Home › Forums › Product Discussion & Questions › BeoLab › DIY Beolab 8000 Wood frets (STLs included).
- This topic has 191 replies, 92 voices, and was last updated 2 months ago by
skolesen.
4 August 2025 at 22:44 #68298
Kyle Hu
BRONZE MemberExcellent, thanks for sharing this!
4 August 2025 at 23:05 #68303Samuel Vesterlund
BRONZE MemberHi everyone,
Since the 5 mm files are no longer accessible, I decided to design my own. They’re essentially a replica of the original design, but modified to fit 5 mm wooden fessets. I’ve tested them, and they work great!
Feel free to email me at Samuel.Vesterlund@outlook.com if you’d like the files.
Big thanks to @matador for the original design – couldn’t have done it without your work.
For the wood, I used pine from Bauhaus Germany, but they also offer oak if you order it.
Here are some pictures!
Favourite Product: Beolab 8000
9 September 2025 at 09:24 #69497lars.kirkegaard
BRONZE MemberHi 🙂
When I put in the files to my AnyCubic 3D printer, it become very small. How many % should I scale it up? Does anyone have same problem?
10 September 2025 at 18:06 #69536 matadorModeratorHow many % should I scale it up?
Common Issue, yes. Documented in the thread. I can’t rememnber right now but it must be like 10%, 100% or 1000% = A multiple of ten.
Again, the size of the final object is shown in the thread: please read it all!Location: Paris France
12 September 2025 at 15:17 #69571nitro2
BRONZE Memberanyone for making a similar design to the penta’s ??
5 November 2025 at 03:52 #70927alan.blok
BRONZE MemberHi Tutti Vini,
Wat mooi gedaan, echt prachtig resultaat! Mag ik vragen welk hout je hebt gebruikt? Ik zou graag dezelfde kleur en look willen bereiken als die van jou.
Bedankt alvast!
5 November 2025 at 16:22 #70936Wouter van de Weerd
BRONZE Member26 January 2026 at 14:46 #72869Guy Menchik
BRONZE MemberDear Matador ,
Great job ! I really like the explanation and the design , already printed the 3D clamps .
Per your instruction the wood lamellas are 4mm thick but the notches on the clamp are 5mm so would the wood be a bit loose ?
Tnx
Guy
Favourite Product: Beoplay A9
6 February 2026 at 21:27 #73324Paulo Scmitt
BRONZE MemberGrüezi Guy
Firstly thanks to Matador for the original files and the amazing Scandinavian furniture company style instructions. Fantastic!!
I’ve just been looking at the files myself, they need to be scaled up 10x for those who did not work it out already. The slot width measures about 4.3mm wide in CAD so (depending on 3D print tolerances) should give a slightly loose fit for a 4mm thick wood strip. So not sure why you measure 5mm Guy, I think that would be too big for the 4mm thick wood.
It could be that print tolerances are too high, also in my limited 3D print experience it is a good idea to put a small radius on all sharp edges. 0.5mm should be enough to help give a better print. That could affect the finished part quality and size.
regards
Paul
24 May 2026 at 19:52 #123733Bubu Bogdan
BRONZE MemberHello,
First of all thank you for the great ideas and contributions and for the 3d files, I just got a beolab 8000 and a beosound 9000 (have to repair the laser thou ;-( ) and will first open the speakers to clean them up, recap (got a bit of “hisss” in them) and then hopefully install those types of grills over them 🙂
I recently saw a version online that has 3d printed clamps with magnets like in 2 pieces, one piece stays on the speaker (like 3-4 of them in total) and the other piece comes over those that remain on the speaker and attach themselves with powerful small magnets.
This makes removal for cleaning etc very easy and also changing between multiple sets of grills easier.
Anyone has those designs by any chance?
I found them on a FB group from a guy named “Leslie Nelwan”, not sure if he’s around here.
Thank you again !
This reply was modified 3 months, 4 weeks ago by
Bubu Bogdan.
This reply was modified 3 months, 3 weeks ago by
Bubu Bogdan.
You must be logged in to view attached files.15 July 2026 at 18:24 #124552Vick NM
BRONZE MemberHello everyone,
I am new to B&O, and just picked up my first set of 8000s— and am looking to update them similar to tuttivini. I cannot find the .stl file however. @matador, would you be able to send the stl file to me? I would really appreciate it. Thanks so much!
Favourite Product: BeoLab 8000
21 July 2026 at 06:45 #124614 skolesen
GOLD MemberHi Vick NM,
Wellcome to Beoworld.
The .STL files are included at the end of Matador original post on “page 1” and you have to be logged in to see them. Hope this helps.
/steffen
