Home › Forums › For Sale & Wanted › For Sale › Conversion kit Beolab 4000 to Sonos electronics with Trueplay
- This topic has 18 replies, 9 voices, and was last updated 2 years, 4 months ago by
Keith Saunders.
21 June 2023 at 08:46 #47292
carljhBRONZE MemberConvert your old and maybe broken Beolab 4000 speakers to a Sonos speaker Gen2 with Trueplay for optimal sound and keeping the nice B&O design. The kit include a complete Sonos electronics with special brackets for the Sonos mainboard, antennas, keypad, power supply and damping foam. Just disassemble the old Beolab electronics and install the new Sonos electronics, instructions included. Keypad, LED, network and 230 VAC will be located at back of the speaker, see picture. The original on/off button is replaced by a plug. You will keep the two speakers and the complete casing from the original Beolab 4000, the rest will be new.
Price is 290€ per speaker including freight within EU. I am located in Sweden and ship with Schenker inside EU.
For order or questions please contact me at carlj.hakansson@gmail.com or +46730257474
Regards,
Carl Hakansson
22 June 2023 at 08:26 #47293 LeosgonewildBRONZE MemberVery impressive!
how do they sound?
22 June 2023 at 08:47 #47294Stereomensch
BRONZE MemberThis is a very interesting project.
But what kind of amplifier do you use? Do you use the original B&O soundprofil?
24 June 2023 at 15:45 #47295
carljhBRONZE MemberThey sound extremely good, I will try to make a comparison with the original and come back. With the Sonos trueplay calibration, the frequency range will be flat.
24 June 2023 at 15:52 #47296
carljhBRONZE MemberThe kit include an Ikea Symfonisk amplifier and electronics (which is made by Sonos). This consist of a very powerful DSP which will calibrate the Beolab 4000 speakers to a flat frequency spectrum and a multiroom wifi active two way speaker.
24 June 2023 at 19:16 #47297 matadorModeratorSo it’s basically an 130€ Ikea Symphonisk shelf speaker guts connected to the Beolab 4000 drivers?
I think I’ve seen the same mod with a Beovox C100 somewhere.
24 June 2023 at 20:05 #47298
carljhBRONZE MemberJust to be clear, no Beolab 4000 drivers are present. The Beolab 4000 speaker elements are direct connected to the Sonos amplifier and all is 100% integrated in the Beolab 4000 cabinet.
24 June 2023 at 20:52 #47299 MillemisBRONZE MemberThe kit include an Ikea Symfonisk amplifier and electronics (which is made by Sonos). This consist of a very powerful DSP which will calibrate the Beolab 4000 speakers to a flat frequency spectrum and a multiroom wifi active two way speaker.
Did you test that?
As far as I understand DSP processing, you must know the characteristics of the used drivers/speaker units in order to let the DSP do it’s job.MM
24 June 2023 at 21:12 #47300 trackbeoBRONZE MemberReally? I thought it just listened to the output and calculated a boost as a percentage of the input, i.e. you could be driving cardboard (or flax!) with tubes, for all the DSP algorithm cared. This is how Dirac Live can work inside a MiniDSP DDRC-24 (e.g.): Dirac knows nothing about the speakers or the amp, only what it hears from its microphone input when it sends out a known signal sweep.
And “speaker elements” == “drivers” colloquially so yes, s/he is indeed hooking up the inexpensive Symfonisk amp to the 4000’s drivers and bypassing or removing the electronics. BeoWorld description claims 35 watt x 2 (ICEpower version mk.2), and supposedly the amplifier on the Symfonisk speaker is the TI TPA3116D2, a two channels x 30 watts per — so it could work OK unless you crank the volume up, maybe? [Edit: the DSP will take some headroom too.]
P.S. @carljh, kindly use your first sale to buy a gold membership here, in order to post to sell stuff.
24 June 2023 at 21:26 #47301
carljhBRONZE MemberYou calibrate the rebuild speaker with Sonos Trueplay which is included in the Sonos app for Iphone and Android. The speaker play a frequency sweep which the phone pick up and adjust the speaker for a flat frequency response.
2 July 2023 at 11:16 #47302
carljhBRONZE MemberI have now made an initial sound test between the original Beolab4000 and the rebuild version with the Sonos built in amplifier. The result is very positive! It is a dramatically improvement with the Sonos amp! The sound is much more open, this is specially present with the voices. The bass is more precise and nuanced in the rebuilded speakers.
2 July 2023 at 11:30 #47303 MillemisBRONZE MemberQuestions?
Did you pair two rebuild speakers?
Which source did you use with the original BL4000’s?
2 July 2023 at 12:27 #47304
carljhBRONZE MemberYes, I rebuild two speakers and got two more as original.
I used Sonos Connect via the RCA input for the original Beolab4000 in order to make it as equal as possible.
21 November 2023 at 10:01 #47305
carljhBRONZE MemberYou can read more about this BL4000 to Sonos upgrade at http://www.speakersuits.com
22 November 2023 at 17:20 #47306 Steve at Sounds HeavenlyGOLD MemberP.S. @carljh, kindly use your first sale to buy a gold membership here, in order to post to sell stuff.
@carljh We do normally ask you to pay for gold membership before offering items for sale, in particular in this case it looks as though you are offering to sell this item commercially. Would you please be so kind as to purchase gold membership on the site so that you are helping to give something back to our community? Many thanks!Location: The cable workshop, England
28 November 2023 at 13:41 #47307
carljhBRONZE MemberHi Steve,
I wasn’t aware that you had these requirements you mention above. I have looked everywhere and can’t find how to upgrade to a gold membership nor how much it cost and how to pay?
Regards,
Carl
28 November 2023 at 13:56 #47308 GuyModeratorClick the ‘Main Web Site’ link above (or under the Menu button if using a phone), then look to the right hand side below the LOGOUT button – you should see a link to ‘Upgrade/Renew Membership’.
28 November 2023 at 15:43 #47309
carljhBRONZE MemberI am now a gold member and my main site profile state that but not on this forum? What its wrong?
28 November 2023 at 16:34 #47310 Keith Saunders
Nothings wrong. Thank you for becoming a gold member
