Home Forums BeoWorld around the world! North America Connecting AUX source to Beo Ouverture
  • #63809
    Pablo Infante
      Hello! I just visited your website and had a question. I have a beolab6000 connected to a Beosound Ouverture. I was trying to connect an external network adapter for AirPlay and Bluetooth. I bought a Wiim Mini, and a 7pin to rca cable. I connected the aux out on the wiim mini to the ouverture with the 7pin adapter and no sound comes out the speakers. If I try to put the Wiim directly on one of the speaker and set it on « Line » It works. Do you have any solution for me? I wanted to have everything connected through the beosound ouverture.
      #63812
      Guy
        Hi and welcome to Beoworld!
        You need to make sure that your DIN to RCA connector sends the input to pins 3&5 of the DIN connector.  Your lead is probably a DIN output using pins 1&4. (EDIT:  You don’t need a 7-pin DIN, a 5-pin DIN will work)
        The correct connections are as follows:
        2010-05-18_125944_Til_7_polet_DIN_IN_fra_RCA
        EDIT:  And make sure that you connect to the AUX input of the Ouverture and not one of the Powerlink sockets!
        • This reply was modified 3 weeks, 3 days ago by Guy.
        My B&O Icons: BeoCenter-9500 Beo4 Beovision-10BeotimeBeosoundBeosound-Explore Beosound-Essence Beoplay-P2Beoplay-M3Beoplay-H4Beoplay-H3Beoplay-Form-2iBeoplay-EarsetBeoplay-A2
        #63818
        Millemis
        GOLD Member
          If you prefer to buy one….
          ….you’ll need something like this
