE MemberHaloo
i want to buy 1 set 3D printes for my beolap 8000 speaker
best regards
Henrik
mail: nebs@duck.com
3 January 2025 at 18:24 #62225H Nebs
BRONZE Memberhello
I have tried loading stl files in my printer, but they are only 10 mm
What do I do?The only one that comes out in real size is the top plate
best regards
Henrik
mail:nebs@duck.com
4 January 2025 at 10:22 #62245 matador
ModeratorRead the whole thread, there is something somewhere about scaling the parts.
22 February 2025 at 07:30 #63916Spout
BRONZE MemberHello guys
I am really interested in building these wood cover and this seems to be a super convenient solution.
Can you tell me how to download the file ? Not sure where to find on the forum.
And thank you Matador for sharing it !
5 March 2025 at 00:03 #64322gj777
BRONZE MemberDear Matador,
Could I please have your input.
I’m in the USA and 4mm sticks are not very common here. The closest is 1/8” or 3.2 mm. Do you think 3.2 mm would work? Or would the fret be too weak? If yes, if I glue the larger side pieces will the fret be strong enough? I’m also thinking a thinner stick should also have less effect on the sound. The sticks here are only available in locations far from me and the shipping costs are high. So I hope to have your input before buying the wood. Which is Basswood – a very light wood used in building model airplanes.
thank you for your patience in helping so many of us with your great project!
Gregg
5 March 2025 at 06:42 #64325 matador
ModeratorHi Gregg,
3.2 mm should work. The only difference I may foresee is the space between the blades larger than the blades themselves. I dont know how it would affect the whole look.
The fret doesnt have to be strong or stiff. It sleep on the speaker and you dont really move it after that.
Now if the wood tends to bend or not be perfectly right, you can just add more middle clamps.Location: Paris France
7 May 2025 at 14:32 #65488Samuel Vesterlund
BRONZE MemberHi there,
Does anyone have the 5 mm files? I can’t seem to find them in the original post from @Matador.
Also:
Where did people in Denmark buy their wood?
Favourite Product: Beolab 8000
