Home › Forums › Product Discussion & Questions › BeoLab › DIY Beolab 8000 Wood frets (STLs included).
- This topic has 178 replies, 81 voices, and was last updated 2 months ago by
22 January 2023 at 12:30 #36843BRONZE Member
@matador Wouldn’t it be better looking if you also design/print (with black PLA/PETG/ABS) the top panel instead of using piece of black cardboard cut to shape?
Would it be possible to add this to the design?
What thickness (in mm) would give us the best/flush look?22 January 2023 at 14:10 #36844Moderator
@matador Wouldn’t it be better looking if you also design/print (with black PLA/PETG/ABS) the top panel instead of using piece of black cardboard cut to shape?Yes it maybe would be. The thing is I dont undertsand anything in PLA/PETG/… plastics and I rely on an remote 16, hormonal dependent teenager for the printings. Then as soon as the wood grills were on the speakers I stopped research!
Location: Paris France22 January 2023 at 16:55 #36845drmichi
BRONZE MemberYou might have a problem to 3D print a nice and smooth surface, for sure you need to grind and paint it afterwards. I also used the black paper as a quick fix 🙂
I personally wouldn’t go for a flush top panel, since the design really adds some nice details if the wood covers are 2mm up, but still lower than the chrome head.
5 February 2023 at 18:02 #36846stivenmar2
BRONZE Memberhi mate can you make me those 3d Plastic wood holders for two speakers will pay you of course ,because i don’t have 3d printer the rest of the work will do it by my self thanks let me know please ha e a good one
12 February 2023 at 12:51 #36847sharknm
BRONZE MemberThanks for these. It is just amazing. Can please someone do it for 6000’s?
27 February 2023 at 06:54 #3684827 February 2023 at 07:27 #36849ModeratorThe 4mm clamps are designed for 4mm thick wood bits.
The 5mm clamps are designed for 5mm thick wood bits easier to find in nothern countries it seems.
Location: Paris France2 March 2023 at 05:06 #36850sprockett
BRONZE MemberI was comparing them and it appears the “curve” is smaller and flatter on the 4mm vs the 5mm?
Does this mean visually it will look like a bigger and more curved?
2 March 2023 at 08:20 #36851ModeratorThe 5mm model was developed by another member from my design, to fit local wood supply so I can’t really say. Nevertheless, there is indeed a strong link between curve, depth, wide, number of lamellas and their thickness, so it make sense the curve is more important.
And yes it will result in a less thinner speaker. To what extend ? I dont know.
Location: Paris France17 March 2023 at 19:16 #36852jesnystrup@gmail.com
BRONZE MemberHi everybody..I need help ..i have a question ..What is the true size of the top lid in the pdf document ..
I cant get it to work on the printer since its a long pdf doc ..I cant get the scaling right so if anybody have a stl or size doc for the normal printer or 3d printer or the laser file for the cutter can you please share it
Thanks.
20 March 2023 at 20:32 #36853BRONZE MemberWhat kind of ‘brackets’ are used on the beolab 8000 on this picture (the right one)?
This one hasn’t got a top-plate, so looks more like the original beolab 18. I like this al lot!
20 March 2023 at 22:04 #36854ModeratorIt’s not about the brackets, it’s about the lamellas. They are rounded and must be L shaped at the top. I think they’re also very thin (not deep). All this to say that this solution involves a lot of woodwork and is certainly not 50€. But indeed the result has nothing to compare with my cheap solution.
Location: Paris France21 March 2023 at 09:34 #36855BRONZE MemberYou discovered the secret! I think you are correct. The lammellas have a L-shape on top. Looks good, but indeed a lot of woodwork…
I’m going to print your brackets next week and buy all the needed wood. We are going to make 2 sets. For my dad and for myself.
23 March 2023 at 10:10 #36856BRONZE MemberHi all Here in Denmark it seems that 5mm frets are more easily available. I have therefore created clamps based on 5mm frets. I have created new STL files based on Matadors original clamp design, but slightly changed. They are 5mm wide, a litte deeper in the groove and more curved. There is also 3 clamps now. A Top, Middle and Buttom. The Top and Middle clamps rests on the speaker structure – and the Buttom just floats. You can choose to replace the Middle with the Buttom clamp if you wish. The clamps were made in Fusion 360. I have provided both the Fusion 360 files and the STL files. That way you can adjust the clamps to your specific needs if needed. Credits go to Matador for starting this. He also approved to add the files here.
@Lemme : Do you have pictures of beolab 8000’s with your 5mm brackers/final result looks?
I’m interested in how it looks compared to Matadors 4mm brackets, because the ‘curve’ looks smaller on the 4mm brackets…23 March 2023 at 13:09 #36857BRONZE Member@matador Why are the slots in the 4mm only ~2.2mm deep?
Is this enough to ‘clamp/hold’ the lammellas firmly?23 March 2023 at 21:15 #36858ModeratorAt first they were meant to be a cradle to hold the sticks with a drop of glue.
But in the end the sticks did click in and stay firmly in place without glue.
The groove is not deep to stay invisible between the lamellas.
Location: Paris France27 March 2023 at 14:40 #36859jackie0
BRONZE MemberHi Matador and community,
Thanks a million for sharing and uploading the files, this is amazing.
Not knowing anything about 3D printing I sent the STL files to a local printer. He says that the files do not have any measurements.
@styppen asked the question before and was also kind to share mm measurements for x,y and z. But what do these represent?Could someone please advice how I communicate the measurements to the printer?
Many thanks in advance and apologies for perhaps asking a stupid question.
Best regards from Sweden
J
27 March 2023 at 19:30 #36860ModeratorThe screen capture and measurement from styppen are right.
It’s the “bounding box” size of the whole object.
For whatever reason my export do not carry scale information and you have to scale it depending on your printer device. But it should usually be a round factor: x10, x100, x1000.
Anyway, give your supplier the bounding box size and it should work.
Location: Paris France31 March 2023 at 17:22 #36861kronzilla
BRONZE MemberLooks very nice. I discovered, the chrome speakers looking much nicer with the wooden frets. Wirh the black covers they looking outdated. I have a black pair and that pair looks good with the original covers.
How can i obtain the files to make the fronts? I don’t know nothing about 3d printing but gonna ask a friend.
31 March 2023 at 22:22 #36862jesnystrup@gmail.com
BRONZE MemberThe files are here on this thread on page 1
